Sony Ericsson ARM Inside: A3618,R600,T100,T100c,T102,T105,T106,Z200,J200,J200i,J200c, J210,J220,230,Z300 etc. AVR Inside: R520,T200,T202,T226,T226m,T226s,T230,T237,T238,T290,T290a,T290c,T290i, T300,T302,T306,T310,T312,T316,T39,T65,T68,T610,T616,T618,T628,T630,T637,P800,P802, P900,P908,P910,Z600,Z608. New ARM Inside (SEMC):D750,F500,J300,K300,K310,K500,K506c,K508,K510,K600,K608,K610,K700,K750,K790,M600, P990,S700,S710,W300,W550,W600,W700,W800,W810,W900,V600,V630,V800,Z1010,Z300,Z500,Z520,Z530,Z550,Z800. CR 16B Inside:T66,T600,T600c,T602. ODM:J100. C Series: C510, C702, C901, C902, C903, C905
G Series: G502, G705
K Series: K630, K660, K850
T Series: T700, T707, T715
V Series: V640
W Series: W508, W595, W705, W715, W760, W890, W902, W910, W980, W995
Z Series: Z750, Z770, Z780 |
07-14-2009, 07:17 | #1 (permalink) |
No Life Poster Join Date: May 2008 Location: G S M Age: 36
Member: 774744 Status: Offline Thanks Meter: 774 | K800 gdfs problem help me CARD SERIAL: 00068002 Loaded 51 flash descriptors SIGNED MODE (USING SERVER). ALTERNATIVE SECURITY BYPASS ENABLED. PRELOADER SECURITY BYPASS ENABLED. Will write GDFS now. Open COM port OK phone pre-boot failed,possible RECOVERY needed. PROCEDURE WAS STOPPED BY USER Elapsed: 41 secs. SIGNED MODE (USING SERVER). ALTERNATIVE SECURITY BYPASS ENABLED. PRELOADER SECURITY BYPASS ENABLED. Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 Flash ID check:897E Flash props sent ok OTP LOCKED:1 CID:51 PAF:1 IMEI:35908801168425 CERT:N/A FLASH CID:53 COLOR:RED set_gdfs_props failed, exiting Elapsed: 37 secs. SIGNED MODE (USING SERVER). ALTERNATIVE SECURITY BYPASS ENABLED. PRELOADER SECURITY BYPASS ENABLED. Will write GDFS now. Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 OTP LOCKED:1 CID:51 PAF:1 IMEI:35908801168425 CERT:N/A FLASH CID:53 COLOR:RED PATCH:071120 1355 HANCXC9876543210_DB2020_MEM_PATCHER_R2A012 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 Flash ID check:897E Flash props sent ok ALTERNATIVE SECURITY BYPASS ONLY SUPPORTED ON DCU60 ! Elapsed: 11 secs. SIGNED MODE (USING SERVER). PRELOADER SECURITY BYPASS ENABLED. Will write GDFS now. Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 OTP LOCKED:1 CID:51 PAF:1 IMEI:35908801168425 CERT:N/A FLASH CID:53 COLOR:RED PATCH:071120 1355 HANCXC9876543210_DB2020_MEM_PATCHER_R2A012 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 Flash ID check:897E Flash props sent ok ALTERNATIVE SECURITY BYPASS ONLY SUPPORTED ON DCU60 ! Elapsed: 12 secs. SIGNED MODE (USING SERVER). Will write GDFS now. Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 OTP LOCKED:1 CID:51 PAF:1 IMEI:35908801168425 CERT:N/A FLASH CID:53 COLOR:RED PATCH:071120 1355 HANCXC9876543210_DB2020_MEM_PATCHER_R2A012 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 Flash ID check:897E Flash props sent ok LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader startup: executed Loader refused to start GDFS services,error is:29 loader GDFS startup failed, that is fatal Elapsed: 18 secs. SIGNED MODE (USING SERVER). Processing script "F:\seetools\seetools\se tool\v0.914038\eroms\db2020\DB2020EROM_CNV_RED53_B ROWN_CID49_DB2020.ssw"... Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 OTP LOCKED:1 CID:51 PAF:1 IMEI:35908801168425 CERT:N/A FLASH CID:53 COLOR:RED PATCH:071120 1355 HANCXC9876543210_DB2020_MEM_PATCHER_R2A012 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 Flash ID check:897E Flash props sent ok LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader startup: executed Loader refused to start GDFS services,error is:29 loader GDFS startup failed, that is fatal Elapsed: 26 secs. there is logs so how i can solve it |
The Following User Says Thank You to bilalzaink For This Useful Post: |
07-14-2009, 07:33 | #3 (permalink) |
Member: 774744 Status: Offline Thanks Meter: 774 | how i can repair with test point cable with seetool because i do not use setool box for this problem i use for this only dream box but at this time i have o dream box..also......... |
k800 GDFS problem! | /FAISAL/ | SETool2 | 1 | 03-22-2010 10:47 |
K800 GDFS problem. | joer | SETool2 | 4 | 03-26-2009 00:59 |
K800 GDFS Problem | curtisbcm | Cruiser Suite | 7 | 12-02-2008 21:34 |
K800 Gdfs Problem | oMeR_Rasheed | Universalbox | 8 | 09-03-2008 08:50 |
k800 gdfs problem plzz help | nadirghazi | Sony Ericsson | 6 | 07-31-2008 19:34 |
