Sony Ericsson ARM Inside: A3618,R600,T100,T100c,T102,T105,T106,Z200,J200,J200i,J200c, J210,J220,230,Z300 etc. AVR Inside: R520,T200,T202,T226,T226m,T226s,T230,T237,T238,T290,T290a,T290c,T290i, T300,T302,T306,T310,T312,T316,T39,T65,T68,T610,T616,T618,T628,T630,T637,P800,P802, P900,P908,P910,Z600,Z608. New ARM Inside (SEMC):D750,F500,J300,K300,K310,K500,K506c,K508,K510,K600,K608,K610,K700,K750,K790,M600, P990,S700,S710,W300,W550,W600,W700,W800,W810,W900,V600,V630,V800,Z1010,Z300,Z500,Z520,Z530,Z550,Z800. CR 16B Inside:T66,T600,T600c,T602. ODM:J100. C Series: C510, C702, C901, C902, C903, C905
G Series: G502, G705
K Series: K630, K660, K850
T Series: T700, T707, T715
V Series: V640
W Series: W508, W595, W705, W715, W760, W890, W902, W910, W980, W995
Z Series: Z750, Z770, Z780 |
06-04-2007, 08:39 | #1 (permalink) |
No Life Poster Join Date: Jan 2004
Member: 49339 Status: Offline Thanks Meter: 93 | how to flash p990i with se tool? |
06-04-2007, 15:04 | #2 (permalink) |
Freak Poster Join Date: Mar 2006 Location: Corazón de America
Member: 240984 Status: Offline Thanks Meter: 9 | 1. Select USB interface for use DCU-60 cable. 2. Go to settings tab and check complete phone after flash + unlock after flash + user server for csca + enable alternative security bypass. 3. Go to PDA tab, select you pda model, in firmware package options add the .zip firmware package (not unziped). 4. Check process pda update files. 5.click flash button You need spend 1 log to do this. (step 1) BR |
The Following 2 Users Say Thank You to cocoliso2005 For This Useful Post: |
11-26-2007, 20:46 | #5 (permalink) | |
Freak Poster Join Date: Apr 2004 Location: guinea conakry Age: 44
Member: 63749 Status: Offline Thanks Meter: 14 | Quote:
Loaded 51 flash descriptors SERVER SUPPORT ENABLED. writing C:\Documents and Settings\Administrateur.URANIUMOFCOURSE\Bureau\v0. 91380096\P990i_Generic_World2_R9G007_R6D23_R6D23.z ip Processing package C:\Documents and Settings\Administrateur.URANIUMOFCOURSE\Bureau\v0. 91380096\P990i_Generic_World2_R9G007_R6D23_R6D23.z ip detected MASTER on COM6, SLAVE on COM56 version request timeout PDA EROM VERSION: N/A package not contains ISP files Processing ACPU files Break. Elapsed:59 secs. SERVER SUPPORT ENABLED. writing C:\Documents and Settings\Administrateur.URANIUMOFCOURSE\Bureau\v0. 91380096\R5A01_CDA162008_59_ACPU_HE_Trade_Thailand .zip Processing package C:\Documents and Settings\Administrateur.URANIUMOFCOURSE\Bureau\v0. 91380096\R5A01_CDA162008_59_ACPU_HE_Trade_Thailand .zip detected MASTER on COM56, SLAVE on COM6 PDA EROM VERSION: CXC162060 R1A10 package not contains ISP files Processing ACPU files PROCESSING: Core OS FILE FLASHED OK PROCESSING: ROFS1 FILE FLASHED OK PROCESSING: ROFS1 Extension FILE FLASHED OK PROCESSING: ROFS2 FILE FLASHED OK PROCESSING: USERDATA FILE FLASHED OK PLEASE IGNORE "PRESS POWER ON" MESSAGES !!!! fetched MASTER on COM56, SLAVE on COM6 Open COM port OK ChipID:7100,EMP protocol:0301 NEW SECURITY MODEL DETECTED PHONE IS RED RETAIL PRODUCT FLASH CID detected:49 Speed:921600 OTP LOCKED:1 CID:49 PAF:1 IMEI:35959300279622 CERT:RED LDR:060524 0930 LIECXC1325414_DB2000_FLASHLOADER_R1A003 Flash ID check:2010 Flash props sent ok Processing CCPU files Flashing: R4A01_CXC162087_CCPU_fs_HE_Red_CID49_Respin.softwa re CURRENT FLASH FILE CID:49 SSW uses complete hash, hash len is:160 Will flash 8 blocks... SSW loading returns:0 Flashing: R9EA001_CXC162037_CCPU_HE_LL_NI_Red_CID49_Respin.s oftware CURRENT FLASH FILE CID:49 SSW uses complete hash, hash len is:2120 Will flash 106 blocks... SSW loading returns:0 Processing update files LDR:070405 1245 NPA1_CXC1327363_1_SEMC_CS_LOADER_1_P1E loader startup: executed loader GDFS startup: executed Skipping filesystem startup for smart phone loader unlock: executed Writing gdfs var 0000:057E len:0022 Success Writing gdfs var 0000:00A6 len:0005 Success Writing gdfs var 0000:0052 len:0014 Success Writing gdfs var 0002:079E len:0055 Success Writing gdfs var 0002:06D6 len:0001 Success Writing gdfs var 0002:06D4 len:0006 Success Writing gdfs var 0002:06D3 len:000F Success Writing gdfs var 0000:0094 len:0001 Success unlock impossible with server/card support enabled. | |
The Following 2 Users Say Thank You to sabbalde For This Useful Post: |
05-03-2008, 19:01 | #6 (permalink) |
Junior Member Join Date: Mar 2008
Member: 723842 Status: Offline Thanks Meter: 3 | P990i hi there, i have a problem flashing a p990i, i manage to flash it well before chip id detection...as shown above ...Processing ACPU files PROCESSING: Core OS FILE FLASHED OK PROCESSING: ROFS1 FILE FLASHED OK PROCESSING: ROFS1 Extension FILE FLASHED OK PROCESSING: ROFS2 FILE FLASHED OK PROCESSING: USERDATA FILE FLASHED OK PLEASE IGNORE "PRESS POWER ON" MESSAGES !!!! fetched MASTER on COM56, SLAVE on COM6 Open COM port OK and afterwards nothing. maybe it s a hardware problem? i found some oxide on it, cleaned it and rehot it... thanks |
The Following 2 Users Say Thank You to robert s For This Useful Post: |
How To Unlock W850i With SE Tool Box3? | .:RAGE:. | SETool2 | 6 | 08-03-2012 14:30 |
how to flash k790i with se tool ? | narpinder | SETool2 | 0 | 12-13-2009 06:55 |
how to flash p990i with se tool? | kapilkapoor | SETool2 | 5 | 06-08-2008 19:14 |
how to flash p990i with se tool.pls guide | kapilkapoor | SETool2 | 1 | 06-07-2008 18:53 |
