Sony Ericsson ARM Inside: A3618,R600,T100,T100c,T102,T105,T106,Z200,J200,J200i,J200c, J210,J220,230,Z300 etc. AVR Inside: R520,T200,T202,T226,T226m,T226s,T230,T237,T238,T290,T290a,T290c,T290i, T300,T302,T306,T310,T312,T316,T39,T65,T68,T610,T616,T618,T628,T630,T637,P800,P802, P900,P908,P910,Z600,Z608. New ARM Inside (SEMC):D750,F500,J300,K300,K310,K500,K506c,K508,K510,K600,K608,K610,K700,K750,K790,M600, P990,S700,S710,W300,W550,W600,W700,W800,W810,W900,V600,V630,V800,Z1010,Z300,Z500,Z520,Z530,Z550,Z800. CR 16B Inside:T66,T600,T600c,T602. ODM:J100. C Series: C510, C702, C901, C902, C903, C905
G Series: G502, G705
K Series: K630, K660, K850
T Series: T700, T707, T715
V Series: V640
W Series: W508, W595, W705, W715, W760, W890, W902, W910, W980, W995
Z Series: Z750, Z770, Z780 |
03-25-2010, 12:19 | #1 (permalink) |
Freak Poster Join Date: Sep 2006 Age: 41
Member: 343227 Status: Offline Thanks Meter: 22 | K810i no power/GDFS corrupted done via SE TOOL Code: RUNNING v0.915060/UNI CARD SERIAL taliktik02 USBFLASH DRIVER VERSION 02.02.00.05 SIGNED MODE (USING SERVER) CFG:100000000000 ChipID:9900,EMP protocol:0301 BOOTROM MODE DETECTED Speed:921600 FLASH ID:897E OTP: LOCKED:1 CID:51 PAF:1 IMEI:3579taliktik02 CERT:N/A FLASH CID:52 COLOR:RED can't get packet start. packet not acknowledged (17) setGDFS_params failed failed to setup GDFS Elapsed: 68 secs. Code: SIGNED MODE (USING SERVER) CFG:100100000000 ChipID:9900,EMP protocol:0301 BOOTROM MODE DETECTED Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:3579taliktik02 CERT:N/A FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 FLASH ID:897E writing "D:\installer\Cellphone apps\v0_915060\k810i\R8BF003_CXC1250811_SM_RED_CID52.software" CURRENT FLASH FILE CID:52 SSW uses full hash, hash len is: 9200 Will flash 460 blocks... writing "D:\installer\Cellphone apps\v0_915060\k810i\R8BF003_FS_S_E_EUROPE_SM_RED_CID52.software" CURRENT FLASH FILE CID:52 SSW uses full hash, hash len is: 4580 Will flash 229 blocks... LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 GDFS startup failed,error is 04 [1D] loader GDFS startup failed, that is fatal Elapsed: 415 secs. Code: SIGNED MODE (USING SERVER) CFG:100000000000 SERVER CREDITS LEFT/USED: 27/3 CARD COUNTERS: FLASH 121, UNLOCK 45 Elapsed: 4 secs. Code: PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") CFG:000000000000 DB2020 EROM UPGRADE MODE STARTED ChipID:9900,EMP protocol:0301 BOOTROM MODE DETECTED Speed:921600 LDR:071130 1150 NPACXC1250330_DB2020_PRODUCTIONIDLOADER_P3M OTP: LOCKED:1 CID:51 PAF:1 IMEI:35799401884778 CERT:N/A FLASH CID:52 COLOR:RED EROM UPGRADE CAN'T FIND QUALIFIED PART Elapsed: 10 secs. Code: SIGNED MODE (USING SERVER) CFG:100000000000 SERVER CREDITS LEFT/USED: 27/3 CARD COUNTERS: FLASH 121, UNLOCK 45 Elapsed: 4 secs. SIGNED MODE (USING SERVER) PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") CFG:100000000000 RESET MODE STARTED ChipID:9900,EMP protocol:0301 BOOTROM MODE DETECTED Speed:921600 RESET:070703 1106 NPACXC1250329_DB2020_CERTRESETLOADER_P3AA FLASH ID:897E GOT SEED:2423905723806A7615A002D8 P96 AUTH PASSED OTP: LOCKED:1 CID:51 PAF:1 IMEI:3579taliktik02 CERT:N/A PHONE SUCCESSFULLY RESET TO DEVELOPER STATE Elapsed: 9 secs. Code: CFG:000000000000 ChipID:9900,EMP protocol:0301 BOOTROM MODE DETECTED Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:3579taliktik02 CERT:N/A FLASH CID:49 COLOR:BROWN LDR:060721 1021 DB2020_SERVICE_LOADER FLASH ID:897E writing "D:\installer\Cellphone apps\v0_915060\gdfs_in_ssw_format\db2020\K810_GDFS_SSW.ssw" CURRENT FLASH FILE CID:49 SSW uses full hash, hash len is: 640 Will flash 32 blocks... Setting up GDFS... OTP WRITE NOT EXECUTED WRITING CLEAR SIMLOCK UNITS... SIGNING... Elapsed: 31 secs. Code: CFG:000000000000 ChipID:9900,EMP protocol:0301 BOOTROM MODE DETECTED Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:3579taliktik02 CERT:N/A FLASH CID:49 COLOR:BROWN LDR:060721 1021 DB2020_SERVICE_LOADER FLASH ID:897E writing "D:\installer\Cellphone apps\v0_915060\eroms\db2020\DB2020EROM_CNV_RED52_BROWN_CID49_DB2020.ssw" CURRENT FLASH FILE CID:49 SSW uses full hash, hash len is: 40 Will flash 2 blocks... Setting up GDFS... OTP WRITE NOT EXECUTED WRITING CLEAR SIMLOCK UNITS... SIGNING... Elapsed: 13 secs. Code: CFG:000000000000 SERVER CREDITS LEFT/USED: 26/4 CARD COUNTERS: FLASH 121, UNLOCK 47 Elapsed: 3 secs. Code: CFG:000100000000 ChipID:9900,EMP protocol:0301 BOOTROM MODE DETECTED Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:3579taliktik02 CERT:N/A FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 FLASH ID:897E PHONE CID NOT SUPPORTED IN THAT MODE Elapsed: 8 secs. SIGNED MODE (USING SERVER) CFG:100100000000 ChipID:9900,EMP protocol:0301 BOOTROM MODE DETECTED Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:3579taliktik02 CERT:N/A FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 FLASH ID:897E writing "D:\installer\Cellphone apps\v0_915060\k810i\R8BF003_CXC1250811_SM_RED_CID52.software" CURRENT FLASH FILE CID:52 SSW uses full hash, hash len is: 9200 Will flash 460 blocks... writing "D:\installer\Cellphone apps\v0_915060\k810i\R8BF003_FS_S_E_EUROPE_SM_RED_CID52.software" CURRENT FLASH FILE CID:52 SSW uses full hash, hash len is: 4580 Will flash 229 blocks... LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader GDFS startup executed loader FILESYSTEM startup executed using GENERIC phone customization tpa/preset/custom/C3_PCA_G3v2.cer tpa/preset/custom/CONTENT_DOWNLOAD_HOOK_2.itm tpa/preset/custom/customize.xml tpa/preset/custom/DESKTOP_HOOK_2.itm tpa/preset/custom/Entrust.net Root Certificate.cer tpa/preset/custom/Entrust.net_WTLS_Root_Certificate.wcrt tpa/preset/custom/FM_PICTURES_HOOK_3.itm tpa/preset/custom/FM_SOUNDS_HOOK_3.itm tpa/preset/custom/FM_THEMES_HOOK_3.itm tpa/preset/custom/FM_VIDEOS_HOOK_3.itm tpa/preset/custom/GAMES_HOOK_3.itm tpa/preset/custom/GTE_CyberTrust_Root.cer tpa/preset/custom/GTE_Cybe_Trust_Root_WTLS.wcrt tpa/preset/custom/Root.cer tpa/preset/custom/SEMC_E2E_Root_CA.crt tpa/preset/custom/SETT_RINGTONE_HOOK_3.itm tpa/preset/custom/ThawtePremium.der tpa/preset/custom/ThawteServerCA.cer tpa/preset/custom/Utiroot.cer tpa/preset/custom/VeriSignClass3Root.cer tpa/preset/custom/Verisign_Class_3_CA_WTLS.wcrt Phone detached Elapsed: 449 secs. done! used 1 credit because of slow internet. |
The Following User Says Thank You to techseeker"ems" For This Useful Post: |
Z320 direct unlock via se tools done | KIKO_GSM | SETool2 | 3 | 04-29-2010 11:16 |
w910 hang blue screen done via se tool | techseeker"ems" | SETool2 | 3 | 03-27-2010 08:04 |
w880i no power done by se-tool | mquimpanes | SETool2 | 4 | 12-07-2009 15:44 |
k530i gdfs error done via tp | aljolas | Sony Ericsson | 0 | 12-11-2008 12:21 |
