Sony Ericsson ARM Inside: A3618,R600,T100,T100c,T102,T105,T106,Z200,J200,J200i,J200c, J210,J220,230,Z300 etc. AVR Inside: R520,T200,T202,T226,T226m,T226s,T230,T237,T238,T290,T290a,T290c,T290i, T300,T302,T306,T310,T312,T316,T39,T65,T68,T610,T616,T618,T628,T630,T637,P800,P802, P900,P908,P910,Z600,Z608. New ARM Inside (SEMC):D750,F500,J300,K300,K310,K500,K506c,K508,K510,K600,K608,K610,K700,K750,K790,M600, P990,S700,S710,W300,W550,W600,W700,W800,W810,W900,V600,V630,V800,Z1010,Z300,Z500,Z520,Z530,Z550,Z800. CR 16B Inside:T66,T600,T600c,T602. ODM:J100. C Series: C510, C702, C901, C902, C903, C905
G Series: G502, G705
K Series: K630, K660, K850
T Series: T700, T707, T715
V Series: V640
W Series: W508, W595, W705, W715, W760, W890, W902, W910, W980, W995
Z Series: Z750, Z770, Z780 |
10-03-2008, 09:18 | #1 (permalink) |
Freak Poster Join Date: May 2008 Location: kampala, uganda. East Africa
Member: 770206 Status: Offline Sonork: Eed07 Thanks Meter: 23 | K800i Send superblock command NAK SERVER SUPPORT ENABLED. ALTERNATIVE SECURITY BYPASS ENABLED. ChipID:9900,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:52 Speed:921600 OTP LOCKED:1 CID:49 PAF:1 IMEI:************** CERT:RED FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:897E Flash props sent ok CID52 BYPASS PROCEDURE STARTED Processing part1... Processing part2... Processing part3.... OTP LOCKED:1 CID:49 PAF:1 IMEI:*************** CERT:RED FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:897E Flash props sent ok Send superblock command NAK CID52 BYPASS PROCEDURE FINISHED |
10-04-2008, 09:01 | #3 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Make Sure Battery is fully charge untick alternative bypass tick Signed CSCA Server & tick Complete Phone after flash than try to flash ....! B.R. ALi |
10-06-2008, 08:22 | #5 (permalink) |
Member: 770206 Status: Offline Sonork: Eed07 Thanks Meter: 23 | yeah have done it with different batteries which i dont think they are empty, but still the same problem. what do you maen by power supply??? |
k510 can,t flashed message is comming"Send superblock command NAK" | pakmobiles | SETool2 | 2 | 05-08-2009 04:36 |
k310 Send Superblock command NAK | khalidsng | Sony Ericsson Hardware Repair | 2 | 12-25-2008 05:57 |
k310 Send Superblock command NAK | khalidsng | Sony Ericsson Hardware Repair | 3 | 12-07-2008 13:26 |
Need HELP K790i flashing | "Send superblock command NAK" | galerinisan | SETool2 | 3 | 05-29-2008 10:06 |
Send superblock command NAK ? | Prestonlad2005 | Sony Ericsson Hardware Repair | 3 | 06-08-2007 02:35 |
