Sony Ericsson ARM Inside: A3618,R600,T100,T100c,T102,T105,T106,Z200,J200,J200i,J200c, J210,J220,230,Z300 etc. AVR Inside: R520,T200,T202,T226,T226m,T226s,T230,T237,T238,T290,T290a,T290c,T290i, T300,T302,T306,T310,T312,T316,T39,T65,T68,T610,T616,T618,T628,T630,T637,P800,P802, P900,P908,P910,Z600,Z608. New ARM Inside (SEMC):D750,F500,J300,K300,K310,K500,K506c,K508,K510,K600,K608,K610,K700,K750,K790,M600, P990,S700,S710,W300,W550,W600,W700,W800,W810,W900,V600,V630,V800,Z1010,Z300,Z500,Z520,Z530,Z550,Z800. CR 16B Inside:T66,T600,T600c,T602. ODM:J100. C Series: C510, C702, C901, C902, C903, C905
G Series: G502, G705
K Series: K630, K660, K850
T Series: T700, T707, T715
V Series: V640
W Series: W508, W595, W705, W715, W760, W890, W902, W910, W980, W995
Z Series: Z750, Z770, Z780 |
06-16-2005, 11:03 | #1 (permalink) |
Freak Poster Join Date: Jun 2003 Location: Dosunlock Age: 38
Member: 31942 Status: Offline Thanks Meter: 42 | k700 hang on startup when with sim solution! |
06-16-2005, 13:31 | #3 (permalink) |
Member: 31942 Status: Offline Thanks Meter: 42 | yup. the result is no bluetooth at least its a temporary solution of the problem until ul find a replacement part. the bluetooth ic is the cause of the hang. |
12-05-2005, 12:04 | #8 (permalink) |
No Life Poster Join Date: Mar 2005 Location: Sahiwal Punjab , Pakistan
Member: 123133 Status: Offline Sonork: 100.999 Thanks Meter: 911 | very very bad solutions this is software problem.. just use sonics cracked..flash the phone and click on k700i freeze option ..after unlock it.set will oki. no need to any kind of hardware... Br Kuku |
12-12-2005, 12:08 | #10 (permalink) |
Junior Member Join Date: Mar 2004 Location: brasov Age: 45
Member: 58043 Status: Offline Thanks Meter: 0 | so, this is an old thread, is there any solution? I also have k700 that hangs on language selection menu. It isn't hardware problem because it apeared after unsuccesfull unlocking (till now i haven't heard of hardware damage after unlock). I used setool and flashed al firmwares availble and no succes. Here's the story: 1. flashed main+ fs......writtes both file and when making "complete phone goes like this failed to load CERTLOADERS,try to use RECOVERY. Phone starts in "contact service operator..." 2. press recovery, reflash main+ fs......uselless we go back to step 1 3. press recovery, flash only main firmware.....write flash ok, phone doesn't start. Press "complet phone" phone starts and hangs on language menu selection 4. write gdfs, unlock after that....same problem 5. empty fill phone....phone hangs on lang....it can't upload otp imei 6. It is for sure problem from with gdfs....write gdfs same problem.....is there any solution? The thread was launched 6 months ago, i hope there is a solution to use this phone again. Waiting for help..... |
12-12-2005, 15:03 | #11 (permalink) | |
Freak Poster Join Date: Mar 2002 Location: SWEDEN, Malmoe Age: 45
Member: 10228 Status: Offline Thanks Meter: 2 | Quote:
Or download mine: K700eeprom_fix_flash_as_main_without_complete.rar | |
12-12-2005, 15:25 | #12 (permalink) |
No Life Poster Join Date: Nov 2001 Location: England Age: 41
Member: 7653 Status: Offline Thanks Meter: 823 | i use cruiser, best tool for SE: 1/ format GDFS 2/ write a new GDFS from support 3/ flash main 4/ flash FS 5/ convert to brown 6/ direct unlock 7/ remake all CRC 8/ convert to red 9/ customise FS. 100% solution to all software related hang at startup, white screen or no network . |
12-12-2005, 16:16 | #13 (permalink) |
Member: 58043 Status: Offline Thanks Meter: 0 | i only have setool and the solution with set to brown, remake CRC i don't have and the solution with eeprom also didn't work. Maybe the phone really broke although i don't know how this could be posible. I worked 3 days on this phone, it's time to say stop. Thanks for the help anyway Last edited by petess98; 12-13-2005 at 09:06. |
02-01-2006, 15:11 | #15 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Philippines
Member: 218941 Status: Offline Thanks Meter: 1,801 | ans.. you have to try before post solution.. were all suffered....any body can help us...will give honor...MASTERS INVITED HERE TO SHARE THIER SECRETS.. |
E200 hang on Boot screen with sim | xim360 | Samsung Hardware Repair | 2 | 10-07-2010 14:15 |
K700 Hang On Startup | alamgarh | Sony Ericsson | 11 | 09-04-2008 14:38 |
K700i hang on startup with SIM card | gurinder | Sony Ericsson | 1 | 05-10-2007 09:49 |
x640 hang on startup any solution??? | fredi | Samsung Hardware Repair | 0 | 08-02-2006 13:45 |
k700 hang on startup | johnny_liang | SonyEricsson (USB-Smart) | 17 | 04-01-2006 02:16 |
