Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Ericsson
Sony Ericsson
  • ARM Inside: A3618,R600,T100,T100c,T102,T105,T106,Z200,J200,J200i,J200c, J210,J220,230,Z300 etc.
  • AVR Inside: R520,T200,T202,T226,T226m,T226s,T230,T237,T238,T290,T290a,T290c,T290i, T300,T302,T306,T310,T312,T316,T39,T65,T68,T610,T616,T618,T628,T630,T637,P800,P802, P900,P908,P910,Z600,Z608.
  • New ARM Inside (SEMC):D750,F500,J300,K300,K310,K500,K506c,K508,K510,K600,K608,K610,K700,K750,K790,M600, P990,S700,S710,W300,W550,W600,W700,W800,W810,W900,V600,V630,V800,Z1010,Z300,Z500,Z520,Z530,Z550,Z800.
  • CR 16B Inside:T66,T600,T600c,T602.
  • ODM:J100.
  • C Series: C510, C702, C901, C902, C903, C905
  • G Series: G502, G705
  • K Series: K630, K660, K850
  • T Series: T700, T707, T715
  • V Series: V640
  • W Series: W508, W595, W705, W715, W760, W890, W902, W910, W980, W995
  • Z Series: Z750, Z770, Z780
  • Reply
    Old 12-20-2012, 09:50   #1 (permalink)
    Member: 1360145
    Thanks Meter: 12
    W300 error help
    I got W300 in white screen blinking problem.
    So tried to flash it but i had no right cid file so i put it in recovery mode to change cid.
    Now phone is in developer mode and not on.
    Help me fix this
    PHONE STATE: "DEVELOPER"
    FLASH CID: 0051
    Speed:115200
    FLASH ID: 897E
    OTP: LOCKED:1 CID:49 PAF:1 IMEI:35424401476645 CERT:BROWN
    FLASH CID:51 COLOR:BROWN
    setGDFS_params failed
    failed to setup GDFS
    Elapsed: 21 secs.
    FLASH CID: 0051
    Speed:115200
    LDRB2010_RESPIN_PRODLOADER_SETOOL2
    FLASH ID: 897E
    writing "D:\Backup\Firmware\Sonyericssion\Flash files\GDFS\w300_gdfs\w300.ssw"
    CURRENT FLASH FILE CID:49
    Converting firmware...
    SSW uses dynamic hash, dynamic hash len is: 5
    Will flash 5 blocks...
    subblock 000 NAK, [44140000/000080E8]
    Elapsed: 22 secs.
    I got this error while this steps
    that is so-called reset procedure.
    1. go to emptyboard tab
    2. select proper model
    3. on settings, check "signed mode"
    4. press recovery
    5. after succeful recovery
    6. on settings uncheck all
    7. if gdfs totally damaged, add to firmware area proper gdfs in ssw format,otherwise skip that step
    8. add to firmware area proper EROM (EROM CID >= OTP CID)
    9. press flash
    10. if needed,reflash phone on usual semc tab with needed settings.
    Provide solution...
    Old 12-20-2012, 11:32   #2 (permalink)
    Super Moderator
    THE CLASH's Avatar
    Member: 173077
    Sonork: 100.1594293
    Thanks Meter: 2,784
    flash red erom to it.. this will make it retail..
    Page generated in 0.18773 seconds with 8 queries
