Sony Ericsson ARM Inside: A3618,R600,T100,T100c,T102,T105,T106,Z200,J200,J200i,J200c, J210,J220,230,Z300 etc. AVR Inside: R520,T200,T202,T226,T226m,T226s,T230,T237,T238,T290,T290a,T290c,T290i, T300,T302,T306,T310,T312,T316,T39,T65,T68,T610,T616,T618,T628,T630,T637,P800,P802, P900,P908,P910,Z600,Z608. New ARM Inside (SEMC):D750,F500,J300,K300,K310,K500,K506c,K508,K510,K600,K608,K610,K700,K750,K790,M600, P990,S700,S710,W300,W550,W600,W700,W800,W810,W900,V600,V630,V800,Z1010,Z300,Z500,Z520,Z530,Z550,Z800. CR 16B Inside:T66,T600,T600c,T602. ODM:J100. C Series: C510, C702, C901, C902, C903, C905
G Series: G502, G705
K Series: K630, K660, K850
T Series: T700, T707, T715
V Series: V640
W Series: W508, W595, W705, W715, W760, W890, W902, W910, W980, W995
Z Series: Z750, Z770, Z780 |
02-28-2010, 10:46 | #1 (permalink) |
Freak Poster Join Date: Dec 2007
Member: 654635 Status: Offline Thanks Meter: 15 | plz help me if you can SIGNED MODE (USING SERVER) CFG:100110000000 Unknown ChipID (0), RETRY FAILED TO SETUP PHONE Elapsed: 24 secs. so what is this plz |
02-28-2010, 15:06 | #2 (permalink) |
No Life Poster Join Date: Jun 2006 Location: {JUST@PRAY@FOR@ME} Age: 39
Member: 288504 Status: Offline Sonork: .:100.1587032:. Thanks Meter: 2,266 | 1. Check the battery.(if battery OK, use power supply and give 4.5v to phone and try) 2. Full clean the board with low heat 3. Use latest Se tool software version. note-not solved ur pb then again post full logs i will try....thx.... |
pls help me if you can | med26 | Samsung Hardware Repair | 0 | 02-17-2010 16:49 |
Please Help me If you can and thank's | mahimed | Nokia Base Band 5 ( BB-5 ) | 3 | 08-26-2009 00:43 |
Careful of "helper_ufs" and help me if you can | to_deal_with | The Market Feed Back | 8 | 02-27-2007 23:22 |
Please Help Me If You Can!!!!! | wimzieee | Samsung Flashers, Software, Firmware. | 4 | 08-24-2004 10:11 |
Give Me A Helping Hand If You Can | sunrise gsm | Infineon C16X M51 & ARM7 M52 BASED | 7 | 03-02-2004 21:09 |
