Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Ericsson
Sony Ericsson
  • ARM Inside: A3618,R600,T100,T100c,T102,T105,T106,Z200,J200,J200i,J200c, J210,J220,230,Z300 etc.
  • AVR Inside: R520,T200,T202,T226,T226m,T226s,T230,T237,T238,T290,T290a,T290c,T290i, T300,T302,T306,T310,T312,T316,T39,T65,T68,T610,T616,T618,T628,T630,T637,P800,P802, P900,P908,P910,Z600,Z608.
  • New ARM Inside (SEMC):D750,F500,J300,K300,K310,K500,K506c,K508,K510,K600,K608,K610,K700,K750,K790,M600, P990,S700,S710,W300,W550,W600,W700,W800,W810,W900,V600,V630,V800,Z1010,Z300,Z500,Z520,Z530,Z550,Z800.
  • CR 16B Inside:T66,T600,T600c,T602.
  • ODM:J100.
  • C Series: C510, C702, C901, C902, C903, C905
  • G Series: G502, G705
  • K Series: K630, K660, K850
  • T Series: T700, T707, T715
  • V Series: V640
  • W Series: W508, W595, W705, W715, W760, W890, W902, W910, W980, W995
  • Z Series: Z750, Z770, Z780
  • Reply
    Old 11-21-2009, 08:17   #1 (permalink)
    Member: 703094
    Thanks Meter: 23
    no power w810i done again
    PHONE STATE: "RETAIL"
    FLASH CID: 0049
    Speed:460800
    Flash ID check:2019
    Flash props sent ok
    OTP: LOCKED:1 CID:49 PAF:1 IMEI:35906100004465 CERT:RED
    FLASH CID:49 COLOR:RED
    IMEI MISMATCH ! GDFS IMEI:35906100020285
    Model:W810i
    Brand:Generic
    MAPP CXC article: R4CE012 prgCXC1250316_GENERIC_HN
    MAPP CXC version: R4CE012
    Language Package:S_ASIA_LEVAN
    CDA article: CDA102555/110
    CDA version: R2A
    Default article: cxc1250324
    Default version: R4CE012
    PROVIDER: 000-00
    SIMLOCKS NOT DETECTED
    USERCODE:0000
    SEARCH:C:\setools\Se tool v0.915016\eroms\db2010\w810_erom_brown49.ssw
    RESTORATION FILE NOT PRESENT
    "R4CE012_CXC1250316_GENERIC_HN"
    YOU MUST PERFORM FULL FLASHING
    WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED
    Elapsed: 9 secs.
    Open COM port OK
    ChipID:8040,EMP protocol:0301
    FLASH CID: 0049
    Speed:460800
    PATCH:061204 1529 HAN_DB2010_MEM_PATCHER_R2A007_CXC9876543210 0
    LDR:060718 0842 LIE_DB2010_FLASHLOADER_R2A003_CXC1326738210 0
    REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK
    THEN PRESS "READY"
    Open COM port OK
    Trying to launch embedded bootloader...
    INT LDRB2010_RESPIN_ID_LOADER_SETOOL2
    LDRB2010_RESPIN_PRODLOADER_SETOOL2
    Flash ID check:2019
    Flash props sent ok
    FOUND REST FILE "R4CK003_CXC1250317_CHINA_HN"...
    UPLOADING REST FILE "R4CK003_CXC1250317_CHINA_HN"...
    can't open file "F:\setools\Se tool v0.915016\rest\R4CK003_CXC1250317_CHINA_HN"
    Setting up GDFS...
    setGDFS_params failed
    failed to setup GDFS
    Unlock FAILED
    Elapsed: 102 secs.
    SIGNED MODE (USING SERVER).
    Open COM port OK
    FLASH CID: 0049
    Speed:460800
    Flash ID check:2019
    Flash props sent ok
    writing C:\setools\SE\W810\W810_CHINA_R4CE012_MAIN.bin.cry
    CURRENT FLASH FILE CID:49
    SSW uses dynamic hash, dynamic hash len is:365
    Will flash 365 blocks...
    SSW loading returns:0
    writing C:\setools\SE\W810\W810_C_ASIA_R4CE012_FS.bin.cry
    SSW uses dynamic hash, dynamic hash len is:161
    Will flash 161 blocks...
    LDR:070524 1030 AN2CXC1327364_COMPACT_SEMC_CS_LOADER__R3A010
    loader startup: executed
    loader GDFS startup: executed
    loader filesystem startup: executed
    loader unlock: executed
    writing "tpa/preset/custom/C3_PCA_G3v2.cer"
    writing "tpa/preset/custom/CONTENT_DOWNLOAD_HOOK_2.itm"
    writing "tpa/preset/custom/customize.xml"
    writing "tpa/preset/custom/DESKTOP_HOOK_2.itm"
    writing "tpa/preset/custom/Entrust.net Root Certificate.cer"
    writing "tpa/preset/custom/Entrust.net_WTLS_Root_Certificate.wcrt"
    writing "tpa/preset/custom/FM_PICTURES_HOOK_3.itm"
    writing "tpa/preset/custom/FM_SOUNDS_HOOK_3.itm"
    writing "tpa/preset/custom/FM_THEMES_HOOK_3.itm"
    writing "tpa/preset/custom/FM_VIDEOS_HOOK_3.itm"
    writing "tpa/preset/custom/GAMES_HOOK_3.itm"
    writing "tpa/preset/custom/GTE_CyberTrust_Root.cer"
    writing "tpa/preset/custom/GTE_Cybe_Trust_Root_WTLS.wcrt"
    writing "tpa/preset/custom/Root.cer"
    writing "tpa/preset/custom/SEMC_E2E_Root_CA.crt"
    writing "tpa/preset/custom/SETT_RINGTONE_HOOK_3.itm"
    writing "tpa/preset/custom/ThawtePremium.der"
    writing "tpa/preset/custom/ThawteServerCA.cer"
    writing "tpa/preset/custom/Utiroot.cer"
    writing "tpa/preset/custom/VeriSignClass3Root.cer"
    writing "tpa/preset/custom/Verisign_Class_3_CA_WTLS.wcrt"
    Phone detached
    Elapsed: 1186 secs.
    lg kp 501 no power lusomaco LG Hardware Repair 1 03-31-2010 12:44
    LG-KH1800 SHOW (KOREAN PHONE) UNLOCKED DONE AGAIN! PIC'S and PROCEDURE INSIDE Ligalig LG 1 03-30-2010 07:40
    Genie dead no power on... [ANSWERED] lchico Genie Universal 1 03-29-2010 07:18
    E51 No Power [Grounded] done!!! squallx2006 Nokia Hardware & Hardware Repair 0 02-24-2010 02:24
    Page generated in 0.13518 seconds with 9 queries
