Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Sony Ericsson > Sony Ericsson
Sony Ericsson
  • ARM Inside: A3618,R600,T100,T100c,T102,T105,T106,Z200,J200,J200i,J200c, J210,J220,230,Z300 etc.
  • AVR Inside: R520,T200,T202,T226,T226m,T226s,T230,T237,T238,T290,T290a,T290c,T290i, T300,T302,T306,T310,T312,T316,T39,T65,T68,T610,T616,T618,T628,T630,T637,P800,P802, P900,P908,P910,Z600,Z608.
  • New ARM Inside (SEMC):D750,F500,J300,K300,K310,K500,K506c,K508,K510,K600,K608,K610,K700,K750,K790,M600, P990,S700,S710,W300,W550,W600,W700,W800,W810,W900,V600,V630,V800,Z1010,Z300,Z500,Z520,Z530,Z550,Z800.
  • CR 16B Inside:T66,T600,T600c,T602.
  • ODM:J100.
  • C Series: C510, C702, C901, C902, C903, C905
  • G Series: G502, G705
  • K Series: K630, K660, K850
  • T Series: T700, T707, T715
  • V Series: V640
  • W Series: W508, W595, W705, W715, W760, W890, W902, W910, W980, W995
  • Z Series: Z750, Z770, Z780
  • Reply
    Old 09-22-2007, 16:49   #1 (permalink)
    Member: 593481
    Question how to SonyEricsson w810i unlocking?
    I have been reading through this forum for almost an hour and cannot find a straight answer about unlocking the w810i.
    Is it possible to unlock this phone for free with only the cable it came with?
    If the answer is yes, can we just make one thread that has the step by step instructions so that people can follow it and not have to read a hundred different posts?
    I am willing to write it all up if someone can point me in the right direction.
    Also I have read a lot about the different software involved but I cant find where to download any of it. Any links involving this would be greatly appreciated.
    Old 09-22-2007, 20:00   #2 (permalink)
    CxVj's Avatar
    Member: 122712
    what is your flash cid? post your firmware version at here.
    Old 09-22-2007, 20:27   #3 (permalink)
    Member: 593481
    is this the info you want?
    R4EA031prgcxc 1250504_CINGULAR_HN R4AE034
    EROM: R3A005 prgCXC 12504 16_EROM_DB2010_HELEN_FOTA_FLAFLA_SIBLA
    ITP SW VERSION
    CXC 125 0326 R1L
    how do i find the flash cid?
    Old 09-22-2007, 20:32   #4 (permalink)
    moldovan's Avatar
    Member: 23684
    Sonork: 1582723
    If CID of Your W810 or any other DB2010 phone is >49 , You need use 1 credit for unlock with SETool.
    WBR !
    Old 09-22-2007, 23:22   #5 (permalink)
    reactos's Avatar
    Member: 323137
    if cid 49 test setool2 Lite and this
    ;W810 SW-R4EA031
    ;Remove SIM-Lock
    ;© IronMaster
    +44140000
    d12918: 70B5041CF1F2C4F900230022011C1C20 F0B505213A22D1F71FFD0020F0BDC046
    save this text to .vkp format place it in misc and flash it in main
    Dont know if it will work on other firmware version then R4EA031
    Old 09-23-2007, 02:08   #6 (permalink)
    Muneer Ahmed's Avatar
    Member: 60500
    it depends on your CID of your phone whether it will get unlock for free or you will be requiring credits to unlock it......and for finding the CID of your phone you conect the phone with the software tool (se tool, UB box etc) and get the info of the phone you will get the CID...hope that my this answer will help you little bit...if theres any other querry you can ask me or other forum members without any hesitation
    Muneer Ahmed\ mR. hOt
    Old 09-23-2007, 05:21   #7 (permalink)
    nefreyu's Avatar
    Member: 538861
    Sonork: 100.1578309
    i am having problems connecting to setool3 box with w810i white which is cid50, i can unlock the black w810i which is cid49 but white one will not even let me "identify" the loading bar just keeps going and going. I am using dcu-60 with both colours so I can not imagine that this is a cable problem. I am aware that it cost credit however there is no point me buying credits for this model if I can not even connect with it first. any help would be much appreciated, Thanks.
    Old 09-23-2007, 08:46   #8 (permalink)
    CxVj's Avatar
    Member: 122712
    Hi,
    Make sure your se drivers installed properly, to identify your phone using setool press hold "C" then plug your dcu-60 cable and you will found new hardware install your SE driver after installation finish at the com port options use usb > then press do identify. You will know what exactly your flash cid is. if your flash cid is 50 you need to unlock using this settings:
    - at settings Tick complete phone after flash.
    - use server csca for unlock/patch.
    - put setool real login account.
    - tick use alternative bypass security
    CxVj
    Old 09-23-2007, 10:39   #9 (permalink)
    Member: 60500
    yes you are right that unless the phone does not connect to the software so theres no use of buying credits
    so first of all you check the SE driver if it is installed properly or not and then try....and if the cable is working on other phones and not working on the phone you are trying then the problem must be in your phone(charging connector or something else)......and if the phone connects it then you use the method which "CxVJ" told.
    Old 09-23-2007, 11:01   #10 (permalink)
    GSM_N4H's Avatar
    Member: 211652
    W810 with CID 50 unlocking requried 1 log , if you want unlock by pass unlocking (patch unlocking)
    if you want to unlcok CID 50 permanetly than you requried 4 logs
    both are different way to unlock it
    Old 09-23-2007, 11:05   #11 (permalink)
    nefreyu's Avatar
    Member: 538861
    Sonork: 100.1578309
    thanks for your help guys, I will try re install the software and drivers. I thought it was the phone that was the problem also however I have now tried 3 different white w810i and all do the same thing so must be driver problem.
    How to flash W810i domidick Sony Ericsson 2 04-13-2007 21:45
    How to connect and unlock w810i ? bankas GOT SEMC 1 04-11-2007 22:37
    how to flash w810i phone kurinay Cruiser Suite 3 10-04-2006 21:03
    How to flash W810i lwilson Cruiser Suite 0 04-05-2006 13:01
    Page generated in 1.26296 seconds with 11 queries
