Sony Ericsson ARM Inside: A3618,R600,T100,T100c,T102,T105,T106,Z200,J200,J200i,J200c, J210,J220,230,Z300 etc. AVR Inside: R520,T200,T202,T226,T226m,T226s,T230,T237,T238,T290,T290a,T290c,T290i, T300,T302,T306,T310,T312,T316,T39,T65,T68,T610,T616,T618,T628,T630,T637,P800,P802, P900,P908,P910,Z600,Z608. New ARM Inside (SEMC):D750,F500,J300,K300,K310,K500,K506c,K508,K510,K600,K608,K610,K700,K750,K790,M600, P990,S700,S710,W300,W550,W600,W700,W800,W810,W900,V600,V630,V800,Z1010,Z300,Z500,Z520,Z530,Z550,Z800. CR 16B Inside:T66,T600,T600c,T602. ODM:J100. C Series: C510, C702, C901, C902, C903, C905
G Series: G502, G705
K Series: K630, K660, K850
T Series: T700, T707, T715
V Series: V640
W Series: W508, W595, W705, W715, W760, W890, W902, W910, W980, W995
Z Series: Z750, Z770, Z780 |
03-28-2004, 13:15 | #1 (permalink) |
No Life Poster Join Date: Oct 2003 Location: Lebanon / Nigeria Age: 52
Member: 42276 Status: Offline Thanks Meter: 47 | Mr The_Laser i need your help By the way, while flashing the handset something wrong is happening : flash AVR will complete succesfully. flash ARM will stop on 1% and give error. is there anything you can help me with to have my phone back working 100% thank you. |
03-28-2004, 15:58 | #2 (permalink) |
No Life Poster Join Date: Aug 2003 Location: at home
Member: 36951 Status: Offline Sonork: 100.63212 Thanks Meter: 6,247 | it seems like your arm cpu it's not working well. i think you've got error 350A, or something like that. try to reflow with hot air station the ARM CPU, and after that try to reflash the phone. if you get after 1% of flashing ARM the same error, you must change the ARM CPU. i know that you want that mister the_laser answer you, but i hope that what i've told helped you. br andres |
03-28-2004, 16:44 | #3 (permalink) |
No Life Poster Join Date: Feb 2002 Location: Russia Age: 44
Member: 9519 Status: Offline Thanks Meter: 2,150 | @cellulary: if flashing of arm cpu can't go past 1% it is means that ARM flash can't be erased. It can be caused by many reasons : bad flash chip (most probably), bad connections, etc,etc. rehot ARM flash chip, maybe it helps. |
03-29-2004, 19:29 | #6 (permalink) |
Member: 42276 Status: Offline Thanks Meter: 47 | Dear guys does this USB 3.1 should work with my DIV 8.4 dongle or another one. i downloaded the software and try to run it with DIV dongle and it give me a message "previliged instruction" and the software opens but can not read any phone. |
03-30-2004, 13:27 | #8 (permalink) |
Freak Poster Join Date: Feb 2004 Location: the land of the doomed Age: 47
Member: 51749 Status: Offline Thanks Meter: 20 | @the_laser i have been using div 8.4 patched by you for a while, as the original one i bought off mr zulea failed to work, i am interested in usingdiv usb but everytime i use it i get a variety of errors including 0101 and 3071 i think, i do have terminator dongle and sometimes i get div usb key not find, is using div usb the same as using div 8.x |
03-30-2004, 13:46 | #9 (permalink) |
No Life Poster Join Date: Nov 2002 Location: Romania Age: 41
Member: 17740 Status: Offline Thanks Meter: 1 | yes it is , but you didn't make yourself very clear .... with 8.4 did it worked good? if yes it means that the version of divusb that you have it is not patched very good if div8.4 sowed you same errors it mens that is something wrong with your dongle! check cables and dongle ... |
03-30-2004, 19:08 | #11 (permalink) |
Member: 42276 Status: Offline Thanks Meter: 47 | same problem with T616 which i'm converting to T610. AVR flash complete and ARM will stop at 1% and give me the same error 3108 can someone show a picture of the IC that should be reball and rehot. thank you guys |
mr vahid or mr siroya i need your help | xheti | UST Pro II | 11 | 05-15-2009 21:55 |
ust exe is closing MR SİROYA İ NEED YOUR HELP | phoenix59 | UST Pro II | 5 | 01-04-2007 11:52 |
please mr julvir i need your help | softel2004 | Redbox | 8 | 09-14-2006 15:13 |
Mr. Steve i need your Help please??? | .::Zafar Communication::. | FuriouS II | 7 | 09-18-2004 14:15 |
