Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| Sony Ericsson ARM Inside: A3618,R600,T100,T100c,T102,T105,T106,Z200,J200,J200i,J200c, J210,J220,230,Z300 etc. AVR Inside: R520,T200,T202,T226,T226m,T226s,T230,T237,T238,T290,T290a,T290c,T290i, T300,T302,T306,T310,T312,T316,T39,T65,T68,T610,T616,T618,T628,T630,T637,P800,P802, P900,P908,P910,Z600,Z608. New ARM Inside (SEMC):D750,F500,J300,K300,K310,K500,K506c,K508,K510,K600,K608,K610,K700,K750,K790,M600, P990,S700,S710,W300,W550,W600,W700,W800,W810,W900,V600,V630,V800,Z1010,Z300,Z500,Z520,Z530,Z550,Z800. CR 16B Inside:T66,T600,T600c,T602. ODM:J100. C Series: C510, C702, C901, C902, C903, C905
G Series: G502, G705
K Series: K630, K660, K850
T Series: T700, T707, T715
V Series: V640
W Series: W508, W595, W705, W715, W760, W890, W902, W910, W980, W995
Z Series: Z750, Z770, Z780 |
| | #1 (permalink) |
| Insane Poster ![]() ![]() ![]() Join Date: Nov 2005
Member: 202892 Status: Offline Thanks: 0
| how to repair se k800i no power-red blinking and not posibility to conect conect cable 4 in 1 ,move to baterry out,put 2 crocodile and do conect (any interface for se).put reversering the alimentation for phone 1 sec and voila.phone conected and maybe flash |
| | #3 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Jul 2006
Member: 306903 Status: Offline Thanks: 38
| i've got same problem here hi ! mate i've got same problem here with 2 phones give red light and do not connect aswell. any solution for this all Masters !!!!!!!!!!!!!!!!!!!!! WBR., |
| | #5 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2006 Location: The Arrivals
Member: 263993 Status: Offline Sonork: 100.1612432 Thanks: 246
| i have same problem before. just short battery connektor with one nokia charger for 2-3 sconds . after can connekt without problem. ebu mohammed-emin |
| | #6 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Jan 2006
Member: 223770 Status: Offline Thanks: 105
| if your phone do not connect with a DCU-60 cable or rs232 cables this a hard ware problem try to rehot a µ controller ic and try if shi is connected with rs232 (you can use your ufs direct com and KulanKendi) u can flash easly |
| | #7 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Feb 2006 Location: Tanzania but U cant see me !!! Age: 32
Member: 228601 Status: Offline Thanks: 40
| i fix with cruiser 3 pcs just repaire erom, flash with main /fs then customize ur k800 will take 1 log and after thall enjoy!! |
| | #8 (permalink) |
| Banned ![]() ![]() ![]() ![]() ![]() ![]() Join Date: May 2003 Location: www.CentralMobile.net/vbb
Member: 28188 Status: Offline Thanks: 35
| Hi It is an erom damage. this solution gives a second chance, maybe you need too to arise the vpp voltage. Best regards, Aishur |
| | #9 (permalink) | |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Feb 2003 Location: P A K I S T A N
Member: 20645 Status: Offline Sonork: 100.1579175 Thanks: 262
| Quote:
WHEN U GOT RED BLINK MODE SO U SUE RJ45 CABLE ALWAYS USE FULL CHARGE BATTARY AND IF IT NOT CONECT THEN USE POWER SUPLLY COS I FACED SAME PROBLEM BUT I FOLOW THIS PROCEDURE AND SLOVED IF STILL PRESIT THEN CHECK ITS HARDWARE MEAN CHARGING BASE REGARDS GSM MIND | |
| | #12 (permalink) |
| solution is posted here,and don't reball,erom repair ,etc.not hardware.is soft.is't very simple .read my post about this.my english is.......but you understand |
| | #13 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2006 Location: Bangladesh
Member: 409725 Status: Offline Sonork: 100.1581478 Thanks: 299
| No need to flash/required erom repair Use ufs interface cable if u have setool Need erom repair Just press recovery....... _________________________________________________ Use Cruiser unchk 2option display info.....Attach phone and then press erom repair. |
| | #15 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: May 2007 Location: UK
Member: 503346 Status: Offline Thanks: 174
| Easy Way to Solve this Problem is: 1, Load Se tools or Universal or any other S.E Software 2, Connect UBL Testpoint cable to the Phones Battery Pins (Red Clip to - of Phone : Black Clip to +) 3, Leave the UBL Testpoint cable switched off 4, Connect Cable to bottom of phone 5, Press Info / Read Button on Selected Software 6, Turn On the UBL Testpoint Adapter (Error message should show up) i.e. S.e Tools Protection Card Error 7, Disconnect the UBL Testpoint Adpater 8, Plug in the Phones Battery and connect the Cable to the bottom of the phone 9, Press Info, Read, Reflash, Flash or any selected button on the Software Away you go..... 100% Tested on 5 Phones |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| How to repair gdfs, red blink and how to upgrade cid with ub in sony ericsson phones | svchost | Universalbox | 1 | 04-29-2009 16:00 |
| How To Repair W850 if detech k700- RED blink | zakiyyboss | Sony Ericsson | 26 | 03-28-2009 06:30 |
| K800i red blink and K770 dead set repaired thru dbss | alfox | DreamBox | 0 | 03-10-2009 08:39 |
| How To Repair W850 if detech k700- RED blink | zakiyyboss | SETool2 | 4 | 12-26-2008 11:31 |
| solution on 8210 no power but charging and flashing due to water damaged!!!!!! | andrew14 | Nokia Hardware & Hardware-Repair Area | 0 | 02-02-2005 02:20 |
