Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Sony Ericsson > Sony Ericsson
Sony Ericsson
  • ARM Inside: A3618,R600,T100,T100c,T102,T105,T106,Z200,J200,J200i,J200c, J210,J220,230,Z300 etc.
  • AVR Inside: R520,T200,T202,T226,T226m,T226s,T230,T237,T238,T290,T290a,T290c,T290i, T300,T302,T306,T310,T312,T316,T39,T65,T68,T610,T616,T618,T628,T630,T637,P800,P802, P900,P908,P910,Z600,Z608.
  • New ARM Inside (SEMC):D750,F500,J300,K300,K310,K500,K506c,K508,K510,K600,K608,K610,K700,K750,K790,M600, P990,S700,S710,W300,W550,W600,W700,W800,W810,W900,V600,V630,V800,Z1010,Z300,Z500,Z520,Z530,Z550,Z800.
  • CR 16B Inside:T66,T600,T600c,T602.
  • ODM:J100.
  • C Series: C510, C702, C901, C902, C903, C905
  • G Series: G502, G705
  • K Series: K630, K660, K850
  • T Series: T700, T707, T715
  • V Series: V640
  • W Series: W508, W595, W705, W715, W760, W890, W902, W910, W980, W995
  • Z Series: Z750, Z770, Z780
  • Reply
    Old 10-08-2008, 22:05   #16 (permalink)
    gsm-lord's Avatar
    Member: 7250
    Sonork: 100.1575042
    Background:
    Unfortunately due to a calibration error a batch of R306 units will show a warning message "Serious error. Stop charging. Stop using your phone. Contact a Sony Ericsson Call Centre" when fully charged.
    The cause is only a measuring problem, so there is no risk to the customer.
    Solution:
    The unit should be swapped since there is no way to fix the message with repair equipment.
    Please send these units to SBE or according instruction from your local Sony Ericsson company.
    Please see below document for the affected IMEI / Market.
    The Following 3 Users Say Thank You to gsm-lord For This Useful Post:
    Old 10-09-2008, 23:38   #17 (permalink)
    gsm-lord's Avatar
    Member: 7250
    Sonork: 100.1575042
    UKG RSI – R306 Low Battery Voltage Behaviour
    Description:
    If the battery level is 3.2V or below, the R306 can not power on by pressing power on even with the charger attached.
    Solution:
    If the R306 appear dead and do not start, keep the phone in the charger for at least 10 min and see if the charging icon appears
    Old 06-11-2011, 07:31   #18 (permalink)
    Member: 1583021
    SI-G900/G700 restart after flashing
    Information
    This is a information/clarification for G900 and G700:
    After you have flashed the units in Emma Service Client you should remove the battery and then re-insert the battery again before you restart the unit.
    If you don't do this it could happend that the unit dosn't start up.
    This effects RTL and MR1 sw on all kits.
    A solution is planned for the MR2 sw.
    This is NOT effecting P1 or W960.
    Old 02-13-2012, 07:49   #19 (permalink)
    Member: 1268620
    Sonork: bincy
    Dear sir;
    Need Arabic soft for M1i (I have setool but i don't found where is Arabic version) please you help me.
    Repair Information Document Listing By Sonyericsson SEMCSEC Sony Ericsson Hardware Repair Area 5 09-10-2009 01:37
    Beginner quastion (right software and list of mobiles) Ciux VygisToolbox 3 01-15-2008 14:42
    new software dp list mortal90210 Nokia Base Band 5 ( BB-5 ) 2 08-24-2007 10:16
    @SHA / HWK Team please check here often , because this is a Software Bug List MisterX GSMFREE HWK 2 11-17-2005 01:14
    Document listing for every GSM Phone made to date jbes Wanted Products 2 05-07-2004 10:20
    Page generated in 0.49062 seconds with 11 queries
