Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | .: Nokia Unlock :. | Search | Today's Posts | Mark Forums Read |
| Sony Ericsson ARM Inside: A3618,R600,T100,T100c,T102,T105,T106,Z200,J200,J200i,J200c, J210,J220,230,Z300 etc. AVR Inside: R520,T200,T202,T226,T226m,T226s,T230,T237,T238,T290,T290a,T290c,T290i, T300,T302,T306,T310,T312,T316,T39,T65,T68,T610,T616,T618,T628,T630,T637,P800,P802, P900,P908,P910,Z600,Z608. New ARM Inside (SEMC):D750,F500,J300,K300,K310,K500,K506c,K508,K510,K600,K608,K610,K700,K750,K790,M600, P990,S700,S710,W300,W550,W600,W700,W800,W810,W900,V600,V630,V800,Z1010,Z300,Z500,Z520,Z530,Z550,Z800. CR 16B Inside:T66,T600,T600c,T602. ODM:J100. C Series: C510, C702, C901, C902, C903, C905
G Series: G502, G705
K Series: K630, K660, K850
T Series: T700, T707, T715
V Series: V640
W Series: W508, W595, W705, W715, W760, W890, W902, W910, W980, W995
Z Series: Z750, Z770, Z780 |
| | #1 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: May 2004 Location: Mauritius
Member: 64823 Status: Offline Thanks: 284
| How To Repair W850 if detech k700- RED blink This is a tutorial about : How To Repair W850 if detech k700 You will need: 1.Setool 2.DreamBox 3. Testpoint 4.Skills........... Step 1: Use Setool and check if it reads like that (i.e k700) ![]() Steps 2 : 1.Repair GDFS area by using Test point with Dreambox SE ![]() Steps 3: Unlock & Repair GDFS Security Block ![]() Steps 4 : Write GDFS (file located below) ![]() Steps 5: Unlock and repair GDFS Security blocks again ![]() Steps 6 : Now use Setool and Identify ![]() Steps 7 : Flashing and Choose "complete phone" with Setool ![]() Steps 8: USE the THANKS button. GDFS file located here : http://rapidshare.com/files/102190471/w850_gdfs.dmap Solution brought to you by Zakiyyboss (zakiyy@gmail.com) Source : HERE |
| | #4 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Feb 2002 Location: Russia Age: 33
Member: 9519 Status: Offline Thanks: 2
| absolutely useless and completely confusing solution. - you do not need setool2 & dreambox, you need ANY of it, of course, setool2 is preferable. - when w850 (or ANY other db2020 phone) detected as K700 (mean firmware startup procedure not completed) user should check steps in order - check, if secunits mismatched (by identify function), if yes - repair secunits either with testpoint procedure,emptyboad fill or with kukuruzer interface to semc factory device (preferred for unexperienced users) test phone, if not helps, then - reflash phone with LATEST firmware version test phone, if not helps, then - make gdfs swap (read secunits backup, write gdfs from working phone, write secunits backup back) test phone, if not helps, then - check phone hardware (99% of "K700" cases) ANY of other "suggestions" and "solutions" are complete nonsense and should not be even readed. |
| The Following 5 Users Say Thank You to the_laser For This Useful Post: |
| | #5 (permalink) | |
| Quote:
Sorry to bother, But i used to had this problem but this one was really difficult to REPAIR so i used the above solution to resolved. This problem frequently come from: 1.Screen Damage 2.Top Keypad 3. Flex cable. Please correct me if am wrong. So i did all the above but still the same thing. So the solution i posted did resolved my problem. And for my POINT of view its not NONSENSE it just an experience that repair a PHONE for me and am JUST sharing it with ALL of you. !! An also i repair most of w850 - k700 problem by changing either FLEX or Screen !! this one was really TOUGH!!!! | |
| | #6 (permalink) | |
| Quote:
| The Following User Says Thank You to zakiyyboss For This Useful Post: |
| | #8 (permalink) |
| your "solution" is exactly 1+2+3 of my post, but it is done with two tools, while it can be done with either of them. but i should admit, testpoint now if just for fans, cause it is much simple to use "kukuruzer interface to semc factory tool", then stop it after step 2 (convert to r&d) and use normal tools to finish phone repair. |
| The Following 2 Users Say Thank You to the_laser For This Useful Post: |
| | #9 (permalink) | |
| Product Supporter ![]() ![]() ![]() Join Date: Mar 2005 Location: Tehran.IR Age: 32
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks: 517
| Quote:
| The Following User Says Thank You to BABAK NURI For This Useful Post: |
| | #10 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Feb 2007 Location: Pakistan Age: 26
Member: 447849 Status: Offline Sonork: 100.1604076 Thanks: 213
| This Is Old Solution Here Is The Easiest Way To Repair This Fault With SEtool2 Now Dont Need To Use 2 Tools Here Is The Video Tutorial Download B.R., Sonu |
| The Following 3 Users Say Thank You to Sonu Jawed For This Useful Post: |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| How to repair gdfs, red blink and how to upgrade cid with ub in sony ericsson phones | svchost | Universalbox | 1 | 04-29-2009 16:00 |
| how to repair W610i if identifyed same as K700. need ful procedure details | IkaMazini | Cruiser Suite | 1 | 03-06-2009 14:26 |
| How To Repair W850 if detech k700- RED blink | zakiyyboss | SETool2 | 4 | 12-26-2008 11:31 |
| how to repair se k800i no power-red blinking and not posibility to conect | lalasdj | Sony Ericsson | 22 | 11-23-2007 07:13 |
