-   Sony Ericsson (http://forum.gsmhosting.com/vbb/f84/)
-   -   K608i Cant Connect to USB-Smart or...... (http://forum.gsmhosting.com/vbb/f84/k608i-cant-connect-usb-smart-338635/)
thcoms 10-07-2006 15:13
Got this K608i here to unlock which will not connect to USB-Smart or UFS, I have been trying for about an hour now but still no luck, the battery is fully charged etc.
Anybody got any solution or tricks on how to get it connected.
thcoms
ivanrommel 10-07-2006 15:20
try to use cruiser 100% ok
James-R 10-07-2006 15:26
good post!
check/change charging block and/or try to connect via testpoint.
br
thcoms 10-07-2006 17:55
I dont have Cruiser so I will try & change the charging block.
Tha phone will charge without any problems so I dont think a new charging block will work, perhaps testpoint.
thcoms
James-R 10-07-2006 19:48
thcoms
the charging block contains the rx/tx connections aswel as the charging connections. hence even if it still charges there can still be a problem with the rx/tx lines.
remove the charging block and check the pads where the block touches the pcb.
if the phone works fine but you cannot connect to it then is must be a problem somewhere on the rx/tx lines or the flash chip itself.
if you have a scope you can check for commucations pulses at different places and see where its lost.
br
irfan99 10-08-2006 13:05
hi
use 4.8 volt with usb smart and it will be ok
thcoms 10-08-2006 16:02
& how do I connect a 4.8V to a cable?
thcoms
debster chipili 10-10-2006 18:01
K608i Dead After Unlock Solution
People Plizz Can Anyone Help Me With With K608i Flash File For Se-tool. Pliz Pliz Am On My Knees. customer will kiil me.
c_ahmad79 10-10-2006 18:45
i am not a se-toll user... but i can assure you can use the k600 flash file for this.................. and you also can find the falsh file on support site....
luzer 10-10-2006 20:08
Post the full log ... all files can be downloaded without any problem from support.
nnaeem11 10-10-2006 20:28
just change the sosftware ver of unlock program
i know it happen a allot to me when i newly use the sonyericsson unlocking just what u have to do is change the current version u r using to other older or much newer version and just unlock it again its the simple solution to my working.
NAEEM FAROOQUI.
nnaeem11 10-10-2006 20:35
make sure u can connect other phone to Unlocker
thcoms
member,
i m using this unlocking long time a go just check u can connect other SEMC mobile to the software coz some time our system memory is running some thing that is breaking the connection to mobile phone and it says error could not connect, no phone found, phone didn't power up like this.
press Ctrl + Alt + Del and stop every thing u know that is not working with the system currently and then try to open the software again and it will give u joy.
NAEEM FAROOQUI.
Page generated in 0.25076 seconds with 5 queries
