Sony Ericsson ARM Inside: A3618,R600,T100,T100c,T102,T105,T106,Z200,J200,J200i,J200c, J210,J220,230,Z300 etc. AVR Inside: R520,T200,T202,T226,T226m,T226s,T230,T237,T238,T290,T290a,T290c,T290i, T300,T302,T306,T310,T312,T316,T39,T65,T68,T610,T616,T618,T628,T630,T637,P800,P802, P900,P908,P910,Z600,Z608. New ARM Inside (SEMC):D750,F500,J300,K300,K310,K500,K506c,K508,K510,K600,K608,K610,K700,K750,K790,M600, P990,S700,S710,W300,W550,W600,W700,W800,W810,W900,V600,V630,V800,Z1010,Z300,Z500,Z520,Z530,Z550,Z800. CR 16B Inside:T66,T600,T600c,T602. ODM:J100. C Series: C510, C702, C901, C902, C903, C905
G Series: G502, G705
K Series: K630, K660, K850
T Series: T700, T707, T715
V Series: V640
W Series: W508, W595, W705, W715, W760, W890, W902, W910, W980, W995
Z Series: Z750, Z770, Z780 |
04-13-2010, 10:49 | #1 (permalink) |
Junior Member Join Date: Mar 2010
Member: 1254811 Status: Offline Sonork: abrarmultani Thanks Meter: 3 | k800i network lock plz help CARD SERIAL: 00057351 Loaded 51 flash descriptors SIGNED MODE (USING SERVER) PROCEDURE WAS STOPPED BY USER Can't load ID loader ! Elapsed: 12 secs. SIGNED MODE (USING SERVER) ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0052 Speed:921600 Flash ID check:897E Flash props sent ok OTP: LOCKED:1 CID:51 PAF:1 IMEI:35731501157990 CERT:RED FLASH CID:52 COLOR:RED Model:K800i Brand:Generic MAPP CXC article: R1KG001 prgCXC1250210_GENERIC_WI MAPP CXC version: R1KG001 Language Package:APAC CDA article: CDA102511/2 CDA version: R2A Default article: cxc1250490 Default version: R1KG001 PROVIDER: 000-00 Network LOCKED RESTORATION FILE NOT PRESENT "R1KG001_CXC1250210_GENERIC_WI" YOU MUST PERFORM FULL FLASHING WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED BYPASS PACKAGE PRESENT FOR DETECTED FIRMWARE SECURITY UNITS BACKUP CREATED. Elapsed: 7 secs. plz help? |
04-13-2010, 11:58 | #2 (permalink) |
No Life Poster Join Date: Jun 2006 Location: {JUST@PRAY@FOR@ME} Age: 39
Member: 288504 Status: Offline Sonork: .:100.1587032:. Thanks Meter: 2,266 | CID 50,51,52,53 standalone patch unlock method via alternative security bypass 1. select com/ufs/usb as interface 2. go to semc tab 3. select correct model 4. on settings tab, check "signed mode","alternative security bypass", "preloader security bypass" 5. back on semc tab 6. press unlock button you can not use that method , if SCRC damaged ( IMEI mismatch in IDENTIFY output ) restoration files required for that method. bypass packages required for that method. please read FAQ post about alternative security bypass. |
Help: Forgot my 6110 user lock code!! | GByte9 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 02-26-2016 14:52 |
SP Lock 1&4 | dw | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 11 | 06-26-1999 06:22 |
