Sony Ericsson ARM Inside: A3618,R600,T100,T100c,T102,T105,T106,Z200,J200,J200i,J200c, J210,J220,230,Z300 etc. AVR Inside: R520,T200,T202,T226,T226m,T226s,T230,T237,T238,T290,T290a,T290c,T290i, T300,T302,T306,T310,T312,T316,T39,T65,T68,T610,T616,T618,T628,T630,T637,P800,P802, P900,P908,P910,Z600,Z608. New ARM Inside (SEMC):D750,F500,J300,K300,K310,K500,K506c,K508,K510,K600,K608,K610,K700,K750,K790,M600, P990,S700,S710,W300,W550,W600,W700,W800,W810,W900,V600,V630,V800,Z1010,Z300,Z500,Z520,Z530,Z550,Z800. CR 16B Inside:T66,T600,T600c,T602. ODM:J100. C Series: C510, C702, C901, C902, C903, C905
G Series: G502, G705
K Series: K630, K660, K850
T Series: T700, T707, T715
V Series: V640
W Series: W508, W595, W705, W715, W760, W890, W902, W910, W980, W995
Z Series: Z750, Z770, Z780 |
06-19-2010, 21:35 | #1 (permalink) |
Freak Poster Join Date: Sep 2008
Member: 857488 Status: Offline Thanks Meter: 41 | j10i2 unlock problem PHONE STATE: "RETAIL" FLASH CID: 0080 OTP LOCKED:1 CID:80 PAF:1 IMEIk CERT:RED LDR:2010-03-02 18:05 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A096 LDR:2010-03-02 18:06 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A096 Model (from GDFS):J10i2 MAPP CXC article: R7BA076 prg1231-1917_GENERIC_SU MAPP CXC version: R7BA076 Language Package: TELEFONICA-O2 CDA article: 1235-2896 CDA version: R14A Default article: 1229-0655 Default version: R7BA076 PROVIDER: 000-00 SIMLOCKS NOT DETECTED now when i'm trying to unlock it shows problem PHONE STATE: "RETAIL" FLASH CID: 0080 OTP LOCKED:1 CID:80 PAF:1 IMEIk CERT:RED LDR:2010-03-02 18:05 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH SIGNATURE AUTH LDR:2010-03-02 18:06 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM TA [a2_usercode_reset] failed, err:101D [a2_shutdown] can't get ACK Elapsed: 18 secs. plz tell me how to solve this problem |
06-27-2010, 13:14 | #2 (permalink) |
Freak Poster Join Date: Jan 2008
Member: 688725 Status: Offline Thanks Meter: 7 | Hi i am having the same Problem - unlock with Signed, full unlock + disable flash... was no problem. But now Provider: 000-00 SIMLOCKS NOT detected. What to do? - i can't turn phone on with any simcard. RUNNING v 1.08/UNI CARD SERIAL 00085086 USBFLASH DRIVER VERSION 02.02.00.05 SIGNED MODE (USING SERVER) CFG:100011000000 ChipID:F100,EMP protocol:0401 PHONE STATE: "RETAIL" FLASH CID: 0080 OTP LOCKED:1 CID:80 PAF:1 IMEI:kkCERT:RED LDR:2010-03-02 18:05 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH SIGNATURE AUTH LDR:2010-03-02 18:06 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM TA Executing CSCA-based unlock. Checking for signature... signature found, skipping calculation Backup security data... Erasing locks... DISCONNECT PHONE NOW REMOVE SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN INSTALL PHONE MODEM DRIVERS IF NEEDED SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM85 PHONE READY TO PROCEED. GOT SEED:00BE5EF4 ACTIVATION COMPLETED. USERCODE RESET TO "0000" Elapsed: 72 secs. SIGNED MODE (USING SERVER) CFG:100011000000 ChipID:F100,EMP protocol:0401 PHONE STATE: "RETAIL" FLASH CID: 0080 OTP LOCKED:1 CID:80 PAF:1 IMEI:kkCERT:RED LDR:2010-03-02 18:05 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH SIGNATURE AUTH LDR:2010-03-02 18:06 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM TA Executing CSCA-based unlock. Checking for signature... signature found, skipping calculation Backup security data... Erasing locks... DISCONNECT PHONE NOW REMOVE SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN INSTALL PHONE MODEM DRIVERS IF NEEDED SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM85 PHONE READY TO PROCEED. GOT SEED:00DEDF50 ACTIVATION COMPLETED. USERCODE RESET TO "0000" Elapsed: 63 secs. SIGNED MODE (USING SERVER) CFG:100011000000 ChipID:F100,EMP protocol:0401 PHONE STATE: "RETAIL" FLASH CID: 0080 OTP LOCKED:1 CID:80 PAF:1 IMEI:kkCERT:RED LDR:2010-03-02 18:05 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A096 LDR:2010-03-02 18:06 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A096 Model (from GDFS):J10i2 MAPP CXC article: R7BA076 prg1231-1917_GENERIC_SU MAPP CXC version: R7BA076 Language Package: WESTERN-EUROPE CDA article: 1237-6122 CDA version: R3A Default article: 1229-0655 Default version: R7BA076 PROVIDER: 000-00 SIMLOCKS NOT DETECTED SECURITY UNITS BACKUP CREATED. Elapsed: 7 secs. |
The Following User Says Thank You to outbreak198x For This Useful Post: |
06-29-2010, 09:19 | #4 (permalink) |
Crazy Poster Join Date: Oct 2009
Member: 1137885 Status: Offline Thanks Meter: 1 | I have the same problem, i have tried to flash but still provider 000-00 and simlocks not detected but still unable to turn on with any simcard. I have tried signed + full unlock, but i always get a dongle error. I cant try signed + full unlock + disable flash becuase the phone wont work with any sim card. Any advise from someone smarter than me thanks in advance chris |
06-29-2010, 09:55 | #5 (permalink) | |
Member: 1137885 Status: Offline Thanks Meter: 1 | Quote:
06-29-2010, 10:00 | #6 (permalink) | |
No Life Poster Join Date: Jun 2007 Location: Talk to *** and He Will Listen
Member: 532761 Status: Offline Sonork: 100-1592994 Thanks Meter: 1,104 | Quote:
security reset failed. i think its bug or need credit log even it is reset. inshort>no free. | |
06-29-2010, 21:52 | #8 (permalink) |
No Life Poster Join Date: Jun 2006 Location: {JUST@PRAY@FOR@ME} Age: 39
Member: 288504 Status: Offline Sonork: .:100.1587032:. Thanks Meter: 2,266 | in setting tab signed mode, full unlock, disable flash mode activation |
The Following User Says Thank You to roney_nexus For This Useful Post: |
07-04-2010, 10:07 | #12 (permalink) |
Member: 857488 Status: Offline Thanks Meter: 41 | i slove this problem by same procedure..... but now i have one more set but when itry to unlock its give same problem... i think its problm with setool.... i also post this problem in se tool official forum but laser say he dont now about this problem.... so my advice dont try to unlock this set..until new update come or try with any other tool |
01-04-2011, 07:34 | #14 (permalink) |
Major Poster Join Date: Apr 2007 Location: pakistan hazro malhoo dhock
Member: 480068 Status: Offline Sonork: [email protected] Thanks Meter: 3 | pls help sony ericssion j10i2 unlocking problem set is unlock but show is display incorect sim card pppppppppllllllllsssss helpppppppppppp |
01-04-2011, 07:35 | #15 (permalink) |
Member: 480068 Status: Offline Sonork: [email protected] Thanks Meter: 3 | j10i2 unlocking problem with see tool box pls help |
$50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-23-2015 14:21 |
