Sony Ericsson ARM Inside: A3618,R600,T100,T100c,T102,T105,T106,Z200,J200,J200i,J200c, J210,J220,230,Z300 etc. AVR Inside: R520,T200,T202,T226,T226m,T226s,T230,T237,T238,T290,T290a,T290c,T290i, T300,T302,T306,T310,T312,T316,T39,T65,T68,T610,T616,T618,T628,T630,T637,P800,P802, P900,P908,P910,Z600,Z608. New ARM Inside (SEMC):D750,F500,J300,K300,K310,K500,K506c,K508,K510,K600,K608,K610,K700,K750,K790,M600, P990,S700,S710,W300,W550,W600,W700,W800,W810,W900,V600,V630,V800,Z1010,Z300,Z500,Z520,Z530,Z550,Z800. CR 16B Inside:T66,T600,T600c,T602. ODM:J100. C Series: C510, C702, C901, C902, C903, C905
G Series: G502, G705
K Series: K630, K660, K850
T Series: T700, T707, T715
V Series: V640
W Series: W508, W595, W705, W715, W760, W890, W902, W910, W980, W995
Z Series: Z750, Z770, Z780 |
10-26-2004, 16:08 | #1 (permalink) |
Junior Member Join Date: Oct 2004 Age: 44
Member: 88522 Status: Offline Thanks Meter: 0 | listening volume 0/0 t68 Please help me with this problem: listening volume 0/0 for t68! It is necesary to flash it first or it is enaugh to "write" listening_volume_0/0.gdfs file? Thank you a lot! |
10-26-2004, 20:56 | #2 (permalink) |
No Life Poster Join Date: Oct 2003 Location: Auckland, New Zealand
Member: 42570 Status: Offline Thanks Meter: 11 | There should be a GDFS fix for this, I'm not sure what it's called but the filename you posted looks promising. Give it a try and see how you go, it's a fairly easy (and common) fault to fix. |
10-26-2004, 23:53 | #3 (permalink) | |
Junior Member Join Date: Oct 2004 Age: 45
Member: 88515 Status: Offline Thanks Meter: 0 | Quote:
T68 i volume 0/0....help | kardelen gsm | Sony Ericsson Hardware Repair | 3 | 02-24-2006 06:16 |
t68 volume [0/0] fix in UFS format need ?? | mroa | UFS2 + UFS3-Tornadoflasher | 1 | 06-02-2005 08:35 |
SE T300 to 310, SE T68 volume 0/0, Nokia 1100 IMEI ??????????? after water...how to ? | Drumz | Twisterflasher | 4 | 09-29-2004 15:05 |
how can I listen sent recordings of t68 ? | koax | Sony Ericsson | 2 | 06-30-2003 15:47 |
T68 Volume 0/0 problem | anduin | Sony Ericsson | 4 | 04-10-2003 00:58 |
