Sony Ericsson ARM Inside: A3618,R600,T100,T100c,T102,T105,T106,Z200,J200,J200i,J200c, J210,J220,230,Z300 etc. AVR Inside: R520,T200,T202,T226,T226m,T226s,T230,T237,T238,T290,T290a,T290c,T290i, T300,T302,T306,T310,T312,T316,T39,T65,T68,T610,T616,T618,T628,T630,T637,P800,P802, P900,P908,P910,Z600,Z608. New ARM Inside (SEMC):D750,F500,J300,K300,K310,K500,K506c,K508,K510,K600,K608,K610,K700,K750,K790,M600, P990,S700,S710,W300,W550,W600,W700,W800,W810,W900,V600,V630,V800,Z1010,Z300,Z500,Z520,Z530,Z550,Z800. CR 16B Inside:T66,T600,T600c,T602. ODM:J100. C Series: C510, C702, C901, C902, C903, C905
G Series: G502, G705
K Series: K630, K660, K850
T Series: T700, T707, T715
V Series: V640
W Series: W508, W595, W705, W715, W760, W890, W902, W910, W980, W995
Z Series: Z750, Z770, Z780 |
07-31-2008, 08:23 | #1 (permalink) |
Registered User Join Date: Nov 2006
Member: 386835 Status: Offline Sonork: 1651112:jassi Thanks Meter: 22 | somebody help with cruiser Version 13.01 ready! [ --- Attach to Phone --- ] Connecting via Fighter USB Cable... Powering on the phone... Baseband chip ID: 0x8040 Protocol version: 3.1 Baudrate = 460800Bd Booting via ROM... Sony Ericsson phone detected. Phone CID: 49 Phone color: Red Flash certificate: A1_DB2010_49_RED Trying Red CID49 flash applet... Sending applet prologue... Sending applet body... Time spent entering bootstrap: 1s Initializing phone hardware... Applet ID: 060206 1814 NPACXC125872_COMPACTPRO... Flash manufacturer: ST Microelectronics Flash ID: 0x200D OTP Security Level: 1 (Retail) OTP CID: 49 Sending applet... Terminating threads... All threads terminated. no set is connecting always getting this...i have already uninstall and reinstall all cruiser drivers and setup again.. |
07-31-2008, 12:51 | #2 (permalink) |
Super Moderator Join Date: Aug 2005 Location: UK.... Age: 57
Member: 173077 Status: Offline Sonork: 100.1594293 Thanks Meter: 2,783 | 1.. update your software, its a little outdated. Do you use a dongal, and cables (instead of box) if this is the case, what power have you got for your Batterys.. if useing a box, plug direct into PC,, not a Hub.... ps, cruiser has its own section. |
The Following User Says Thank You to THE CLASH For This Useful Post: |
08-01-2008, 16:57 | #3 (permalink) |
Freak Poster Join Date: Jun 2008
Member: 788782 Status: Offline Sonork: 100.1610033 Thanks Meter: 1,035 | Manually select phone model, will be modified CID below the two hook removed, the on-line, can the |
The Following User Says Thank You to MTK-BOX For This Useful Post: |
somebody help with bb unlock | REKIN_R.C. | Phone Unlocking Codes & Maps | 3 | 01-18-2010 17:52 |
Somebody help with registration !!! | Kiano | ULT PRO | 7 | 09-10-2007 08:46 |
somebody help with v3r fullflash in shx or sbf | ::gsmcoder:: | Motorola P2k | 5 | 03-12-2007 09:11 |
Need Help with Cruiser | soudies | Cruiser Suite | 2 | 07-14-2005 18:07 |
