Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Sony Ericsson > Sony Ericsson
Sony Ericsson
  • ARM Inside: A3618,R600,T100,T100c,T102,T105,T106,Z200,J200,J200i,J200c, J210,J220,230,Z300 etc.
  • AVR Inside: R520,T200,T202,T226,T226m,T226s,T230,T237,T238,T290,T290a,T290c,T290i, T300,T302,T306,T310,T312,T316,T39,T65,T68,T610,T616,T618,T628,T630,T637,P800,P802, P900,P908,P910,Z600,Z608.
  • New ARM Inside (SEMC):D750,F500,J300,K300,K310,K500,K506c,K508,K510,K600,K608,K610,K700,K750,K790,M600, P990,S700,S710,W300,W550,W600,W700,W800,W810,W900,V600,V630,V800,Z1010,Z300,Z500,Z520,Z530,Z550,Z800.
  • CR 16B Inside:T66,T600,T600c,T602.
  • ODM:J100.
  • C Series: C510, C702, C901, C902, C903, C905
  • G Series: G502, G705
  • K Series: K630, K660, K850
  • T Series: T700, T707, T715
  • V Series: V640
  • W Series: W508, W595, W705, W715, W760, W890, W902, W910, W980, W995
  • Z Series: Z750, Z770, Z780
  • Reply
    Old 11-01-2004, 21:25   #1 (permalink)
    Member: 49600
    Remove 'locked' WAP profiles with Setool..?
    Question for the Experts...
    I've have a SE T68i from Cingular that WAP profiles are 'locked' and cannot be deleted by normal flashing with dongle and DIV software.
    If I was to backup the firmware from my other uncustomized T68i, could I write this firmware to the Cingular T68i and **** out the locks on their WAP profiles..?
    Thanks in advance.
    Old 11-02-2004, 00:41   #2 (permalink)
    merwin's Avatar
    Member: 47173
    I really wouldn't do that. There's a 30% chance that you will end up with low standby time or non-working bluetooth.
    Contact me on IM when you have about 30 minutes to spare (and have the phone and terminator cable with you). I can walk you through the steps necessary.
    Old 11-02-2004, 07:05   #3 (permalink)
    SFlood's Avatar
    Member: 83
    Hmm, i remember something like this, i used decustomised GDFS and AVR firmware and if i remember correcrly (not sure its really so) after Master Reset - Reset All locked WAP profiles was gone without reflashing ARM parameters block. But i'm not sure it was so, just try it by youself.
    Old 11-02-2004, 07:32   #4 (permalink)
    merwin's Avatar
    Member: 47173
    Decustomizing the GDFS will only get rid of some cusotmizations. Many (namely AT&T) leave their customizations in the ARM flash, in an area that the EMMA (and DIV) flashes conveniently don't touch.
    And to top it off, if you flash the wrong type of t68 with the wrong arm flash you will have bad standby/no bluetooth.
    Old 11-02-2004, 10:10   #5 (permalink)
    SFlood's Avatar
    Member: 83
    Yes, but while doing Master Reset ARM WAP area are being rewrited too, so it worths a try.
    Old 11-02-2004, 15:26   #6 (permalink)
    merwin's Avatar
    Member: 47173
    Unfortunately, this part of it is never overwritten... trust me, it took months of working on it to get the solution
    Old 11-03-2004, 16:40   #7 (permalink)
    Member: 49600
    Hi merwin, I would really like a solution t remove these WAP profiles... I'll try and hook up with you on ICQ and I can usually be reached 8-5pm EST.
    Talk to you soon.
    Old 11-04-2004, 19:27   #8 (permalink)
    Member: 49600
    WAP Profiles finally gone...
    With help from Merwin, we managed to get rid of those 'locked' WAP profiles and no adverse effects of losing bluetooth or standby time...
    Many thanks again
    Old 11-06-2004, 05:08   #9 (permalink)
    Member: 20953
    can we maybe get those STEP BY STEP instructions ???
    Old 11-08-2004, 14:14   #10 (permalink)
    Member: 49600
    It is a bit more complicated... Basically, Merwin had gave me a 'program' of his own to run and he asked what result (ARM Flash ID) it came back with. Based on that, he then gave me another file to flash the phone with and it removed the locked WAP profiles.
    I think you will need to direct your request to Merwin to see if he would want to release the steps and files on how to do this as i think there more to it than just flashing an 'ARM' file to phone.
    Old 11-09-2004, 02:37   #11 (permalink)
    Member: 63675
    so merwin, it is inputting a certain hex value somewhere in the ARM to do this? if you could post instructions for this, it would be great. thank you.
    again thanks setool team t280 hang repair with setool kadricom SETool2 1 04-03-2010 02:21
    Removes Protection Card Error In Setool reactos GSM Programming & Reverse Engineering 4 12-28-2007 15:50
    Switch profiles with [+] key - change to [-] ? Replika x4x, x5x Flashpatching 1 09-01-2007 00:02
    Delete Wap Profile DonaldDuck69 Scout 0 08-09-2007 10:20
    Editing locked WAP profiles on C45 TriMesh x1x to x45/x50 0 01-24-2002 11:28
    Page generated in 0.32523 seconds with 11 queries
