Sony Ericsson ARM Inside: A3618,R600,T100,T100c,T102,T105,T106,Z200,J200,J200i,J200c, J210,J220,230,Z300 etc. AVR Inside: R520,T200,T202,T226,T226m,T226s,T230,T237,T238,T290,T290a,T290c,T290i, T300,T302,T306,T310,T312,T316,T39,T65,T68,T610,T616,T618,T628,T630,T637,P800,P802, P900,P908,P910,Z600,Z608. New ARM Inside (SEMC):D750,F500,J300,K300,K310,K500,K506c,K508,K510,K600,K608,K610,K700,K750,K790,M600, P990,S700,S710,W300,W550,W600,W700,W800,W810,W900,V600,V630,V800,Z1010,Z300,Z500,Z520,Z530,Z550,Z800. CR 16B Inside:T66,T600,T600c,T602. ODM:J100. C Series: C510, C702, C901, C902, C903, C905
G Series: G502, G705
K Series: K630, K660, K850
T Series: T700, T707, T715
V Series: V640
W Series: W508, W595, W705, W715, W760, W890, W902, W910, W980, W995
Z Series: Z750, Z770, Z780 |
01-23-2010, 22:11 | #1 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Gsm World Age: 37
Member: 1157693 Status: Offline Thanks Meter: 122 | How to repair GDFS of W580i GDFS startup failed,error is 04 [1D] loader GDFS startup failed, that is fatal plez can tell me how to repair gdfs whats solution writing "C:\Documents and Settings\SHOP\Ambiente de trabalho\s.e tool2\sony ericsson flash\W580i\R8BE001_1123362_GENERIC_LA.ssw" CURRENT FLASH FILE CID:52 SSW uses full hash, hash len is: 9200 Will flash 460 blocks... writing "C:\Documents and Settings\SHOP\Ambiente de trabalho\s.e tool2\sony ericsson flash\W580i\R8BE001_FS_EUROPE_1_LA_RED_CID52.ssw" CURRENT FLASH FILE CID:52 SSW uses full hash, hash len is: 4260 Will flash 213 blocks... LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader startup: executed GDFS startup failed,error is 04 [1D] loader GDFS startup failed, that is fatal Elapsed: 494 secs. |
The Following User Says Thank You to nofear99 For This Useful Post: |
01-23-2010, 22:20 | #3 (permalink) |
No Life Poster Join Date: Sep 2007 Location: algeria
Member: 591880 Status: Offline Thanks Meter: 561 | 1. make sure you have needed quantity of credits on your account 2. select proper model 3. on settings check only "signed mode (using server)" 4. if phone db200x,db201x select COM/UFS as interface. if phone is db2020 - you can select COM/UFS/USB as interface. if phone is db2020 and USB interface selected - you MUST boot phone in bootrom mode (hold "2+5" while inserting cable) 5. press "recovery". 6. if phone hardware okay (flash chip,ram,etc) - phone will be reset to developer status (brown) 7. phone is BROWN now. 8. staying on "emptyboard fill and repair" write correct gdfs_in_ssw format. 9. if flashing went fine, flash db2020 erom with needed CID, still on "emptyboard fill" tab 10. phone now retail and repaired. fullflash phone as usual. |
03-08-2010, 17:50 | #6 (permalink) |
Junior Member Join Date: Dec 2006
Member: 414358 Status: Offline Thanks Meter: 2 | CFG:00000000000000 RECOVERY MODE STARTED REC:070703 1229 NPA4_CXC1329130_DB2020_SEMC_RECOVERY_P3N can't open file "frec\marikabrowncid16.bin" Recovery failed. Phone dead. Elapsed: 18 secs. |
03-08-2010, 17:51 | #7 (permalink) |
Member: 414358 Status: Offline Thanks Meter: 2 | SIGNED MODE (USING SERVER) CFG:10001010000000 ChipID:9900,EMP protocol:0301 Speed:115200 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35714301170552 CERT:N/A FLASH CID:53 COLOR:RED PATCH:071120 1355 HANCXC9876543210_DB2020_MEM_PATCHER_R2A012 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 FLASH ID check:897E Flash props sent ok writing "D:\sony ericsson flash file\w580i\cid-53\R8BE001_1123478_TAIWAN_LA.ssw" CURRENT FLASH FILE CID:53 SSW uses full hash, hash len is: 9200 Will flash 460 blocks... SSW loading returns:0 writing "D:\sony ericsson flash file\w580i\cid-53\R8BE001_FS_TAIWAN_LA_RED_CID53.ssw" CURRENT FLASH FILE CID:53 SSW uses full hash, hash len is: 4260 Will flash 213 blocks... SSW loading returns:0 LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader startup: executed GDFS startup failed,error is 04 [1D] loader GDFS startup failed, that is fatal Elapsed: 4064 secs. |
03-08-2010, 20:43 | #8 (permalink) | |
No Life Poster Join Date: Jun 2006 Location: {JUST@PRAY@FOR@ME} Age: 39
Member: 288504 Status: Offline Sonork: .:100.1587032:. Thanks Meter: 2,266 | Quote:
b) install empty flash chip and do emptyboard fill procedure c) change both mcu+flash chip from other phone | |
03-16-2010, 13:03 | #10 (permalink) |
Member: 288504 Status: Offline Sonork: .:100.1587032:. Thanks Meter: 2,266 | |
05-05-2010, 12:53 | #11 (permalink) |
Insane Poster Join Date: Oct 2007
Member: 612010 Status: Offline Thanks Meter: 5 | w880 flash problem pls i need your help in w880 flash CFG:000000000000 Processing script "D:\Boxes\Setools\eroms\db2020\DB2020EROM_CNV_RED5 1_BROWN_CID49_DB2020.ssw"... ChipID:9900,EMP protocol:0301 Speed:115200 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35578501318960 CERT:N/A FLASH CID:49 COLOR:BROWN LDR:060721 1021 DB2020_SERVICE_LOADER FLASH ID: 2019 No situable FS loader found Elapsed: 15 secs. CFG:000000000000 ChipID:9900,EMP protocol:0301 Speed:115200 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35578501318960 CERT:N/A FLASH CID:49 COLOR:BROWN LDR:060721 1021 DB2020_SERVICE_LOADER FLASH ID: 2019 writing "C:\Downloads\R1JC002_1250648_HONG_KONG_AI.ssw " CURRENT FLASH FILE CID:51 SSW uses full hash, hash len is: 9200 HDR block not accepted,error: 19 Elapsed: 26 secs. thanks sir pllllssss help me |
05-05-2010, 13:02 | #12 (permalink) | ||
No Life Poster Join Date: Nov 2008 Location: U.S.A.
Member: 893209 Status: Offline Thanks Meter: 274 | Quote:
WRITE EROMS HIGHER or EQUAL than OTP,,,,,,,,, Then FLASH AGAIN MAIN@FS,,,,,,,,,, Br,. Rhyan777 | ||
The Following User Says Thank You to Rhyan777 For This Useful Post: |
05-05-2010, 13:29 | #13 (permalink) | |
please check FAQ for details. | |
How to repair gdfs of a2 phones. | alamgarh | Cruiser Suite | 1 | 12-10-2009 15:18 |
how to repair gdfs of w830 no tp with setool | SATISH | Sony Ericsson | 1 | 10-21-2009 19:22 |
How to repair gdfs, red blink and how to upgrade cid with ub in sony ericsson phones | svchost | Universalbox | 1 | 04-29-2009 16:00 |
How to Repair GDFS of K800 with Cruiser+ | rajinder1978 | Cruiser Suite | 3 | 04-10-2009 22:07 |
How to repair Gdfs of db2020 phone using ub | Gsm Mardan | Universalbox | 2 | 01-05-2009 10:57 |
