Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| Sony Ericsson ARM Inside: A3618,R600,T100,T100c,T102,T105,T106,Z200,J200,J200i,J200c, J210,J220,230,Z300 etc. AVR Inside: R520,T200,T202,T226,T226m,T226s,T230,T237,T238,T290,T290a,T290c,T290i, T300,T302,T306,T310,T312,T316,T39,T65,T68,T610,T616,T618,T628,T630,T637,P800,P802, P900,P908,P910,Z600,Z608. New ARM Inside (SEMC):D750,F500,J300,K300,K310,K500,K506c,K508,K510,K600,K608,K610,K700,K750,K790,M600, P990,S700,S710,W300,W550,W600,W700,W800,W810,W900,V600,V630,V800,Z1010,Z300,Z500,Z520,Z530,Z550,Z800. CR 16B Inside:T66,T600,T600c,T602. ODM:J100. C Series: C510, C702, C901, C902, C903, C905
G Series: G502, G705
K Series: K630, K660, K850
T Series: T700, T707, T715
V Series: V640
W Series: W508, W595, W705, W715, W760, W890, W902, W910, W980, W995
Z Series: Z750, Z770, Z780 |
| | #1 (permalink) |
| Junior Member Join Date: Jun 2005 Age: 31
Member: 154602 Status: Offline Thanks: 0
| K800i red IR LED blinking, cant start phone. Hello. I have got a problem with my K800i. The led next to IR port is blinking red 6 times when i try to start the phone or connect the charger / DC-60 cabel. I have searched everywhere for a solution and i found a lot of different methods of fixing this problem. It seems that the EPROM needs to be repaired however i can't do this since Windows does not find the phone when i plug it in with the DC-60 cable. I believe i can get this to work if only windows would find the phone. I have tried everything i can think of. Fully charged battery, 2+5 or C, different DC-60 cables, Shorting the battery, Different PCs, All kinds of software like Wotanclient, SETool, XS++ among others but none of them works since windows will not install the flash drivers when i plug in the phone. Have anyone else had this problem? The problem occured when i removed the battery while the phone was still on. Ever since i haven't been able to start the phone. Please share your knowledge with me. Regards /Cole |
| | #2 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Aug 2001 Location: Roma Age: 39
Member: 5926 Status: Online Thanks: 135
| Use F-bus serial cable instead usb cable, on usb serial comport (serial interface, will communicate with pc) after repair erom will also communicate on usb mode. repaired dousines of them (2020) BR Rak|m |
| | #3 (permalink) |
| Super Moderator ![]() Join Date: Aug 2005 Location: UK.. Age: 47
Member: 173077 Status: Offline Sonork: 100.1594293 Thanks: 0
| if software will not reconise the phone, connect the **PHONES** battery terminals the Wrong way Round for a couple of seconds, so - to + and + to -. this does work...... you will need tiny pieces of wire, or if you have UBlight, use the TP cable supplyed with that instead.. Then you will be able to work on phone, IE,, flash or repair Erom. |
| | #4 (permalink) | |
| Quote:
Thanks though. | |
| | #7 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2006 Location: INDIA,TAMILNADU,PATTUKKOTTAI
Member: 304090 Status: Offline Thanks: 201
| Did u try... 2+5 key combnation (press&hold) when conecting phone? |
| The Following User Says Thank You to aikonmani For This Useful Post: |
| | #9 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: May 2008 Location: kampala, uganda. East Africa
Member: 770206 Status: Offline Sonork: Eed07 Thanks: 2
| K800i red IR LED blinking, cant start phone. Yeah, think am in the rite place, koz i have the same problem. K800i blink at its IR port, tried repair erome. "failed" same thing with W850i, white blinking screen. repair failed, flashing wasnt a prob. But still failed. ANy solution is kindly appreciated. Thnx Eed07 |
| | #10 (permalink) | |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: May 2005
Member: 143889 Status: Offline Sonork: 100.1584685 Thanks: 217
| Quote:
| | #11 (permalink) |
| Junior Member Join Date: Sep 2008
Member: 873318 Status: Offline Thanks: 0
| did you every get this to work, because i have the same problem on my K800i, i tried everything but it still has the 6 IR flash. please tell me how you did yours. thanks |
| | #12 (permalink) |
| some time back i was looking for a possible solution to that same problem. But as i was online some guy talked about changing the erom IC, of which i dont know how it even looks like or where its located on the k800i motherboard. so has any body tried it out, please post here |
| | #13 (permalink) |
| Junior Member ![]() ![]() Join Date: Mar 2008
Member: 727935 Status: Offline Thanks: 89
| I have a set k800 I connect it to se tool by pressing 2+5. and flashed it.but it still red blinking and when i click identify in se tool it does not shows full information. only shows gdfs startup failed it. what should i do? thanks |
| | #14 (permalink) |
| Junior Member ![]() ![]() Join Date: Oct 2008
Member: 878116 Status: Offline Thanks: 10
| With test poin Your troubleshoot is finished or change flash ic =====> write gdfs in ssw format, write errom, write otp imei unlock and flassshing normal enjoy.........test by me work 100% |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| K800i Red Led blinking?? | byteforce | D-Unlock Suite | 0 | 07-07-2009 08:29 |
| K800i red led blink | zdrx69 | Sony Ericsson Hardware Repair Area | 36 | 03-11-2009 03:13 |
| k800i red led unbootable by any box | momayaz | Sony Ericsson Hardware Repair Area | 1 | 02-22-2007 10:20 |
| w850i Red LED blinking - phone dead. | Mobileforce | Cruiser Suite | 5 | 12-30-2006 22:44 |
| Z200 red LED blinks | gsmgsa | Sony Ericsson Hardware Repair Area | 3 | 10-27-2005 16:06 |
