Sony Ericsson ARM Inside: A3618,R600,T100,T100c,T102,T105,T106,Z200,J200,J200i,J200c, J210,J220,230,Z300 etc. AVR Inside: R520,T200,T202,T226,T226m,T226s,T230,T237,T238,T290,T290a,T290c,T290i, T300,T302,T306,T310,T312,T316,T39,T65,T68,T610,T616,T618,T628,T630,T637,P800,P802, P900,P908,P910,Z600,Z608. New ARM Inside (SEMC):D750,F500,J300,K300,K310,K500,K506c,K508,K510,K600,K608,K610,K700,K750,K790,M600, P990,S700,S710,W300,W550,W600,W700,W800,W810,W900,V600,V630,V800,Z1010,Z300,Z500,Z520,Z530,Z550,Z800. CR 16B Inside:T66,T600,T600c,T602. ODM:J100. C Series: C510, C702, C901, C902, C903, C905
G Series: G502, G705
K Series: K630, K660, K850
T Series: T700, T707, T715
V Series: V640
W Series: W508, W595, W705, W715, W760, W890, W902, W910, W980, W995
Z Series: Z750, Z770, Z780 |
09-19-2009, 22:27 | #1 (permalink) |
Freak Poster Join Date: Oct 2008
Member: 884184 Status: Offline Thanks Meter: 14 | How to repair GDFS for Sony Ericsson K610i with no Backup, using SE Tool Box 3 I've flashed and unlocked hundreds of K610i with SetoolBox3, with no problems, however when i was doing few weeks ago, (ironically while making backup of GDFS) it failed. (I'm not sure how, but I discovered some of my files had vanished from the folder, after my dad used the computer.) Now the phones do not power up, and there is NO red light, just completely dead, when I try to flash, I get: GDFS startup failed,error is 04 [1D] loader GDFS startup failed, that is fatal Now I don't have backups, as it failed to backup and thats what killed it & I don't know how to really fix the GDFS, however in the past I have fixed by using Sony Ericsson Update Service, but this only works when the phone has old firmware on it, and then it lets you update it, My phones already have latest firmwares, so there is nothing to update. I have tried using some tips, and I've looked at many guides, and tips over the last 11 months on how to fix GDFS, but nothing seems to be clear or work. I am told it is really easy to fix using cruiser and a file called: K610_ by_ gsm_enggine.gdfs However I only have SetoolBox 3, but I am told that it's now possible to fix GDFS without backup, and without Testpoint. (I have no idea about Testpoint) Some people say use old version of setool software, I have used old and new, but doesn't seem to work, I'm not sure if i'm doing it right or using right files. I have tried putting the file, K610_ by_ gsm_enggine.gdfs in the Misc files: and then clicked Write GDFS, but it says: phone CID not supported in that mode Can someone make a simple 1,2,3 step or however many steps are needed guide for my problem. And send me any files needed, if needed. |
09-20-2009, 12:02 | #3 (permalink) |
Member: 884184 Status: Offline Thanks Meter: 14 | Yes, doesn't work, I tried with and without options on and off: Loaded 51 flash descriptors CFG:000000000000 Will write GDFS now. ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:921600 OTP: LOCKED:1 CID:49 PAF:1 IMEI:XXXXXXXXXXXXXXXX CERT:RED FLASH CID:49 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 FLASH ID:897E phone CID not supported in that mode Elapsed: 7 secs. SIGNED MODE (USING SERVER) CFG:100000000000 Will write GDFS now. ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:921600 OTP: LOCKED:1 CID:49 PAF:1 IMEI:XXXXXXXXXXXXXXXX CERT:RED FLASH CID:49 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 FLASH ID:897E LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader startup: executed GDFS startup failed,error is 04 [1D] loader GDFS startup failed, that is fatal Elapsed: 9 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110000000000 Will write GDFS now. ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:921600 OTP: LOCKED:1 CID:49 PAF:1 IMEI:XXXXXXXXXXXXXXXX CERT:RED FLASH CID:49 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 FLASH ID:897E bypassing security... server step1 error:No server found. loader unlock failed, that is fatal Elapsed: 10 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED PRELOADER SECURITY BYPASS ENABLED CFG:111000000000 Will write GDFS now. ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:921600 OTP: LOCKED:1 CID:49 PAF:1 IMEI:XXXXXXXXXXXXXXXX CERT:RED FLASH CID:49 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 FLASH ID:897E LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader startup: executed GDFS startup failed,error is 04 [1D] loader GDFS startup failed, that is fatal Elapsed: 11 secs. |
The Following User Says Thank You to samaraki For This Useful Post: |
09-20-2009, 12:27 | #4 (permalink) |
Freak Poster Join Date: Feb 2007 Location: Spain
Member: 453324 Status: Offline Thanks Meter: 54 | Ya unlock with code using singed mode and perfom full unlock these two options or try with the lastest version may be your problem solved but by using code sure your problem solved. |
The Following User Says Thank You to belli42 For This Useful Post: |
09-20-2009, 13:49 | #5 (permalink) |
Member: 884184 Status: Offline Thanks Meter: 14 | You are a genius, saved me a lot of money, I normally flash / unlock using all top settings, usually works a treat, however as I got broken gdfs for 3 phones,that method would not work for them, but I did what you said, and it let me flash them, and turn phone on, HOWEVER when i turned phone there was error on screen, contact service provider, BUT, I went to Sony Ericsson Update Tool, and it found latest software, and reinstalled. Now all works. |
how to repair gdfs for sony w200 | SATISH M ROHRA | Universalbox | 2 | 11-11-2009 19:24 |
How to repair GDFS for K750???? | masood karimy | Sony Ericsson | 2 | 07-21-2009 08:50 |
How to repair GDFS for K750???? | masood karimy | Sony Ericsson | 2 | 07-18-2009 21:51 |
How to Flash & Unlock Sony Ericsson K610i | samaraki | Sony Ericsson | 0 | 11-17-2008 17:00 |
how to difference version for sony ericsson all model | my toh | Sony Ericsson Hardware Repair | 3 | 01-26-2007 11:35 |
