Sony Ericsson ARM Inside: A3618,R600,T100,T100c,T102,T105,T106,Z200,J200,J200i,J200c, J210,J220,230,Z300 etc. AVR Inside: R520,T200,T202,T226,T226m,T226s,T230,T237,T238,T290,T290a,T290c,T290i, T300,T302,T306,T310,T312,T316,T39,T65,T68,T610,T616,T618,T628,T630,T637,P800,P802, P900,P908,P910,Z600,Z608. New ARM Inside (SEMC):D750,F500,J300,K300,K310,K500,K506c,K508,K510,K600,K608,K610,K700,K750,K790,M600, P990,S700,S710,W300,W550,W600,W700,W800,W810,W900,V600,V630,V800,Z1010,Z300,Z500,Z520,Z530,Z550,Z800. CR 16B Inside:T66,T600,T600c,T602. ODM:J100. C Series: C510, C702, C901, C902, C903, C905
G Series: G502, G705
K Series: K630, K660, K850
T Series: T700, T707, T715
V Series: V640
W Series: W508, W595, W705, W715, W760, W890, W902, W910, W980, W995
Z Series: Z750, Z770, Z780 |
05-26-2009, 13:32 | #1 (permalink) |
No Life Poster Join Date: Sep 2004 Age: 49
Member: 81697 Status: Offline Thanks Meter: 149 | w700 no mic ringer and speaker |
05-26-2009, 16:24 | #3 (permalink) |
Member: 81697 Status: Offline Thanks Meter: 149 | v0.915036/UNI CARD SERIAL: 000000000 Loaded 51 flash descriptors POSSIBLE GDFS FILE DETECTED, EXTRACTING PHONEBOOK PHONEBOOK NOT DETECTED IN GDFS FILE CFG:000000000000000 Will write GDFS now. ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:921600 OTP: LOCKED:1 CID:49 PAF:1 IMEI:35167401391521 CERT:RED LDR:051207 0928 NPACXC1250165_1_SEMC_COMPACTFLASHLOADER R2B Flash ID check:200D Flash props sent ok REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK THEN PRESS "READY" Starting embedded bootloader... INT LDR:COMPACT_ID_LOADER_CRIPPLED_SETOOL2_R2 LDR:041214 0816 LLECXC1326743_COMPACTPRODUCTION R2AB Flash ID check:200D Flash props sent ok FOUND VERSION "R1DB001_CXC1250514_EU_1_CR" Setting up GDFS... will write 986 units done Phone detached Elapsed: 95 secs. v0.915036/UNI CARD SERIAL: 00059786 Loaded 51 flash descriptors POSSIBLE GDFS FILE DETECTED, EXTRACTING PHONEBOOK PHONEBOOK NOT DETECTED IN GDFS FILE CFG:000000000000000 Will write GDFS now. ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:921600 OTP: LOCKED:1 CID:49 PAF:1 IMEI:35167401391521 CERT:RED LDR:051207 0928 NPACXC1250165_1_SEMC_COMPACTFLASHLOADER R2B Flash ID check:200D Flash props sent ok REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK THEN PRESS "READY" Starting embedded bootloader... INT LDR:COMPACT_ID_LOADER_CRIPPLED_SETOOL2_R2 LDR:041214 0816 LLECXC1326743_COMPACTPRODUCTION R2AB Flash ID check:200D Flash props sent ok FOUND VERSION "R1DB001_CXC1250514_EU_1_CR" Setting up GDFS... will write 986 units done Phone detached Elapsed: 95 secs. CFG:000000000000000 ChipID:8040,EMP protocol:0301 OBSOLETE EROM,FORCING COLOR -> RED RED OBSOLETE EROM,FORCING CID -> 49 49 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:921600 Can't load ID loader ! Elapsed: 15 secs. CFG:000000000000000 ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:921600 Flash ID check:200D Flash props sent ok OTP: LOCKED:1 CID:49 PAF:1 IMEI:35167401391521 CERT:RED FLASH CID:49 COLOR:RED IMEI MISMATCH ! GDFS IMEI:35167301113412 Model (from GDFS):W700i Brand:Generic MAPP CXC article: R1CA021 prgCXC1250514_EU_1_CR MAPP CXC version: R1CA021 Language Package: EMEA_1 CDA article: CDA102580/1 CDA version: R1A Default article: cxc1250522 Default version: R1CA021 PROVIDER: 000-00 SIMLOCKS NOT DETECTED USERCODE:0000 RESTORATION FILE NOT PRESENT "R1CA021_CXC1250514_EU_1_CR" YOU MUST PERFORM FULL FLASHING WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED Elapsed: 2 secs. |
05-26-2009, 16:25 | #4 (permalink) |
Member: 81697 Status: Offline Thanks Meter: 149 | v0.915036/UNI CARD SERIAL: 000000000 Loaded 51 flash descriptors POSSIBLE GDFS FILE DETECTED, EXTRACTING PHONEBOOK PHONEBOOK NOT DETECTED IN GDFS FILE CFG:000000000000000 Will write GDFS now. ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:921600 OTP: LOCKED:1 CID:49 PAF:1 IMEI:35167401391521 CERT:RED LDR:051207 0928 NPACXC1250165_1_SEMC_COMPACTFLASHLOADER R2B Flash ID check:200D Flash props sent ok REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK THEN PRESS "READY" Starting embedded bootloader... INT LDR:COMPACT_ID_LOADER_CRIPPLED_SETOOL2_R2 LDR:041214 0816 LLECXC1326743_COMPACTPRODUCTION R2AB Flash ID check:200D Flash props sent ok FOUND VERSION "R1DB001_CXC1250514_EU_1_CR" Setting up GDFS... will write 986 units done Phone detached Elapsed: 95 secs. v0.915036/UNI CARD SERIAL: 00000000 Loaded 51 flash descriptors POSSIBLE GDFS FILE DETECTED, EXTRACTING PHONEBOOK PHONEBOOK NOT DETECTED IN GDFS FILE CFG:000000000000000 Will write GDFS now. ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:921600 OTP: LOCKED:1 CID:49 PAF:1 IMEI:35167401391521 CERT:RED LDR:051207 0928 NPACXC1250165_1_SEMC_COMPACTFLASHLOADER R2B Flash ID check:200D Flash props sent ok REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK THEN PRESS "READY" Starting embedded bootloader... INT LDR:COMPACT_ID_LOADER_CRIPPLED_SETOOL2_R2 LDR:041214 0816 LLECXC1326743_COMPACTPRODUCTION R2AB Flash ID check:200D Flash props sent ok FOUND VERSION "R1DB001_CXC1250514_EU_1_CR" Setting up GDFS... will write 986 units done Phone detached Elapsed: 95 secs. CFG:000000000000000 ChipID:8040,EMP protocol:0301 OBSOLETE EROM,FORCING COLOR -> RED RED OBSOLETE EROM,FORCING CID -> 49 49 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:921600 Can't load ID loader ! Elapsed: 15 secs. CFG:000000000000000 ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:921600 Flash ID check:200D Flash props sent ok OTP: LOCKED:1 CID:49 PAF:1 IMEI:35167401391521 CERT:RED FLASH CID:49 COLOR:RED IMEI MISMATCH ! GDFS IMEI:35167301113412 Model (from GDFS):W700i Brand:Generic MAPP CXC article: R1CA021 prgCXC1250514_EU_1_CR MAPP CXC version: R1CA021 Language Package: EMEA_1 CDA article: CDA102580/1 CDA version: R1A Default article: cxc1250522 Default version: R1CA021 PROVIDER: 000-00 SIMLOCKS NOT DETECTED USERCODE:0000 RESTORATION FILE NOT PRESENT "R1CA021_CXC1250514_EU_1_CR" YOU MUST PERFORM FULL FLASHING WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED Elapsed: 2 secs. |
05-26-2009, 21:56 | #5 (permalink) |
Registered User Join Date: Apr 2007 Location: ==**Syria**== Age: 44
Member: 493205 Status: Offline Sonork: 100.1581647 Thanks Meter: 526 | your phone is imei mismach IMEI MISMATCH ! GDFS IMEI:35167301113412 so try to repair imei and it will be ok just press unlockrepair and select 1-pach otp gdfs chick in firmware 2-allow to chenge imei when unlocking but in first you need to make restoration file -search for restoration file with this name (R1CA021 prgCXC1250514_EU_1_CR) or -add R1CA021 same phone cid and press idintify |
The Following 2 Users Say Thank You to yarra For This Useful Post: |
05-27-2009, 05:21 | #6 (permalink) |
Member: 81697 Status: Offline Thanks Meter: 149 | v0.915036/UNI CARD SERIAL: 00000000 Loaded 51 flash descriptors THAT ACTION IS ILLEGAL,IF YOU DOING IT FOR ANY PURPOSE, OTHER THAN REPAIR PHONE CFG:000000011000000 ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:921600 Flash ID check:200D Flash props sent ok OTP: LOCKED:1 CID:49 PAF:1 IMEI:35167401391521 CERT:RED FLASH CID:49 COLOR:RED IMEI MISMATCH ! GDFS IMEI:35167301113412 Model (from GDFS):W700i Brand:Generic MAPP CXC article: R1CA021 prgCXC1250514_EU_1_CR MAPP CXC version: R1CA021 Language Package: EMEA_1 CDA article: CDA102580/1 CDA version: R1A Default article: cxc1250522 Default version: R1CA021 PROVIDER: 000-00 SIMLOCKS NOT DETECTED USERCODE:0000 SEARCH:\gsm\Flash Files\W700\R1DB001\R1DB001_1250514_EU_1_CR.ssw.cry SEARCH:\gsm\Flash Files\W700\R1DB001\R1DB001_EUROPE_1_fs.ssw.cry RESTORATION FILE NOT PRESENT "R1CA021_CXC1250514_EU_1_CR" YOU MUST PERFORM FULL FLASHING WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED Elapsed: 39 secs. CFG:000000011000000 ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:921600 llbug: blk write fail. fatal Can't load ID loader ! Elapsed: 7 secs. CFG:000000011000000 ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:921600 Flash ID check:200D Flash props sent ok OTP: LOCKED:1 CID:49 PAF:1 IMEI:35167401391521 CERT:RED FLASH CID:49 COLOR:RED IMEI MISMATCH ! GDFS IMEI:35167301113412 Model (from GDFS):W700i Brand:Generic MAPP CXC article: R1CA021 prgCXC1250514_EU_1_CR MAPP CXC version: R1CA021 Language Package: EMEA_1 CDA article: CDA102580/1 CDA version: R1A Default article: cxc1250522 Default version: R1CA021 PROVIDER: 000-00 SIMLOCKS NOT DETECTED USERCODE:0000 SEARCH:\gsm\Flash Files\W700\R1CA021\r1ca021_CXC1250514_EU_1_CR.ssw. cry "R1CA021_CXC1250514_EU_1_CR" CREATED Elapsed: 14 secs. CFG:000000011000000 ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:921600 OTP: LOCKED:1 CID:49 PAF:1 IMEI:35167401391521 CERT:RED LDR:051207 0928 NPACXC1250165_1_SEMC_COMPACTFLASHLOADER R2B Flash ID check:200D Flash props sent ok REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK THEN PRESS "READY" Starting embedded bootloader... INT LDR:COMPACT_ID_LOADER_CRIPPLED_SETOOL2_R2 LDR:041214 0816 LLECXC1326743_COMPACTPRODUCTION R2AB Flash ID check:200D Flash props sent ok FOUND VERSION "R1DB001_CXC1250514_EU_1_CR" Searching... Firmware OTP check determined. Setting up GDFS... IMEI MISMATCH !!!! POSSIBLE STOLEN PHONE !!!!! ORIGINAL IMEI:35167401391521 CURRENT IMEI:35167301113412 "USB" INTERFACE DETECTED AND IMEI IS MISMATCHED USE "COM/UFS" INTERFACE TO REPAIR THAT PROBLEM ! WRITING CLEAR SIMLOCK UNITS... SIGNING... Unlock DONE Elapsed: 93 secs. CFG:000000011000000 ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0049 Speed:921600 Flash ID check:200D Flash props sent ok OTP: LOCKED:1 CID:49 PAF:1 IMEI:35167401391521 CERT:RED FLASH CID:49 COLOR:RED IMEI MISMATCH ! GDFS IMEI:35167301113412 Model (from GDFS):W700i Brand:Generic MAPP CXC article: R1CA021 prgCXC1250514_EU_1_CR MAPP CXC version: R1CA021 Language Package: EMEA_1 CDA article: CDA102580/1 CDA version: R1A Default article: cxc1250522 Default version: R1CA021 PROVIDER: 000-00 SIMLOCKS NOT DETECTED USERCODE:0000 RESTORATION FILE PRESENT FOR DETECTED FIRMWARE Elapsed: 15 secs. |
05-27-2009, 08:51 | #8 (permalink) |
Member: 493205 Status: Offline Sonork: 100.1581647 Thanks Meter: 526 | [QUOTE=linekbp;4505519]when i try to identifyvia com cable it does not identify please tell which option to tick[/QUOT don'nt worry its not problem conntinue...... now you have restoration file so try to repair imei |
05-27-2009, 09:01 | #9 (permalink) |
Member: 81697 Status: Offline Thanks Meter: 149 | v0.915036/UNI CARD SERIAL: 0000000 Loaded 51 flash descriptors Connecting to UFS... Found 2 FTDI device(s). UFS #85134 READY SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED PRELOADER SECURITY BYPASS ENABLED CFG:101110000000000 Unknown ChipID (3F00), RETRY Can't load ID loader ! Elapsed: 4 secs. |
1202 spekar no sound ringer and mic ok so any body help me no sound spekar | alkesh02 | Nokia Hardware & Hardware Repair | 4 | 02-02-2009 20:45 |
1600 ringer and speaker jumper because i loss ringer ic print | pakmobiles | Nokia Hardware & Hardware Repair | 0 | 08-27-2008 19:31 |
1600 ringer and speaker jumper because i loss ringer ic peint | shani72 | Nokia Hardware & Hardware Repair | 5 | 08-21-2008 13:45 |
LG 8120 ringer and speaker problem | Bismillah_mob | LG | 4 | 06-08-2005 20:59 |
6600 low ringer and speaker | goga3000 | Nokia Hardware & Hardware Repair | 1 | 03-06-2005 22:24 |
