Sony Ericsson ARM Inside: A3618,R600,T100,T100c,T102,T105,T106,Z200,J200,J200i,J200c, J210,J220,230,Z300 etc. AVR Inside: R520,T200,T202,T226,T226m,T226s,T230,T237,T238,T290,T290a,T290c,T290i, T300,T302,T306,T310,T312,T316,T39,T65,T68,T610,T616,T618,T628,T630,T637,P800,P802, P900,P908,P910,Z600,Z608. New ARM Inside (SEMC):D750,F500,J300,K300,K310,K500,K506c,K508,K510,K600,K608,K610,K700,K750,K790,M600, P990,S700,S710,W300,W550,W600,W700,W800,W810,W900,V600,V630,V800,Z1010,Z300,Z500,Z520,Z530,Z550,Z800. CR 16B Inside:T66,T600,T600c,T602. ODM:J100. C Series: C510, C702, C901, C902, C903, C905
G Series: G502, G705
K Series: K630, K660, K850
T Series: T700, T707, T715
V Series: V640
W Series: W508, W595, W705, W715, W760, W890, W902, W910, W980, W995
Z Series: Z750, Z770, Z780 |
02-24-2010, 06:22 | #1 (permalink) |
No Life Poster Join Date: Jul 2009 Location: philippines now here in U.A.E Age: 38
Member: 1070665 Status: Offline Sonork: 100.1636802 Thanks Meter: 572 | g700 after flash restarting help Elapsed: 0 secs. SIGNED MODE (USING SERVER) CFG:100101000000 writing "F:\ALL BOX FILES & UPDATES\setool\setool-Sony Ericson\G700\G700_MR2_WORLD1__R9N002_R1F_R6K842_R6 K836_.zip" Processing package F:\ALL BOX FILES & UPDATES\setool\setool-Sony Ericson\G700\G700_MR2_WORLD1__R9N002_R1F_R6K842_R6 K836_.zip detected MASTER on COM36, SLAVE on COM37 PDA EROM VERSION: 1202-0237 R1A01 package not contains ISP files Processing ACPU files PROCESSING: Core OS FILE FLASHED OK PROCESSING: ROFS1 FILE FLASHED OK PROCESSING: ROFS1 Extension FILE FLASHED OK PROCESSING: ROFS2 FILE FLASHED OK PROCESSING: USERDATA FILE FLASHED OK PLEASE IGNORE "PRESS POWER ON" MESSAGES !!!! fetched MASTER on COM36, SLAVE on COM37 ChipID:7100,EMP protocol:0301 NEW SECURITY (MARITA RESPIN) PHONE PHONE STATE: "RETAIL" FLASH CID: 0053 Speed:921600 OTP: LOCKED:1 CID:52 PAF:1 IMEI:35388702076505 CERT:RED LDR:060524 0930 LIECXC1325414_DB2000_FLASHLOADER_R1A003 FLASH ID:8964 Processing CCPU files PROCESSING: R5C01_CXC162175_CCPU_fs_EN_Red_CID53_DB2001.softwa re CURRENT FLASH FILE CID:53 SSW uses full hash, hash len is: 160 Will flash 8 blocks... PROCESSING: R9N002_CXC162037_CCPU_EN_MO_Red_CID53_DB2001.softw are CURRENT FLASH FILE CID:53 SSW uses full hash, hash len is: 2120 Will flash 106 blocks... Processing update files LDR:070405 1245 NPA1_CXC1327363_1_SEMC_CS_LOADER_1_P1E loader GDFS startup executed PROCESSING: R6G804_CAH1621132_Settings_JO_LockRemoved.gdfs PROCESSING: R6G804_CAH1621132_Settings_JO_LockRemoved.gdfs.gdf s Writing GDFS var 0002/06D6/0001 Writing GDFS var 0002/06D4/0005 Writing GDFS var 0002/06D3/000F Writing GDFS var 0000/0094/0001 PROCESSING: R6K842_CAH1621132_PUQData_JO_World1.gdfs Elapsed: 463 secs. SIGNED MODE (USING SERVER) CFG:100101000000 PLEASE IGNORE "PRESS POWER ON" MESSAGES !!!! detected MASTER on COM36, SLAVE on COM37 ChipID:7100,EMP protocol:0301 NEW SECURITY (MARITA RESPIN) PHONE PHONE STATE: "RETAIL" FLASH CID: 0053 Speed:921600 OTP: LOCKED:1 CID:52 PAF:1 IMEI:35388702076505 CERT:RED LDR:060524 0930 LIECXC1325414_DB2000_FLASHLOADER_R1A003 FLASH ID:8964 LDR:070405 1245 NPA1_CXC1327363_1_SEMC_CS_LOADER_1_P1E Executing CSCA-based unlock. loader GDFS startup executed Checking for signature... CAN'T CONNECT TO SERVER. signature calculation not done,err: 144 Elapsed: 32 secs. SIGNED MODE (USING SERVER) CFG:100110100000 writing "F:\ALL BOX FILES & UPDATES\setool\setool-Sony Ericson\G700\G700_MR2_WORLD1__R9N002_R1F_R6K842_R6 K836_.zip" Processing package F:\ALL BOX FILES & UPDATES\setool\setool-Sony Ericson\G700\G700_MR2_WORLD1__R9N002_R1F_R6K842_R6 K836_.zip detected MASTER on COM36, SLAVE on COM37 PDA EROM VERSION: 1202-0237 R1A01 package not contains ISP files Processing ACPU files PROCESSING: Core OS FILE FLASHED OK PROCESSING: ROFS1 FILE FLASHED OK PROCESSING: ROFS1 Extension FILE FLASHED OK PROCESSING: ROFS2 FILE FLASHED OK PROCESSING: USERDATA FILE FLASHED OK PLEASE IGNORE "PRESS POWER ON" MESSAGES !!!! fetched MASTER on COM36, SLAVE on COM37 Terminate loader NAK Break. Elapsed: 337 secs. SIGNED MODE (USING SERVER) CFG:100110100000 PLEASE IGNORE "PRESS POWER ON" MESSAGES !!!! detected MASTER on COM36, SLAVE on COM37 PROCEDURE WAS STOPPED BY USER version request timeout PDA EROM VERSION: N/A Terminate loader NAK Elapsed: 40 secs. SIGNED MODE (USING SERVER) CFG:100110100000 writing "F:\ALL BOX FILES & UPDATES\setool\setool-Sony Ericson\G700\G700_MR2_WORLD2__R9N002_R1F_R6K842_R6 K836_.zip" Processing package F:\ALL BOX FILES & UPDATES\setool\setool-Sony Ericson\G700\G700_MR2_WORLD2__R9N002_R1F_R6K842_R6 K836_.zip detected MASTER on COM36, SLAVE on COM37 PDA EROM VERSION: 1202-0237 R1A01 package not contains ISP files Processing ACPU files PROCESSING: Core OS FILE FLASHED OK PROCESSING: ROFS1 FILE FLASHED OK PROCESSING: ROFS1 Extension FILE FLASHED OK PROCESSING: ROFS2 FILE FLASHED OK PROCESSING: USERDATA FILE FLASHED OK PLEASE IGNORE "PRESS POWER ON" MESSAGES !!!! fetched MASTER on COM36, SLAVE on COM37 Terminate loader NAK Break. Elapsed: 306 secs. SIGNED MODE (USING SERVER) CFG:100110100000 UNLOCK IMPOSSIBLE IN "SIGNED" MODE Elapsed: 0 secs. SIGNED MODE (USING SERVER) CFG:100000000000 PLEASE IGNORE "PRESS POWER ON" MESSAGES !!!! detected MASTER on COM36, SLAVE on COM37 ChipID:7100,EMP protocol:0301 NEW SECURITY (MARITA RESPIN) PHONE PHONE STATE: "RETAIL" FLASH CID: 0053 Speed:921600 OTP: LOCKED:1 CID:52 PAF:1 IMEI:35388702076505 CERT:RED LDR:060524 0930 LIECXC1325414_DB2000_FLASHLOADER_R1A003 FLASH ID:8964 LDR:070405 1245 NPA1_CXC1327363_1_SEMC_CS_LOADER_1_P1E Executing CSCA-based unlock. loader GDFS startup executed Checking for signature... CAN'T CONNECT TO SERVER. signature calculation not done,err: 144 Elapsed: 34 secs. SIGNED MODE (USING SERVER) CFG:100000000000 a1_sendCommand: exception! loader refused shutdown, remove and insert battery ! Elapsed: 0 secs. SIGNED MODE (USING SERVER) CFG:100000000000 writing "C:\v0.915059\eroms\ACPU\1201-0197_coreloader_hb107_P1B.armsoftware" Processing package C:\v0.915059\eroms\ACPU\1201-0197_coreloader_hb107_P1B.armsoftware damaged package Break. Elapsed: 0 secs. SIGNED MODE (USING SERVER) CFG:100000000000 writing "C:\v0.915059\eroms\ACPU\g700.zip" Processing package C:\v0.915059\eroms\ACPU\g700.zip detected MASTER on COM36, SLAVE on COM37 PDA EROM VERSION: 1202-0237 R1A01 package not contains ISP files Processing ACPU files PROCESSING: Mini Boot FILE FLASHED OK PROCESSING: Core Loader FILE FLASHED OK PROCESSING: Extended ROM FILE FLASHED OK PLEASE IGNORE "PRESS POWER ON" MESSAGES !!!! fetched MASTER on COM36, SLAVE on COM37 ChipID:7100,EMP protocol:0301 NEW SECURITY (MARITA RESPIN) PHONE PHONE STATE: "RETAIL" FLASH CID: 0053 Speed:921600 OTP: LOCKED:1 CID:52 PAF:1 IMEI:35388702076505 CERT:RED LDR:060524 0930 LIECXC1325414_DB2000_FLASHLOADER_R1A003 FLASH ID:8964 package not contains CCPU files no update files in package Elapsed: 30 secs. SIGNED MODE (USING SERVER) CFG:100000000000 writing "F:\ALL BOX FILES & UPDATES\setool\setool-Sony Ericson\G700\G700_MR2_WORLD2__R9N002_R1F_R6K842_R6 K836_.zip" Processing package F:\ALL BOX FILES & UPDATES\setool\setool-Sony Ericson\G700\G700_MR2_WORLD2__R9N002_R1F_R6K842_R6 K836_.zip detected MASTER on COM36, SLAVE on COM37 PDA EROM VERSION: 1202-0237 R1A01 package not contains ISP files Processing ACPU files PROCESSING: Core OS FILE FLASHED OK PROCESSING: ROFS1 FILE FLASHED OK PROCESSING: ROFS1 Extension FILE FLASHED OK PROCESSING: ROFS2 FILE FLASHED OK PROCESSING: USERDATA FILE FLASHED OK PLEASE IGNORE "PRESS POWER ON" MESSAGES !!!! fetched MASTER on COM36, SLAVE on COM37 ChipID:7100,EMP protocol:0301 NEW SECURITY (MARITA RESPIN) PHONE PHONE STATE: "RETAIL" FLASH CID: 0053 Speed:921600 OTP: LOCKED:1 CID:52 PAF:1 IMEI:35388702076505 CERT:RED LDR:060524 0930 LIECXC1325414_DB2000_FLASHLOADER_R1A003 FLASH ID:8964 Processing CCPU files PROCESSING: R5C01_CXC162175_CCPU_fs_EN_Red_CID53_DB2001.softwa re CURRENT FLASH FILE CID:53 SSW uses full hash, hash len is: 160 Will flash 8 blocks... PROCESSING: R9N002_CXC162037_CCPU_EN_MO_Red_CID53_DB2001.softw are CURRENT FLASH FILE CID:53 SSW uses full hash, hash len is: 2120 Will flash 106 blocks... Processing update files LDR:070405 1245 NPA1_CXC1327363_1_SEMC_CS_LOADER_1_P1E loader GDFS startup executed PROCESSING: R6G804_CAH1621132_Settings_JO_LockRemoved.gdfs PROCESSING: R6G804_CAH1621132_Settings_JO_LockRemoved.gdfs.gdf s Writing GDFS var 0002/06D6/0001 Writing GDFS var 0002/06D4/0005 Writing GDFS var 0002/06D3/000F Writing GDFS var 0000/0094/0001 PROCESSING: R6K836_CAH1621132_PUQData_JO_World2.gdfs Elapsed: 432 secs. SIGNED MODE (USING SERVER) CFG:100000000000 PLEASE IGNORE "PRESS POWER ON" MESSAGES !!!! detected MASTER on COM36, SLAVE on COM37 ChipID:7100,EMP protocol:0301 NEW SECURITY (MARITA RESPIN) PHONE PHONE STATE: "RETAIL" FLASH CID: 0053 Speed:921600 OTP: LOCKED:1 CID:52 PAF:1 IMEI:35388702076505 CERT:RED LDR:060524 0930 LIECXC1325414_DB2000_FLASHLOADER_R1A003 FLASH ID:8964 LDR:070405 1245 NPA1_CXC1327363_1_SEMC_CS_LOADER_1_P1E Executing CSCA-based unlock. loader GDFS startup executed Checking for signature... CAN'T CONNECT TO SERVER. signature calculation not done,err: 144 Elapsed: 22 secs. CFG:000000000000 PLEASE IGNORE "PRESS POWER ON" MESSAGES !!!! detected MASTER on COM36, SLAVE on COM37 ChipID:7100,EMP protocol:0301 NEW SECURITY (MARITA RESPIN) PHONE PHONE STATE: "RETAIL" FLASH CID: 0053 Speed:921600 OTP: LOCKED:1 CID:52 PAF:1 IMEI:35388702076505 CERT:RED phone CID not supported in that mode Elapsed: 8 secs. SIGNED MODE (USING SERVER) CFG:100001000000 PLEASE IGNORE "PRESS POWER ON" MESSAGES !!!! detected MASTER on COM36, SLAVE on COM37 ChipID:7100,EMP protocol:0301 NEW SECURITY (MARITA RESPIN) PHONE PHONE STATE: "RETAIL" FLASH CID: 0053 Speed:921600 OTP: LOCKED:1 CID:52 PAF:1 IMEI:35388702076505 CERT:RED LDR:060524 0930 LIECXC1325414_DB2000_FLASHLOADER_R1A003 FLASH ID:8964 LDR:070405 1245 NPA1_CXC1327363_1_SEMC_CS_LOADER_1_P1E Executing CSCA-based unlock. loader GDFS startup executed Checking for signature... CAN'T CONNECT TO SERVER. signature calculation not done,err: 144 Elapsed: 32 secs. SIGNED MODE (USING SERVER) CFG:101000000000 PLEASE IGNORE "PRESS POWER ON" MESSAGES !!!! PROCEDURE WAS STOPPED BY USER CAN'T DETECT PDA PDA setup failed Elapsed: 2 secs. SIGNED MODE (USING SERVER) CFG:101000000000 PLEASE IGNORE "PRESS POWER ON" MESSAGES !!!! detected MASTER on COM36, SLAVE on COM37 PROCEDURE WAS STOPPED BY USER Terminate loader NAK Elapsed: 15 secs. SIGNED MODE (USING SERVER) CFG:101000000000 PLEASE IGNORE "PRESS POWER ON" MESSAGES !!!! detected MASTER on COM36, SLAVE on COM37 PROCEDURE WAS STOPPED BY USER Elapsed: 21 secs. SIGNED MODE (USING SERVER) CFG:101000000000 RESET MODE STARTED PLEASE IGNORE "PRESS POWER ON" MESSAGES !!!! detected MASTER on COM36, SLAVE on COM37 ChipID:7100,EMP protocol:0301 NEW SECURITY (MARITA RESPIN) PHONE PHONE STATE: "RETAIL" FLASH CID: 0053 Speed:921600 RESET:070703 1102 NPACXC125880_DB2000_CERTRESETLOADER_P4D FLASH ID:8964 server step1 error:No server found. Elapsed: 20 secs. CFG:000001000000 PLEASE IGNORE "PRESS POWER ON" MESSAGES !!!! detected MASTER on COM36, SLAVE on COM37 ChipID:7100,EMP protocol:0301 NEW SECURITY (MARITA RESPIN) PHONE PHONE STATE: "RETAIL" FLASH CID: 0053 Speed:921600 OTP: LOCKED:1 CID:52 PAF:1 IMEI:35388702076505 CERT:RED phone CID not supported in that mode Elapsed: 19 secs. CFG:000000000000 PLEASE IGNORE "PRESS POWER ON" MESSAGES !!!! detected MASTER on COM36, SLAVE on COM37 ChipID:7100,EMP protocol:0301 NEW SECURITY (MARITA RESPIN) PHONE PHONE STATE: "RETAIL" FLASH CID: 0053 Speed:921600 OTP: LOCKED:1 CID:52 PAF:1 IMEI:35388702076505 CERT:RED phone CID not supported in that mode Elapsed: 15 secs. SIGNED MODE (USING SERVER) CFG:100001000000 PLEASE IGNORE "PRESS POWER ON" MESSAGES !!!! detected MASTER on COM36, SLAVE on COM37 ChipID:7100,EMP protocol:0301 NEW SECURITY (MARITA RESPIN) PHONE PHONE STATE: "RETAIL" FLASH CID: 0053 Speed:921600 OTP: LOCKED:1 CID:52 PAF:1 IMEI:35388702076505 CERT:RED LDR:060524 0930 LIECXC1325414_DB2000_FLASHLOADER_R1A003 FLASH ID:8964 LDR:070405 1245 NPA1_CXC1327363_1_SEMC_CS_LOADER_1_P1E Executing CSCA-based unlock. loader GDFS startup executed Checking for signature... CAN'T CONNECT TO SERVER. signature calculation not done,err: 144 Elapsed: 29 secs. SIGNED MODE (USING SERVER) CFG:110001000000 PLEASE IGNORE "PRESS POWER ON" MESSAGES !!!! detected MASTER on COM36, SLAVE on COM37 ChipID:7100,EMP protocol:0301 NEW SECURITY (MARITA RESPIN) PHONE PHONE STATE: "RETAIL" FLASH CID: 0053 Speed:921600 OTP: LOCKED:1 CID:52 PAF:1 IMEI:35388702076505 CERT:RED LDR:060524 0930 LIECXC1325414_DB2000_FLASHLOADER_R1A003 FLASH ID:8964 LDR:070405 1245 NPA1_CXC1327363_1_SEMC_CS_LOADER_1_P1E Executing CSCA-based unlock. loader GDFS startup executed Checking for signature... CAN'T CONNECT TO SERVER. signature calculation not done,err: 144 Elapsed: 30 secs. help after complete flashing phone restarting a few minuets |
S5200 restart problem die after flash need help | freedomqn | Z3X-Team Products | 9 | 12-08-2010 12:31 |
need help sony ericssson g700 after flash | lilong_lee | Universalbox | 13 | 02-26-2010 02:45 |
g700 after flash restarting help | lilong_lee | SETool2 | 2 | 02-24-2010 23:44 |
need help my e250 after flash restart after logo | /\/\A/\/| | UST Pro II | 2 | 11-09-2009 12:57 |
j200 restart after flash please help | hiredgun | UST Pro II | 2 | 08-11-2008 07:22 |
