Sony Ericsson ARM Inside: A3618,R600,T100,T100c,T102,T105,T106,Z200,J200,J200i,J200c, J210,J220,230,Z300 etc. AVR Inside: R520,T200,T202,T226,T226m,T226s,T230,T237,T238,T290,T290a,T290c,T290i, T300,T302,T306,T310,T312,T316,T39,T65,T68,T610,T616,T618,T628,T630,T637,P800,P802, P900,P908,P910,Z600,Z608. New ARM Inside (SEMC):D750,F500,J300,K300,K310,K500,K506c,K508,K510,K600,K608,K610,K700,K750,K790,M600, P990,S700,S710,W300,W550,W600,W700,W800,W810,W900,V600,V630,V800,Z1010,Z300,Z500,Z520,Z530,Z550,Z800. CR 16B Inside:T66,T600,T600c,T602. ODM:J100. C Series: C510, C702, C901, C902, C903, C905
G Series: G502, G705
K Series: K630, K660, K850
T Series: T700, T707, T715
V Series: V640
W Series: W508, W595, W705, W715, W760, W890, W902, W910, W980, W995
Z Series: Z750, Z770, Z780 |
03-22-2010, 13:02 | #2 (permalink) |
No Life Poster Join Date: Jun 2006 Location: {JUST@PRAY@FOR@ME} Age: 39
Member: 288504 Status: Offline Sonork: .:100.1587032:. Thanks Meter: 2,266 | Problem Solved! 1- Write a good GDFS to your phone. 2- user MUST unlock phone using alternative security bypass... |
03-23-2010, 12:20 | #3 (permalink) |
Freak Poster Join Date: Mar 2010
Member: 1249507 Status: Offline Sonork: [email protected] Thanks Meter: 9 | hi how can i flash c903 with setool |
03-23-2010, 12:29 | #4 (permalink) |
Member: 1249507 Status: Offline Sonork: [email protected] Thanks Meter: 9 | hi sir how can i unlockig j200i with setool |
03-23-2010, 14:56 | #5 (permalink) |
Member: 288504 Status: Offline Sonork: .:100.1587032:. Thanks Meter: 2,266 | common for all CID: 1. go to semc a2 tab, select proper model 2. add to firmware area correct MAIN, FS IMAGE parts of firmware. order not important. 3. select in misc. field needed CUSTPACK (.zip archive with customization files) 4. if you do not have CUSTPACK, you MUST check on settings "customize phone after flash" 5. set "signed mode" on settings tab. 6. set other settings according your needs. 7. back to semc a2 tab, press flash. |
Problem with C902 | noman shakir | Sony Ericsson Hardware Repair | 3 | 05-20-2011 09:42 |
Problem with C902 keypad | ChronicDK | Sony Ericsson Hardware Repair | 4 | 05-19-2011 20:37 |
Big problem with a2 w902 c902 w595 | ms.4011 | Sony Ericsson Hardware Repair | 0 | 12-05-2009 15:03 |
Big problem with a2 w902 c902 w595 | ms.4011 | Sony Ericsson | 0 | 12-05-2009 15:02 |
