sony ericson z600 flsh - need help i have a z600. I tried to upgrade the firmware to lastest version R6C005. Now it has developed a fault. When i send a file to the phone by IR or BT the phone resets itself. This only happens when the phone receives files not when it sends. All other functions work fine. Need to now what flash file (AVR / ARM ) version to download from SE fighter. The Z600 is a T-mobile UK version. Here is info about the phone (if it helps) Type AAB-1021031-BV BBAAAA imei 351932008687294 ALG1PGAZ01 04W03 A3627837A R1 IC: 4170B-A1021031 FCC ID: PY7A1021031 Many thanks in advance |
what tool did u use to flash it??? |
I have same problem i flashed using div usb and still no good result may be i used the wrong flash anybody know any good link for z600 flash file???? |
hi tried flash form http://www.cellular-support.com/ :)) this flash always OK:) best regards fingusio |
thank you very much for youre etention guys. thankyou thankyou i where used the se fighter to flash z600. i have accses to se fighter site and i allready downlod some of the flash files and flash it but as i said i got problem . in fact i need to know wich flash file is the right one to solve the problem. |
