Sony Ericsson ARM Inside: A3618,R600,T100,T100c,T102,T105,T106,Z200,J200,J200i,J200c, J210,J220,230,Z300 etc. AVR Inside: R520,T200,T202,T226,T226m,T226s,T230,T237,T238,T290,T290a,T290c,T290i, T300,T302,T306,T310,T312,T316,T39,T65,T68,T610,T616,T618,T628,T630,T637,P800,P802, P900,P908,P910,Z600,Z608. New ARM Inside (SEMC):D750,F500,J300,K300,K310,K500,K506c,K508,K510,K600,K608,K610,K700,K750,K790,M600, P990,S700,S710,W300,W550,W600,W700,W800,W810,W900,V600,V630,V800,Z1010,Z300,Z500,Z520,Z530,Z550,Z800. CR 16B Inside:T66,T600,T600c,T602. ODM:J100. C Series: C510, C702, C901, C902, C903, C905
G Series: G502, G705
K Series: K630, K660, K850
T Series: T700, T707, T715
V Series: V640
W Series: W508, W595, W705, W715, W760, W890, W902, W910, W980, W995
Z Series: Z750, Z770, Z780 |
04-29-2009, 08:55 | #1 (permalink) | |
Insane Poster Join Date: Mar 2008
Member: 732895 Status: Offline Sonork: 100.1607266 Thanks Meter: 5 | K550i Flash says : verify block error 01, [45E90000/00010000] Quote:
05-02-2009, 07:09 | #2 (permalink) |
Junior Member Join Date: Mar 2008
Member: 718768 Status: Offline Thanks Meter: 4 | usually that means for a bad flash ic or a loss connection between cpu and flash ic. if can do change flash ic, change it first and reflash the phone whith test point, gdfs, erom and full flash |
05-04-2009, 12:29 | #5 (permalink) | |
Super Moderator Join Date: Aug 2005 Location: UK.... Age: 57
Member: 173077 Status: Offline Sonork: 100.1594293 Thanks Meter: 2,784 | Quote:
There are a few possible causses for red Flash, corrupt security, bad erom, Bad Flash, You will need Hardware box to repair this ,, Cruiser/Setool.. | |
01-29-2010, 03:45 | #9 (permalink) |
Freak Poster Join Date: Sep 2005 Age: 51
Member: 182513 Status: Offline Thanks Meter: 26 | SSW uses dynamic hash, dynamic hash len is: 2 HDR block not accepted,error: 19 Elapsed: 9 secs. SIGNED MODE (USING SERVER) CFG:100000000000 RESET MODE STARTED ChipID:9900,EMP protocol:0301 Speed:921600 can't get packet start. Elapsed: 32 secs. SIGNED MODE (USING SERVER) CFG:100000000000 ChipID:9900,EMP protocol:0301 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35665701010321 CERT:N/A FLASH CID:53 COLOR:RED PATCH:071120 1355 HANCXC9876543210_DB2020_MEM_PATCHER_R2A012 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 FLASH ID:897E writing "C:\Documents and Settings\SKCC\Desktop\setool\gdfs_in_ssw_format\db 2020\k550_gdfs_SSW.ssw" CURRENT FLASH FILE CID:49 SSW uses full hash, hash len is: 640 HDR block not accepted,error: 19 Elapsed: 11 secs. |
01-29-2010, 03:47 | #11 (permalink) |
Member: 182513 Status: Offline Thanks Meter: 26 | SIGNED MODE (USING SERVER) CFG:100000100000 ChipID:9900,EMP protocol:0301 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35665701010321 CERT:N/A FLASH CID:53 COLOR:RED PATCH:071120 1355 HANCXC9876543210_DB2020_MEM_PATCHER_R2A012 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 FLASH ID:897E writing "C:\Documents and Settings\SKCC\Desktop\setool\gdfs_in_ssw_format\db 2020\k550_gdfs_SSW.ssw" CURRENT FLASH FILE CID:49 SSW uses full hash, hash len is: 640 HDR block not accepted,error: 19 Elapsed: 14 secs. |
K800i Flashing problem verify block error 01 ? help plz | pakstar | SETool2 | 12 | 01-05-2010 06:00 |
verify block error 68/01, [44950000/00010000] | kapilgupta | Sony Ericsson Hardware Repair | 0 | 08-29-2009 14:41 |
verify block error on w300 | nost | SETool2 | 0 | 12-13-2007 18:48 |
in V3r reading LP procces fone say : Critical error 40 80 | matin-gsm | Smart-Clip | 5 | 07-17-2007 13:34 |
hi I build a jdm programmer but icprog1.03 says always verify faild at 000h | surfer2go | Hardware Equipments for GSM | 2 | 07-13-2002 05:08 |
