Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| Sony Ericsson ARM Inside: A3618,R600,T100,T100c,T102,T105,T106,Z200,J200,J200i,J200c, J210,J220,230,Z300 etc. AVR Inside: R520,T200,T202,T226,T226m,T226s,T230,T237,T238,T290,T290a,T290c,T290i, T300,T302,T306,T310,T312,T316,T39,T65,T68,T610,T616,T618,T628,T630,T637,P800,P802, P900,P908,P910,Z600,Z608. New ARM Inside (SEMC):D750,F500,J300,K300,K310,K500,K506c,K508,K510,K600,K608,K610,K700,K750,K790,M600, P990,S700,S710,W300,W550,W600,W700,W800,W810,W900,V600,V630,V800,Z1010,Z300,Z500,Z520,Z530,Z550,Z800. CR 16B Inside:T66,T600,T600c,T602. ODM:J100. C Series: C510, C702, C901, C902, C903, C905
G Series: G502, G705
K Series: K630, K660, K850
T Series: T700, T707, T715
V Series: V640
W Series: W508, W595, W705, W715, W760, W890, W902, W910, W980, W995
Z Series: Z750, Z770, Z780 |
| | #1 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Aug 2002
Member: 14741 Status: Offline Thanks: 0
| >> How to repair dead J210i << First of all u need Cruiser and USB-Smart.....and Full charged battery!!!! 1. Flash the phone with Cruiser with "J210i_Repair_v2.ARM.flp" 2. Detach the phone from Cruiser soft. 3. "remake CRC's" with USB-Smart 4. "read all codes" with USB-Smart and don't touch the phone before it's power on automatically. After that power off the phone and disconnect the cable!!! The phone is 100% working!!! Enjoy |
| | #2 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: May 2001 Location: Bulgaria
Member: 4627 Status: Offline Sonork: 57528:debeliamark Thanks: 51
| Easy way: Use old good UFS ( Tornado, Twister, ect ... ) and flash files from ..J200i and J210 Flash Files for UFS... Connect phone like Z200, flash with desired flash file, InitSecBlk, Power on, Enjoy! No need Cruiser, USB-BlaBla..., MT_Se... ect... |
| The Following User Says Thank You to debeliamark For This Useful Post: |
| | #3 (permalink) |
| Insane Poster ![]() ![]() ![]() Join Date: Apr 2006 Location: Male', Maldives
Member: 260672 Status: Offline Thanks: 0
| Hi, i have a dead J210i ...i have flashed the phone using cruiser , i have used "J210i_CDA102416-1_R3B_World_Generic_v2.ARM" & "J210i_Repair_v2.ARM" to flash...but still its dead , can u pls help me |
| | #4 (permalink) | |
| Quote:
| | #5 (permalink) |
| I have USB-Smart SEMC tool version 5.1 but it dosnt have the option of recalc DCRC, the cruiser has this option but i tried this method below and the phone came alive but went dead after it detached from cruiser • write repair flash and generic flash from cruiser support • select phone as j200 • make unlock and remake crc. • after that, you will need a twister box • select again j200 from N-Box • Do initSecBlk, when appear massage reattach battery remove battery and reattach battery and click yes • your phone will be alive pls help me guys!!!!!!!!!!!!!!!!!! |
| | #6 (permalink) | |
| Quote:
... you forget to make power off / power on cycle. | |
| | #7 (permalink) | |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2001 Location: Inside Raskal pocket
Member: 5325 Status: Offline Thanks: 11
| Quote:
Here is procedure how to repair J210 phones (this solve ANY software problems, no power up, ...) - Use SEMC Tool v7.5 (or higher version) - NOT use UFS/Twister as interface !!! (use any other cable, Cruiser, Serial, DSS) - Flash file J210_Full_Repair_Flash.arm - Disconnect phone from cable after flash - Remove battery from phone - Insert battery to phone - Connect phone to cable - object ChkCalcCrc: TCheckBox - Repair -> Remake CRC's (SCRC, DCRC1, DCRC2) - Wait phone to power up before disconnect from cable !!! - If required, read codes, put a SIM card and unlock If in repair flash you dont find needed language, do this: - Flash your required language flash file - Disconnect phone from cable after flash - Remove battery from phone - Insert battery to phone - Connect phone to cable - Repair -> Remake CRC's (SCRC, DCRC1, DCRC2) - Wait phone to power up before disconnect from cable !!! - If required, read codes, put a SIM card and unlock - If after read codes your phone is dead do again Repair -> Remake CRC's (SCRC, DCRC1, DCRC2) - Wait phone to power up before disconnect from cable !!! - Put a SIM card, press <**< then enter NCK unlock code readed This procedure is confirmed working well by more USB-Smart users: j210 repair work Of course, you should have USB-Smart dongle to do this. | |
| | #8 (permalink) |
| hey thanx for the gr8 tip...can u pls provide me a url where i can get SEMC Tool 7.5 or above version...i cudnt get one can u provide me this tool plsssssssssss |
| | #9 (permalink) | |
| Quote:
Of course bro, this is : www.usb-smart.com | |
| | #10 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2005
Member: 184793 Status: Offline Sonork: 100.1574609 Thanks: 0
| Thinx Zulea but i have other problem my mobile now can't be unlocked ;take look 17/04/2006 11:33:57 Phone: J210 IMEI: Unlock NCK: 00000000 Unlock NSCK: 00000000 Unlock CCK: 00000000 Unlock SPCK: 00000000 Lock NCK: 00000000 Lock NSCK: 00000000 Lock CCK: 00000000 Lock SPCK: 00000000 can u help |
| | #11 (permalink) | |
| Quote:
without problem Best regards lordmen007 | |
| | #12 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Dec 2003 Location: ALGERIA Age: 34
Member: 46191 Status: Offline Thanks: 65
| Go here and see what is on this thread you can find your solution http:///vbb/showthread.php?t=275226 GOOD LUCK |
| | #14 (permalink) | |
| Quote:
| | #15 (permalink) | ||
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Dec 2001 Location: Gliwice, Poland Age: 36
Member: 8184 Status: Offline Thanks: 4
| Quote:
I have got dead J210i, if I make first step with repair flash and crc remaking all's o.k. But if next I flash with J210i_EU3_R2H_h.arm (I need EU3 langpack), flashing o.k., but phone don't power up after remake CRC's and '- Wait phone to power up before disconnect from cable !!!', if I disconnect cable phone is dead... Any suggestion? WBR Axee | ||
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| here is how to repair dead j210i | deha | Sony Ericsson | 11 | 08-07-2008 11:24 |
| How to unlock M55 without restpoint and How to repair dead phones. | halcon.cpu | E-Gold Based Phones | 10 | 06-19-2004 14:31 |
| How to repair dead S35? | HiTech | x1x to x45/x50 | 3 | 01-17-2002 16:03 |
| how to repair dead alcatel be1 16f | pilcris | Alcatel TCL Hardware Repair Section | 3 | 12-06-2001 12:22 |
| How to repair dead A35 v2506 | miba | x1x to x45/x50 | 2 | 11-19-2001 16:42 |
