Setool Lite question. What does 'HDR block not accpeted' mean? Hi there, I'm trying to flash my phone but I'm having no joy. Whenever I try using Setool Lite I get an error message at the end 'HDR block not accepted'. My phone is a D750i. I also tried to use GSlide and XS++ to flash it but that didn't work either. Can someone help me out please and tell me what might be going wrong? Thanks Setool Lite log: Open COM port OK ChipID:8040,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:49 Speed:115200 Trying to launch embedded bootloader... Embedded flashloader: COMPACT_ID_LOADER_CRIPPLED_SETOOL2_R2 Flash ID check:200D Flash props sent ok FOUND: R1BC002_CXC1250092_EU_1_CA Restore from:R1BC002_CXC1250092_EU_1_CA CSloader version: COMPACT_SEMC_FS_LOADER_SETOOL2 LITE loader startup: executed loader filesystem startup: executed loader GDFS startup: executed Flashing upgrade archive:D:\Firmware\D750\D750_R1BC002_MAIN_EU_1_1_ CL_RED49\D750_R1BC002_MAIN_EU_1_1_CL_RED49.mbn CURRENT FLASH FILE CID:49 HDR block not accepted. (1/0),error:01FF Elapsed:146 secs. |
Try it with USB Cable ... |
Hi thanks for replying, I am using a Fighter cable which is USB and RJ45, isn't that just the same? |
Use the dcu-60 cable... |
Hi thanks, I will get one but I don't understand why it should be different from the Fighter cable? I unlocked the phone using SEMCTOOLv8.4 with no problems. I'm only having problems trying to upgrade the firmware. Aren't both cables capable of transferring the same information from the PC to phone? |
that is for better connection;) |
dcu-60 is usb to phone (direct conexion) cable ,figther and cruiser cables are usb to serial converters. |
Code: Flashing upgrade archive:....... |
Hi, I don't know what you mean. I am loading a firmware file I downloaded and I'm sure it's correct. Why should I edit the flash file and how do I do that using Setool Lite? I can't see any edit options on it |
cannot add the flash file of k800, what happened? seetool lite?? |
setool lite support for K800 CID52? |
