Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Ericsson
Sony Ericsson
  • ARM Inside: A3618,R600,T100,T100c,T102,T105,T106,Z200,J200,J200i,J200c, J210,J220,230,Z300 etc.
  • AVR Inside: R520,T200,T202,T226,T226m,T226s,T230,T237,T238,T290,T290a,T290c,T290i, T300,T302,T306,T310,T312,T316,T39,T65,T68,T610,T616,T618,T628,T630,T637,P800,P802, P900,P908,P910,Z600,Z608.
  • New ARM Inside (SEMC):D750,F500,J300,K300,K310,K500,K506c,K508,K510,K600,K608,K610,K700,K750,K790,M600, P990,S700,S710,W300,W550,W600,W700,W800,W810,W900,V600,V630,V800,Z1010,Z300,Z500,Z520,Z530,Z550,Z800.
  • CR 16B Inside:T66,T600,T600c,T602.
  • ODM:J100.
  • C Series: C510, C702, C901, C902, C903, C905
  • G Series: G502, G705
  • K Series: K630, K660, K850
  • T Series: T700, T707, T715
  • V Series: V640
  • W Series: W508, W595, W705, W715, W760, W890, W902, W910, W980, W995
  • Z Series: Z750, Z770, Z780
  • Reply
    Old 07-31-2004, 20:03   #1 (permalink)
    karouk's Avatar
    Member: 66478
    Thanks Meter: 6
    sony ericson z600 flsh - need help
    i have a z600. I tried to upgrade the firmware to lastest version R6C005. Now it has developed a fault. When i send a file to the phone by IR or BT the phone resets itself. This only happens when the phone receives files not when it sends. All other functions work fine.
    Need to now what flash file (AVR / ARM ) version to download from SE fighter. The Z600 is a T-mobile UK version.
    Here is info about the phone (if it helps)
    Type AAB-1021031-BV BBAAAA
    imei 351932008687294
    ALG1PGAZ01 04W03 A3627837A R1
    IC: 4170B-A1021031
    FCC ID: PY7A1021031
    Many thanks in advance
    Old 07-31-2004, 20:29   #2 (permalink)
    Member: 59089
    what tool did u use to flash it???
    Old 07-31-2004, 22:06   #3 (permalink)
    chinex14's Avatar
    Member: 30405
    Thanks Meter: 3
    I have same problem i flashed using div usb and still no good result may be i used the wrong flash anybody know any good link for z600 flash file????
    Old 07-31-2004, 22:39   #4 (permalink)
    Member: 16927
    Sonork: 100.1592866
    Thanks Meter: 133
    hi
    tried flash form http://www.cellular-support.com/ )
    this flash always OK
    best regards
    fingusio
    Old 08-01-2004, 01:05   #5 (permalink)
    karouk's Avatar
    Member: 66478
    Thanks Meter: 6
    thank you very much for youre etention guys. thankyou thankyou
    i where used the se fighter to flash z600.
    i have accses to se fighter site and i allready downlod some of the flash files and flash it but as i said i got problem .
    in fact i need to know wich flash file is the right one to solve the problem.
    Sony ericson G900 driver needed Unicom Sony Ericsson 4 04-06-2013 19:51
    Z600 flashing.. Need help!!! mash7669 Sony Ericsson 7 04-11-2005 14:41
    Sony J6 no network. need HELP!!! Kairon Sony Ericsson Hardware Repair 0 11-20-2002 01:11
    sony j6 starnge problem need HELP gsnbhagawan Sony 0 02-20-2002 07:54
    sony cmd-x2000dr i need help!!! dollyb Sony 1 08-19-2001 19:25
    Page generated in 0.23834 seconds with 8 queries
