Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| Sony Ericsson ARM Inside: A3618,R600,T100,T100c,T102,T105,T106,Z200,J200,J200i,J200c, J210,J220,230,Z300 etc. AVR Inside: R520,T200,T202,T226,T226m,T226s,T230,T237,T238,T290,T290a,T290c,T290i, T300,T302,T306,T310,T312,T316,T39,T65,T68,T610,T616,T618,T628,T630,T637,P800,P802, P900,P908,P910,Z600,Z608. New ARM Inside (SEMC):D750,F500,J300,K300,K310,K500,K506c,K508,K510,K600,K608,K610,K700,K750,K790,M600, P990,S700,S710,W300,W550,W600,W700,W800,W810,W900,V600,V630,V800,Z1010,Z300,Z500,Z520,Z530,Z550,Z800. CR 16B Inside:T66,T600,T600c,T602. ODM:J100. C Series: C510, C702, C901, C902, C903, C905
G Series: G502, G705
K Series: K630, K660, K850
T Series: T700, T707, T715
V Series: V640
W Series: W508, W595, W705, W715, W760, W890, W902, W910, W980, W995
Z Series: Z750, Z770, Z780 |
| | #1 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2006 Location: india
Member: 239168 Status: Offline Thanks: 2
| k800 5 locks closed-imei mismatch also-how repair? i have a k800i insert correct card-five locks closed and imei mismatch also-details as below CFG:100000000000 ChipID:9900,EMP protocol:0301 Speed:921600 FLASH ID:897E OTP: LOCKED:1 CID:51 PAF:1 IMEI:35908801566811 CERT:N/A FLASH CID:52 COLOR:RED IMEI MISMATCH ! GDFS IMEI:35471601808414 Model (from GDFS):K800i Brand:Generic MAPP CXC article: R8BA024 prgCXC1250210_GENERIC_WI MAPP CXC version: R8BA024 Language Package: APAC CDA article: CDA102511/2 CDA version: R2A Default article: cxc1250490 Default version: R8BA024 PROVIDER: 000-00 SIMLOCKS NOT DETECTED RESTORATION FILE PRESENT FOR DETECTED FIRMWARE BYPASS PACKAGE PRESENT FOR DETECTED FIRMWARE Elapsed: 6 secs. how repair ? |
| | #3 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jun 2007 Location: Talk to *** and He Will Listen
Member: 532761 Status: Offline Sonork: 100-1592994 Thanks: 1,695
| Due to unlocking problem right! If yes try restore back up be sure same iMEI and unlock again |
| | #8 (permalink) | |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2008 Location: RVIII
Member: 890926 Status: Offline Thanks: 93
| Quote:
Br, xerraco | |
| | #10 (permalink) | |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jun 2006 Location: {JUST@PRAY@FOR@ME} Age: 28
Member: 288504 Status: Offline Sonork: .:100.1587032:. Thanks: 258
| Quote:
u can full unlock it i hope pb solved......... 1. select com/ufs/usb as interface 2. go to semc tab 3. select correct model 4. on settings tab, check "signed mode","do full unlock instead usercode reset" 5. back on semc tab 6. press unlock button that is recommended method for unlocking such phones. you can not repair damaged SCRC via that method. NOTE-must be 1 credit not free..... thx..... | |
| | #11 (permalink) | |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Mar 2010
Member: 1257171 Status: Offline Thanks: 78
| Quote:
use setool2 ver 1.01 and go setting and click server mode b4 recovery click ur problem 100% solved Brother http://www.2shared.com/file/IrxOSCnl/gdfs_ok.html Last edited by FaHaD_DePaR; 05-11-2010 at 10:08. | |
| | #12 (permalink) |
| Insane Poster ![]() ![]() ![]() Join Date: Mar 2008 Location: Robinson's Metro,Philippines
Member: 719577 Status: Offline Thanks: 31
| imei mismatch usually occurs if you use reset method, and flash gdfs and erom in setab. To fix, just follow correct method. with signed mode in settings, click recovery in setab (choose correct model) If phone successfuly changed to brown state, Go to empty fill tab, flash correct gdfs and erom. Phone should be ok now, unlocked and imei ok. Goodluck |
| The Following User Says Thank You to harungaz For This Useful Post: |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| k800 5 locks close | vjn.com | Universalbox | 9 | 01-26-2010 14:11 |
| I have k800 cid53 whith ( 5 lock closed ) can i unlock that phone free ? how much cri | waseem pirmahal | Sony Ericsson | 12 | 11-29-2009 15:33 |
| k800 5 locks closed please help | mzsufi | Seking Server | 3 | 11-18-2009 05:22 |
| k800 5 lock close | .Wise Solution | Universalbox | 4 | 12-31-2008 19:42 |
| k800 after repair tp 5 lock closed | Mohsin-* | SETool2 | 10 | 08-02-2008 14:37 |
