K750i white screen please help Hi I have a k750i when I switch it on it vibrates then only white screen Details from usb smart: Switch phone ON Get phone info Flash CID: 36 Phone KEY: A1_DB2010_36_RED OTP CID: 36 Phone IMEI: 3565530015xxxx Flash ID: 200D Switch phone ON Send GDFS application Convert to BROWN Switch phone ON Send GDFS application Clear all SP locks Convert back to RED Operation succesfull I flashed it with w800i software no luck, then with k750i repair K750_R1N035_CID36_FullRepairFlash.mbn But still white screen :( Could you please advise wich flash files to select please Thanks |
maybe a waterdamage ? have you complte the phone ? |
Rapair flash by Cruiser Cruiser working %% for this problem in sonyEricsson Br. Wawe |
Completed no problem, I only have usb smart :( There is no sign of water damage and I changed the screen just to make sure. It's the good flash file I am missing!! which one!!:confused: Quote:
did you repair crc and sp locks,write eeprom and erom.i usually do this with se phones that have white screen. |
hi you used usb-smatr repar file & sp lock . |
have you tried with ufsxhwk |
Thanks for your help brothers It was repaired with cruiser, my advise is buy a cruiser ;) But sometimes when you change the lcd screen it's hardware not software ( not all lcd screens fit because they have different versions) Keep up the good work:p Quote:
how to repir k-750 1 Attachment(s) how to repir k-750 this is my tested |
Hi I tried it but software did not ask for test point (usb smart v8.6) wich version did you use. Now I have an other K750i whith white screen!!! but it plays music when you press the play botton, wierd :confused: I changed the screen but no luck:( . The only thing I did was flash main and Fs with w800i then complete, it worked one day the and the day after white screen!! Quote:
