Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Sony Ericsson > Sony Ericsson
Sony Ericsson
  • ARM Inside: A3618,R600,T100,T100c,T102,T105,T106,Z200,J200,J200i,J200c, J210,J220,230,Z300 etc.
  • AVR Inside: R520,T200,T202,T226,T226m,T226s,T230,T237,T238,T290,T290a,T290c,T290i, T300,T302,T306,T310,T312,T316,T39,T65,T68,T610,T616,T618,T628,T630,T637,P800,P802, P900,P908,P910,Z600,Z608.
  • New ARM Inside (SEMC):D750,F500,J300,K300,K310,K500,K506c,K508,K510,K600,K608,K610,K700,K750,K790,M600, P990,S700,S710,W300,W550,W600,W700,W800,W810,W900,V600,V630,V800,Z1010,Z300,Z500,Z520,Z530,Z550,Z800.
  • CR 16B Inside:T66,T600,T600c,T602.
  • ODM:J100.
  • C Series: C510, C702, C901, C902, C903, C905
  • G Series: G502, G705
  • K Series: K630, K660, K850
  • T Series: T700, T707, T715
  • V Series: V640
  • W Series: W508, W595, W705, W715, W760, W890, W902, W910, W980, W995
  • Z Series: Z750, Z770, Z780
  • Reply
    Old 05-04-2008, 15:17   #1 (permalink)
    Member: 763001
    Thumbs up Remove SIM-lock patch generator
    Hi everybody!
    I made a little tool what can generate SIM-Lock remover vkp patches that you can use with SETool2 Lite, Far Manager with SEFP (Sony Ericsson Flash Plugin) and compatible tools. It is able to generate vkp patches for DB2000/DB2010/DB2012/DB2020 CID36/49/50/51/52 MAIN firmwares (*.mbn, *.bin), but at the moment you can apply patches to DB2000/DB2010 CID36/49 and DB2020 CID52 platforms only. You can also apply patches to any DB2000/DB2010 CID36/49 and DB2020 CID52 cross flashed phone (e.g. DB2010 CID49 K310@W200).
    DISCLAMER: If the generated patch will brick your phone DO NOT blame me. But the worst thing may happen is that you need to reflash the MAIN firmware.
    Any comments, suggestions are welcome...
    History
    ------ v2.1 ------
    Fix: Now can generate patches for hopefully all DB2020 firmware files
    ------ v2.0 ------
    New:Added DB2020 support
    Bug: Unable to generate patches from many DB2020 firmware files
    ------ v1.5 ------
    Fix: Now can generate patches from all supported firmware files
    ------ v1.4 ------
    Fix: Now generates working patches for all DB2000 firmware files
    Bug: Cannot generate patches from some firmware files
    ------ v1.3 ------
    New:Added DB2000 support
    Bug: Generates bad patches from some DB2000 firmware files
    ------ v1.2 ------
    Fix: Now can generate patch from GSlide generated firmware files
    ------ v1.1 ------
    New: Added CID36 support
    Bug: Unable to generate patch from firmware files generated by GSlide
    ------ v1.0.1 ------
    New: Added platform detection routine
    Info: I decided not to support the DB2020 firmware files at the moment because we cannot apply the generated patches anyway...
    ------ v1.0.0(Beta) ------
    New: Initial release
    Bug: Unable to generate patch from DB2020 firmware files
    New version(07-01-2008):
    Released version 2.1
    - Now can generate patches for hopefully all DB2020 firmware files
    Unlocking tutorial
    How to connect the phone to flashing/patching tools:
    Many users asked me how to connect the phone to SETool2 Lite, XS++, etc., so I decided to write it up. First of all fully charge your battery.
    I. Install USB Flash driver:
    If you never modded your phone, then probably you don't have the USB Flash driver, what is required to be able to communicate with phone. So install the driver: USB Flash Driver Installation - Guide
    II. Connect the phone to SETool2 Lite(or any other flashing tool):
    Click on button what you need/guide says(Identify, Read GDFS, etc.)...
    When SETool2 Lite says to press the C key and connect the cable you need to:
    1. Turn off the phone(if it was turned on)
    2. Remove the battery, wait a few seconds(2-3 seconds is enough) and put it back, but DO NOT turn the phone on
    3. Press and hold the C key on phone and connect the DCU-60 cable(data cable, what comes with phone)
    4. When you see some progress on SETool2 Lite status window(on left side) release the C key.
    What is your phone's platform and EROM CID?
    If you don't know what is your phone's platform(DB2010, DB2020 etc.) and EROM CID, then read this: General Information about Patch-Unlocking (start here if you want to unlock)
    A. How to apply the generated patches to DB2010 CID49 phones:
    Follow this tutorial: How to apply patchs with Se Tool 2 Lite on DB2010 phones
    B. How to apply the generated patches to DB2020 CID52 phones:
    IMPORTANT: First you need backup the GDFS. If something goes wrong you can unbrick you phone with this backup. Here is how to do:
    Open SETool2 Lite v1.11.
    1. Select your phone model.
    2. Click on Read GDFS button.
    3. Follow the instructions given by SETool2 Lite.
    4. You will get a gdfs_[yourIMEI].bin file in SETool2 Lite folder. Put it to a safe place.
    I. We will apply the quick access patch to phone. It is needed to be able to use the quick access method in future. Due to this great patch you can easily apply the further patches, just like to DB2010 CID 49 phones.
    !!!YOU NEED TO DO THIS ONLY ONCE!!!
    With SETool2 Lite v1.11.
    2. In Windows Explorer drag the MAIN file (.mbn) onto SETool2 Lite v1.11 folder\qamaker\qamaker.exe. In the qamaker's folder you will get a quick_access_***X_******X.vkp file.
    3. Click on ... (three dots) button near MISC files box, and select the vkp file generated in step 2.
    4. Tick Bypass DB2020 security checkbox.
    5. Click on Add button and select the MAIN firmware file.
    6. Press FLASH button.
    7. Follow the instructions given by SETool2 Lite.
    8. READ THIS CAREFULLY, it is a little tricky: When a dialog pop-up, click "Yes" to remove the patch. Click "No" to add the patch. In this case click on "No" button.
    At one moment you will belive that nothing happens and the status windows is not changing! DO NOT remove the CABLE! Wait until "ELAPSED x SECONDS" appears in status window.
    This process will take some time, about 10-15 minutes or more...
    II. Now we need to generate an unlock patch.
    Run SIMLockPatchGen.exe, select that MAIN firmware (used earlier) by clicking on ... (three dots) button, then press the Make patch button. In status window you will get the path to the generated vkp file(e.g. "D:\...\SIMLockPatchGen\vkp\Remove_SIM_lock_XX X_XX ***XX.vkp" patch file created.) Close the SIMLockPatchGen.
    III. We will apply the generated unlock patch to unlock the phone.
    With SETool2 Lite v1.11:
    1. Click on Clear button.
    2. Select your phone model.
    3. Tick Use "quick access" patch checkbox
    4. Uncheck(remove the tick from) Bypass DB2020 security checkbox.
    5. Click on ... (three dots) button near MISC files box, and select the vkp file generated by SIMLockPatchGen.
    6. Click Write SCRIPT button
    7. Follow the instructions in left status window...
    Wait until "ELAPSED x SECONDS" appears in status window, and done. Your phone is unlocked.
    The Following User Says Thank You to aqui For This Useful Post:
    Old 05-04-2008, 21:46   #2 (permalink)
    globalsystem's Avatar
    Member: 521295
    Sonork: 100.1607380
    no reply ?! because mr aqui is a junior member...
    thanx aqui, great info & good luck
    Old 05-04-2008, 21:53   #3 (permalink)
    Member: 521295
    Sonork: 100.1607380
    Old 05-04-2008, 23:41   #4 (permalink)
    Member: 763001
    Thank you more good stuff coming...
    enjoy, by GSM Unlockers Awareness Report
    Old 05-05-2008, 01:24   #5 (permalink)
    Member: 763001
    Here is the patchGen.
    Old 05-05-2008, 04:07   #6 (permalink)
    rico_deep's Avatar
    Member: 159757
    old tool............old news....................
    The Following User Says Thank You to rico_deep For This Useful Post:
    Old 05-05-2008, 06:33   #7 (permalink)
    Member: 312676
    1: Old tool, old news
    2: Simonx is the creator of this tool, not aqui.
    So 2x dupe.
    Shame on you.
    Old 05-06-2008, 18:08   #8 (permalink)
    Member: 521295
    Sonork: 100.1607380
    So 2x dupe.
    Shame on you.
    >>>>yes true
    but you need encourage mr aqui for her effort
    sorry for bad english
    good luck for all
    Remove SIM-lock patch generator v2.2 TOMM Sony Ericsson 3 04-14-2009 10:30
    A300 Easy way to remove sim-lock Alex1234 VLSI, Conexant, Skyworks and Old Models 3 10-03-2003 18:45
    SL55 - how to remove sim-lock? MrK E-Gold Based Phones 0 07-27-2003 15:22
    need remove sim lock simens s40 p.bacler NON Siemens Brand (ODM Phones) 3 04-11-2003 21:23
    NEC 2000 SIM LOCK CODE GENERATOR Marsovec Various 0 01-06-2000 21:59
    Page generated in 3.27243 seconds with 12 queries
