Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Ericsson
Sony Ericsson
  • ARM Inside: A3618,R600,T100,T100c,T102,T105,T106,Z200,J200,J200i,J200c, J210,J220,230,Z300 etc.
  • AVR Inside: R520,T200,T202,T226,T226m,T226s,T230,T237,T238,T290,T290a,T290c,T290i, T300,T302,T306,T310,T312,T316,T39,T65,T68,T610,T616,T618,T628,T630,T637,P800,P802, P900,P908,P910,Z600,Z608.
  • New ARM Inside (SEMC):D750,F500,J300,K300,K310,K500,K506c,K508,K510,K600,K608,K610,K700,K750,K790,M600, P990,S700,S710,W300,W550,W600,W700,W800,W810,W900,V600,V630,V800,Z1010,Z300,Z500,Z520,Z530,Z550,Z800.
  • CR 16B Inside:T66,T600,T600c,T602.
  • ODM:J100.
  • C Series: C510, C702, C901, C902, C903, C905
  • G Series: G502, G705
  • K Series: K630, K660, K850
  • T Series: T700, T707, T715
  • V Series: V640
  • W Series: W508, W595, W705, W715, W760, W890, W902, W910, W980, W995
  • Z Series: Z750, Z770, Z780
  • Reply
    Old 03-03-2008, 20:43   #1 (permalink)
    jtg
    Member: 24754
    Thanks Meter: 2
    Question k800i flash recovery?
    I have a k800i which has been messed about with, and needs repaired. K810i firmware has been written to the phone and also a gdfs from another phone.
    Now i have received the phone, only red led when powered on. Only boots when 2+5 are pressed. C doesn't boot phone. There is no backup gdfs file available, and i have tried repair erom but doesn't fix the problem. I have several different hardware tools which i can use to repair the phone.
    Could someone post a method that i can follow which will restore the k800i?
    Or is it bricked?
    Thanks
    JTG
    Old 03-03-2008, 20:50   #2 (permalink)
    reactos's Avatar
    Member: 323137
    Thanks Meter: 234
    Or is it bricked?
    Thanks
    JTG
    se dreambox is the tool you should get
    Old 03-09-2008, 04:04   #3 (permalink)
    Member: 146369
    Thanks Meter: 118
    Maybe, but TP is below flash IC...
    The correct solution would be to change flash ic and do empty fill procedure... It is far easier than doing TP...
    There is not any software that will fix your phone with out GDFS backup/sec units
    Wbr
    Old 05-27-2008, 13:15   #4 (permalink)
    mkwatis's Avatar
    Member: 22893
    Sonork: 100.1607086
    Thanks Meter: 129
    @Crazy_ratata;
    On this problem can i use se tool lite?how screenshot please
    Can i replace k800i flash from another k800i? zonetrichur SETool2 4 03-01-2009 15:57
    k800i data recovery jusdal Sony Ericsson Hardware Repair 4 05-20-2008 21:28
    lg 8120 flash recovery failed Ped HWK 1 09-14-2005 10:31
    LG FLash RECOVERY usernome HWK 0 09-13-2005 11:03
    How to flash recovery file to phone ??? drag Cruiser Suite 1 11-08-2004 19:09
    Page generated in 0.42091 seconds with 8 queries
