Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Ericsson
Sony Ericsson
  • ARM Inside: A3618,R600,T100,T100c,T102,T105,T106,Z200,J200,J200i,J200c, J210,J220,230,Z300 etc.
  • AVR Inside: R520,T200,T202,T226,T226m,T226s,T230,T237,T238,T290,T290a,T290c,T290i, T300,T302,T306,T310,T312,T316,T39,T65,T68,T610,T616,T618,T628,T630,T637,P800,P802, P900,P908,P910,Z600,Z608.
  • New ARM Inside (SEMC):D750,F500,J300,K300,K310,K500,K506c,K508,K510,K600,K608,K610,K700,K750,K790,M600, P990,S700,S710,W300,W550,W600,W700,W800,W810,W900,V600,V630,V800,Z1010,Z300,Z500,Z520,Z530,Z550,Z800.
  • CR 16B Inside:T66,T600,T600c,T602.
  • ODM:J100.
  • C Series: C510, C702, C901, C902, C903, C905
  • G Series: G502, G705
  • K Series: K630, K660, K850
  • T Series: T700, T707, T715
  • V Series: V640
  • W Series: W508, W595, W705, W715, W760, W890, W902, W910, W980, W995
  • Z Series: Z750, Z770, Z780
  • Reply
    Old 04-10-2005, 14:04   #1 (permalink)
    Member: 73641
    Thanks Meter: 2
    p900 touch screen problem
    i have a problem with p900 screen.
    i formatted my p900.
    then p900 touch screen middle area is not working.Dont respont the touchs with stylus or finger.Other areas are working.(corner,bottom,head)
    Can i how fix it.
    is it available with software settings or flashing firmware
    Thanx
    Old 04-10-2005, 14:17   #2 (permalink)
    yasirmcp's Avatar
    Member: 36825
    Thanks Meter: 11
    Can i how fix it.
    Thanx
    if u want to set userdefault u rry to master reset.if it is not ok then remove u r memory battery then all will come to user default.some time it is the problem of the connector of the top of lcd glass conector
    Old 04-11-2005, 10:09   #3 (permalink)
    Member: 73641
    Thanks Meter: 2
    thanx yasirmcp
    i will make your suggestions
    Old 04-11-2005, 10:16   #4 (permalink)
    Member: 73641
    Thanks Meter: 2
    What is the "master reset"
    Can i how make it
    it is as "jd up, jd up, * ,jd down, jd down, *,jd down, *"
    is it available in the service mode?
    or
    with flashing tools
    Old 04-11-2005, 10:20   #5 (permalink)
    yasirmcp's Avatar
    Member: 36825
    Thanks Meter: 11
    Can i how make it
    or
    with flashing tools
    master reset u can do threw menu.in settings u can see master reset.
    Old 04-11-2005, 18:50   #6 (permalink)
    Member: 73641
    Thanks Meter: 2
    ok yasirmcp.
    i seen after using with english language the phone
    But
    it is requesting lock code to me.
    i dont know the lock code :-)
    also
    Old 04-11-2005, 19:59   #7 (permalink)
    Member: 73641
    Thanks Meter: 2
    i found lock code and did reset
    But dont anything.
    Dont working center of screen
    Old 04-12-2005, 11:33   #8 (permalink)
    yasirmcp's Avatar
    Member: 36825
    Thanks Meter: 11
    ok yasirmcp.
    But
    also
    TRY 0000 OR 00000000 OR 000000
    Old 04-12-2005, 11:43   #9 (permalink)
    Member: 73641
    Thanks Meter: 2
    ok.but
    i did master reset
    But:
    Center of screen dont working
    Old 04-12-2005, 11:54   #10 (permalink)
    yasirmcp's Avatar
    Member: 36825
    Thanks Meter: 11
    ok.but
    i did master reset
    But:
    TRY TO CHECK WITH ONE OTHER DISPLY(IF U HAVE).THEN WE CAN COFERM
    PROBLEM ON DISPLAY OR PHONE
    Old 04-12-2005, 13:11   #11 (permalink)
    Member: 73641
    Thanks Meter: 2
    i dont have a extra screen.
    i will do upgrade p900 to p908 using flashing firmware to my phone in next days
    Old 05-03-2005, 10:25   #12 (permalink)
    FITOS's Avatar
    Member: 111248
    my friend ....
    the problem is the ic...
    Bless u
    Old 06-11-2005, 15:55   #13 (permalink)
    Leo140's Avatar
    Member: 43076
    Thanks Meter: 10
    touch screeen doen not work, must be hardware problem, totally not software, so do not try
    Old 06-19-2005, 15:46   #14 (permalink)
    nctrung_vn's Avatar
    Member: 135671
    Thanks Meter: 45
    I have the same prolem.
    My scrên i blank .
    Can not turn on POWER it.
    Old 06-19-2005, 17:32   #15 (permalink)
    Member: 134852
    Sonork: 100.1603594
    Take of scren and chek flat cabel conection bitween uper touch pad end conector .
    Curious: Touch screen is not working and is not touch screen problem trentini iPhone 2 / iPhone 3G / iPhone 3GS 2 09-04-2009 16:23
    htc touch elf touch screen problem worldwidemovil HTC & PDA WM( With Touchscreen) 2 05-23-2009 14:28
    p900 Touch screen PHLI72 Sony Ericsson Hardware Repair 1 12-26-2007 22:21
    p900 touch screen calibiration? zeeber Cruiser Suite 2 10-30-2005 23:31
    p900 touch screen not working gsm-decode Sony Ericsson 3 07-30-2004 10:36
    Page generated in 0.23917 seconds with 10 queries
