Sony Ericsson ARM Inside: A3618,R600,T100,T100c,T102,T105,T106,Z200,J200,J200i,J200c, J210,J220,230,Z300 etc. AVR Inside: R520,T200,T202,T226,T226m,T226s,T230,T237,T238,T290,T290a,T290c,T290i, T300,T302,T306,T310,T312,T316,T39,T65,T68,T610,T616,T618,T628,T630,T637,P800,P802, P900,P908,P910,Z600,Z608. New ARM Inside (SEMC):D750,F500,J300,K300,K310,K500,K506c,K508,K510,K600,K608,K610,K700,K750,K790,M600, P990,S700,S710,W300,W550,W600,W700,W800,W810,W900,V600,V630,V800,Z1010,Z300,Z500,Z520,Z530,Z550,Z800. CR 16B Inside:T66,T600,T600c,T602. ODM:J100. C Series: C510, C702, C901, C902, C903, C905
G Series: G502, G705
K Series: K630, K660, K850
T Series: T700, T707, T715
V Series: V640
W Series: W508, W595, W705, W715, W760, W890, W902, W910, W980, W995
Z Series: Z750, Z770, Z780 |
07-02-2009, 02:17 | #1 (permalink) |
No Life Poster Join Date: May 2006 Location: lucknow
Member: 275643 Status: Offline Thanks Meter: 360 | k510 and w350 problem ? v0.915034/UNI CARD SERIAL: 00093947 Loaded 51 flash descriptors Open COM port OK ChipID:8000,EMP protocol:0000 PHONE STATE: "UNKNOWN" [00000000] SUPPORTED FLASH CID IS NOT DETECTED [0000] skipping empty loader... Can't load ID loader ! Elapsed: 25 secs. Open COM port OK ChipID000,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0053 skipping empty loader... OTP: LOCKED:1 CID:52 PAF:1 IMEI:35438802293760 CERT:RED Model (from GDFS):W350i Brand:Customized MAPP CXC article: R11CA002 prg1204-3117_GENERIC_JH MAPP CXC version: R11CA002 Language Package:S_ASIA_LEVAN CDA article: 1208-7477 CDA version: R3A Default article: 1204-3119 Default version: R11CA002 PROVIDER: 000-00 SIMLOCKS NOT DETECTED RESTORATION FILE NOT PRESENT "R11CA002_1204-3117_GENERIC_JH" YOU MUST PERFORM FULL FLASHING WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED BYPASS PACKAGE PRESENT FOR DETECTED FIRMWARE SECURITY UNITS BACKUP CREATED. Elapsed: 8 secs. Open COM port OK ChipID000,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0053 Speed:921600 OTP: LOCKED:1 CID:52 PAF:1 IMEI:35438802293760 CERT:RED phone CID not supported in that mode Elapsed: 36 secs. plz help me where i wrong ? |
07-02-2009, 02:42 | #2 (permalink) |
No Life Poster Join Date: Feb 2008 Location: Philippines
Member: 696820 Status: Offline Sonork: 100.1684793 Thanks Meter: 269 | mate, phone CID not supported in that mode,....... K510i flashing... go to settings tab.. put check on signed mode and complete phone after flash.... flashing should proceed.... w350i.. you'll be needing "R11CA002_1204-3117_GENERIC_JH" restoration file... if already present.. on the setting tab,, put a check on the first three tab.. eg.. signed mode, enable alternative security bypass, enable preloader security bypass.... don't forget your test card.... br, |
07-02-2009, 02:48 | #3 (permalink) | |
No Life Poster Join Date: Oct 2004 Location: No Location
Member: 87853 Status: Offline Thanks Meter: 1,231 | Quote:
07-02-2009, 02:57 | #4 (permalink) | |
No Life Poster Join Date: Jun 2007 Location: Talk to *** and He Will Listen
Member: 532761 Status: Offline Sonork: 100-1592994 Thanks Meter: 1,104 | Quote:
download same version of rest file then paste into rest folder unlock check 1/2/3 | |
Help : K310 and K510 joystick, keypad problem | Edocomsel | Sony Ericsson Hardware Repair | 41 | 08-23-2013 08:31 |
w350 problem | gunbee | Sony Ericsson | 3 | 01-29-2010 09:43 |
w350 problem | srikanthreddy | SETool2 | 0 | 06-10-2009 17:03 |
Problem with k510 and W300 | bu_ta | Seking Server | 0 | 10-30-2007 08:45 |
"PLEASE WAIT" problem on SE K510 and Z530 | anas9393 | Cruiser Suite | 20 | 08-06-2007 12:43 |
