Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | .: Nokia Unlock :. | Search | Today's Posts | Mark Forums Read |
| Sony Ericsson ARM Inside: A3618,R600,T100,T100c,T102,T105,T106,Z200,J200,J200i,J200c, J210,J220,230,Z300 etc. AVR Inside: R520,T200,T202,T226,T226m,T226s,T230,T237,T238,T290,T290a,T290c,T290i, T300,T302,T306,T310,T312,T316,T39,T65,T68,T610,T616,T618,T628,T630,T637,P800,P802, P900,P908,P910,Z600,Z608. New ARM Inside (SEMC):D750,F500,J300,K300,K310,K500,K506c,K508,K510,K600,K608,K610,K700,K750,K790,M600, P990,S700,S710,W300,W550,W600,W700,W800,W810,W900,V600,V630,V800,Z1010,Z300,Z500,Z520,Z530,Z550,Z800. CR 16B Inside:T66,T600,T600c,T602. ODM:J100. C Series: C510, C702, C901, C902, C903, C905
G Series: G502, G705
K Series: K630, K660, K850
T Series: T700, T707, T715
V Series: V640
W Series: W508, W595, W705, W715, W760, W890, W902, W910, W980, W995
Z Series: Z750, Z770, Z780 |
| | #1 (permalink) |
| Insane Poster ![]() ![]() ![]() Join Date: Jun 2006 Location: pakistan
Member: 287429 Status: Offline Thanks: 20
| sony ericsson t650 i solution hi mates i m a newbi wants to flash 1 t650 i I try my best but all in vain plz help me urgent what i have to to procedure step by step here is log and picture Code: RUNNING v 1.1204/01.14/UNI CARD SERIAL 0018 CFG:000000000000 ChipID:9900,EMP protocol:0301 Speed:921600 LDR:071130 1150 NPACXC1250330_DB2020_PRODUCTIONIDLOADER_P3M FLASH ID: 897E OTP LOCKED:1 CID:51 PAF:1 IMEI:35796601602734 ACTIVE CID:49 COLOR:BROWN no ack during gdfs_readvar ! SCRC READ FAILURE Elapsed: 20 secs. CFG:000000000000 ChipID:9900,EMP protocol:0301 Speed:921600 LDR:071130 1150 NPACXC1250330_DB2020_PRODUCTIONIDLOADER_P3M OTP LOCKED:1 CID:51 PAF:1 IMEI:35796601602734 ACTIVE CID:49 COLOR:BROWN LDR:DB2020 SERVICE LOADER FOR SETOOL2 FLASH ID: 897E writing "D:\MOBILE\SE TOOL\SE TOOL\main\1.1204\eroms\db2020\DB2020EROM_CNV_RED52_BROWN_CID49_DB2020.ssw" CURRENT FLASH FILE CID: 49 SSW uses full hash, hash len is: 40 Will flash 2 blocks ... Setting up GDFS ... OTP WRITE NOT EXECUTED packet not acknowledged (20) No ack during gdfsWrite command. SCRC WRITE FAILURE FINALIZATION FAILED. Elapsed: 44 secs. CFG:000000000000 PROCEDURE WAS STOPPED BY USER FAILED TO SETUP PHONE Elapsed: 22 secs. CFG:000000000000 ChipID:9900,EMP protocol:0301 Speed:921600 LDR:071130 1150 NPACXC1250330_DB2020_PRODUCTIONIDLOADER_P3M OTP LOCKED:1 CID:51 PAF:1 IMEI:35796601602734 ACTIVE CID:52 COLOR:RED PHONE CID NOT SUPPORTED IN THAT MODE Elapsed: 21 secs. SIGNED MODE (USING SERVER) CFG:101110000000 ChipID:9900,EMP protocol:0301 Speed:921600 LDR:071130 1150 NPACXC1250330_DB2020_PRODUCTIONIDLOADER_P3M OTP LOCKED:1 CID:51 PAF:1 IMEI:35796601602734 ACTIVE CID:52 COLOR:RED LDR:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 FLASH ID: 897E writing "D:\MOBILE\SE TOOL\SE TOOL\main\FLASH FILES\t650 i\New Folder\CID53\T650-CID-RED-53-R8BC004-M_EAST_N_AFR-SETOOL\R8BC004_1200-2562_GENERIC_SN.ssw" CURRENT FLASH FILE CID: 53 SSW uses full hash, hash len is: 9200 HDR block not accepted,error: 19 Elapsed: 35 secs. SIGNED MODE (USING SERVER) CFG:101110000000 ChipID:9900,EMP protocol:0301 Speed:921600 LDR:071130 1150 NPACXC1250330_DB2020_PRODUCTIONIDLOADER_P3M OTP LOCKED:1 CID:51 PAF:1 IMEI:35796601602734 ACTIVE CID:52 COLOR:RED LDR:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 FLASH ID: 897E writing "D:\MOBILE\SE TOOL\SE TOOL\main\FLASH FILES\t650 i\New Folder\cid 52\T650_R8BC004_MAIN_GENERIC_SN_RED52.mbn" CURRENT FLASH FILE CID: 52 SSW uses full hash, hash len is: 9200 Will flash 460 blocks ... subblock 001 NAK, [44270000/00010000] Elapsed: 39 secs. SIGNED MODE (USING SERVER) CFG:101110000000 PROCEDURE WAS STOPPED BY USER FAILED TO SETUP PHONE Elapsed: 9 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:111110000000 ChipID:9900,EMP protocol:0301 Speed:921600 LDR:071130 1150 NPACXC1250330_DB2020_PRODUCTIONIDLOADER_P3M OTP LOCKED:1 CID:51 PAF:1 IMEI:35796601602734 ACTIVE CID:52 COLOR:RED LDR:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 FLASH ID: 897E LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 GDFS startup failed,error is 04 [1D] loader GDFS startup failed, that is fatal Elapsed: 14 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:111110000000 ChipID:9900,EMP protocol:0301 Speed:921600 err: bad answer [00] FAILED TO SETUP PHONE Elapsed: 10 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:111110000000 ChipID:9900,EMP protocol:0301 Speed:921600 LDR:071130 1150 NPACXC1250330_DB2020_PRODUCTIONIDLOADER_P3M OTP LOCKED:1 CID:51 PAF:1 IMEI:35796601602734 ACTIVE CID:52 COLOR:RED LDR:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 FLASH ID: 897E LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 GDFS startup failed,error is 04 [1D] loader GDFS startup failed, that is fatal Elapsed: 21 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:111110000000 ChipID:9900,EMP protocol:0301 Speed:921600 LDR:071130 1150 NPACXC1250330_DB2020_PRODUCTIONIDLOADER_P3M OTP LOCKED:1 CID:51 PAF:1 IMEI:35796601602734 ACTIVE CID:52 COLOR:RED LDR:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 FLASH ID: 897E LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 GDFS startup failed,error is 04 [1D] loader GDFS startup failed, that is fatal Elapsed: 37 secs. CFG:001110000000 ChipID:9900,EMP protocol:0301 Speed:921600 LDR:071130 1150 NPACXC1250330_DB2020_PRODUCTIONIDLOADER_P3M OTP LOCKED:1 CID:51 PAF:1 IMEI:35796601602734 ACTIVE CID:52 COLOR:RED PHONE CID NOT SUPPORTED IN THAT MODE Elapsed: 10 secs. ALTERNATIVE SECURITY BYPASS ENABLED CFG:011110000000 ChipID:9900,EMP protocol:0301 Speed:921600 STARTING BOOTLOADER ... PROCEDURE WAS STOPPED BY USER FLASHLOADER NOT RESPONDING Elapsed: 143 secs. ALTERNATIVE SECURITY BYPASS ENABLED CFG:011110000000 Will write GDFS now. ChipID:9900,EMP protocol:0301 Speed:921600 STARTING BOOTLOADER ... PROCEDURE WAS STOPPED BY USER FLASHLOADER NOT RESPONDING Elapsed: 72 secs. SIGNED MODE (USING SERVER) CFG:101110000000 Will write GDFS now. ChipID:9900,EMP protocol:0301 Speed:921600 LDR:071130 1150 NPACXC1250330_DB2020_PRODUCTIONIDLOADER_P3M OTP LOCKED:1 CID:51 PAF:1 IMEI:35796601602734 ACTIVE CID:52 COLOR:RED LDR:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 FLASH ID: 897E LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 GDFS startup failed,error is 04 [1D] loader GDFS startup failed, that is fatal Elapsed: 39 secs. SIGNED MODE (USING SERVER) CFG:101110000000 RESET MODE STARTED PROCEDURE WAS STOPPED BY USER Elapsed: 13 secs. CFG:000000000000 RECOVERY MODE STARTED ChipID:9900,EMP protocol:0301 Speed:921600 err: bad answer [00] All possible recovery loaders failed. That phone not supported Elapsed: 11 secs. CFG:000000000000 RECOVERY MODE STARTED ChipID:9900,EMP protocol:0301 Speed:921600 err: bad answer [00] All possible recovery loaders failed. That phone not supported Elapsed: 1 secs. CFG:000000000000 RECOVERY MODE STARTED ChipID:9900,EMP protocol:0301 Speed:921600 err: bad answer [00] All possible recovery loaders failed. That phone not supported Elapsed: 1 secs. CFG:000000000000 RECOVERY MODE STARTED ChipID:9900,EMP protocol:0301 Speed:921600 err: bad answer [00] All possible recovery loaders failed. That phone not supported Elapsed: 8 secs. CFG:000000000000 RECOVERY MODE STARTED ChipID:9900,EMP protocol:0301 Speed:921600 REC:070703 1229 NPA4_CXC1329130_DB2020_SEMC_RECOVERY_P3N CHECKING OTP ... OTP LOCKED:1 CID:51 PAF:1 IMEI:35796601602734 can't open file "frec\db2020_browncid52.bin" RECOVERY FAILED. Elapsed: 1 secs. SIGNED MODE (USING SERVER) CFG:100000000000 RESET MODE STARTED ChipID:9900,EMP protocol:0301 Speed:921600 RESET:070703 1106 NPACXC1250329_DB2020_CERTRESETLOADER_P3AA FLASH ID: 897E GOT SEED:687E3F9B23804E7615E02693 P96 AUTH PASSED OTP LOCKED:1 CID:51 PAF:1 IMEI:35796601602734 PHONE SUCCESSFULLY RESET TO DEVELOPER STATE Elapsed: 23 secs. CFG:000000000000 ChipID:9900,EMP protocol:0301 Speed:921600 err: bad answer [00] CAN'T LOAD IDENTIFICATION LOADER. Elapsed: 2 secs. CFG:000000000000 ChipID:9900,EMP protocol:0301 Speed:921600 LDR:071130 1150 NPACXC1250330_DB2020_PRODUCTIONIDLOADER_P3M FLASH ID: 897E OTP LOCKED:1 CID:51 PAF:1 IMEI:35796601602734 ACTIVE CID:49 COLOR:BROWN no ack during gdfs_readvar ! SCRC READ FAILURE Elapsed: 2 secs. CFG:000000000000 ChipID:9900,EMP protocol:0301 Speed:921600 LDR:071130 1150 NPACXC1250330_DB2020_PRODUCTIONIDLOADER_P3M OTP LOCKED:1 CID:51 PAF:1 IMEI:35796601602734 ACTIVE CID:49 COLOR:BROWN LDR:DB2020 SERVICE LOADER FOR SETOOL2 FLASH ID: 897E writing "D:\MOBILE\SE TOOL\SE TOOL\main\1.1204\eroms\db2020\DB2020EROM_CNV_RED51_BROWN_CID49_DB2020.ssw" CURRENT FLASH FILE CID: 49 SSW uses full hash, hash len is: 80 Will flash 4 blocks ... Setting up GDFS ... OTP WRITE NOT EXECUTED packet not acknowledged (20) No ack during gdfsWrite command. SCRC WRITE FAILURE FINALIZATION FAILED. Elapsed: 43 secs. CFG:000000000000 ChipID:9900,EMP protocol:0301 Speed:921600 err: bad answer [00] CAN'T LOAD IDENTIFICATION LOADER. Elapsed: 12 secs. CFG:000000000000 ChipID:9900,EMP protocol:0301 Speed:921600 err: bad answer [00] CAN'T LOAD IDENTIFICATION LOADER. Elapsed: 9 secs. CFG:000000000000 ChipID:9900,EMP protocol:0301 Speed:921600 err: bad answer [00] CAN'T LOAD IDENTIFICATION LOADER. Elapsed: 1 secs. CFG:000000000000 ChipID:9900,EMP protocol:0301 Speed:921600 LDR:071130 1150 NPACXC1250330_DB2020_PRODUCTIONIDLOADER_P3M FLASH ID: 897E OTP LOCKED:1 CID:51 PAF:1 IMEI:35796601602734 ACTIVE CID:51 COLOR:RED can't get packet start. setGDFS_params failed failed to setup GDFS Elapsed: 40 secs. SIGNED MODE (USING SERVER) CFG:100000000000 file "gdfs.bin" can't be found or opened Elapsed: 0 secs. CFG:000000000000 file "" can't be found or opened Elapsed: 0 secs. CFG:000000000000 Will write GDFS now. ChipID:9900,EMP protocol:0301 Speed:921600 err: bad answer [00] FAILED TO SETUP PHONE Elapsed: 3 secs. CFG:000000000000 Will write GDFS now. ChipID:9900,EMP protocol:0301 Speed:921600 LDR:071130 1150 NPACXC1250330_DB2020_PRODUCTIONIDLOADER_P3M OTP LOCKED:1 CID:51 PAF:1 IMEI:35796601602734 ACTIVE CID:51 COLOR:RED PHONE CID NOT SUPPORTED IN THAT MODE Elapsed: 33 secs. CFG:000000000000 Will write GDFS now. ChipID:9900,EMP protocol:0301 Speed:921600 LDR:071130 1150 NPACXC1250330_DB2020_PRODUCTIONIDLOADER_P3M OTP LOCKED:1 CID:51 PAF:1 IMEI:35796601602734 ACTIVE CID:51 COLOR:RED PHONE CID NOT SUPPORTED IN THAT MODE Elapsed: 10 secs. SIGNED MODE (USING SERVER) CFG:101110000000 Will write GDFS now. ChipID:9900,EMP protocol:0301 Speed:921600 err: bad answer [00] FAILED TO SETUP PHONE Elapsed: 9 secs. SIGNED MODE (USING SERVER) CFG:101110000000 Will write GDFS now. ChipID:9900,EMP protocol:0301 Speed:921600 LDR:071130 1150 NPACXC1250330_DB2020_PRODUCTIONIDLOADER_P3M OTP LOCKED:1 CID:51 PAF:1 IMEI:35796601602734 ACTIVE CID:51 COLOR:RED LDR:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 FLASH ID: 897E LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 GDFS startup failed,error is 04 [1D] loader GDFS startup failed, that is fatal Elapsed: 13 secs. SIGNED MODE (USING SERVER) CFG:101000000000 Will write GDFS now. ChipID:9900,EMP protocol:0301 Speed:921600 err: bad answer [00] FAILED TO SETUP PHONE Elapsed: 12 secs. SIGNED MODE (USING SERVER) CFG:101000000000 Will write GDFS now. ChipID:9900,EMP protocol:0301 Speed:921600 LDR:071130 1150 NPACXC1250330_DB2020_PRODUCTIONIDLOADER_P3M OTP LOCKED:1 CID:51 PAF:1 IMEI:35796601602734 ACTIVE CID:51 COLOR:RED LDR:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 FLASH ID: 897E LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 GDFS startup failed,error is 04 [1D] loader GDFS startup failed, that is fatal Elapsed: 14 secs. SIGNED MODE (USING SERVER) CFG:101000000000 Will backup GDFS now. ChipID:9900,EMP protocol:0301 Speed:921600 LDR:071130 1150 NPACXC1250330_DB2020_PRODUCTIONIDLOADER_P3M OTP LOCKED:1 CID:51 PAF:1 IMEI:35796601602734 ACTIVE CID:51 COLOR:RED LDR:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 FLASH ID: 897E A1_loader_on_loader:payload block 197 NAK Loader uploading failed,exiting Elapsed: 15 secs. ALTERNATIVE SECURITY BYPASS ENABLED CFG:011110000000 Will write GDFS now. ChipID:9900,EMP protocol:0301 Speed:921600 STARTING BOOTLOADER ... PROCEDURE WAS STOPPED BY USER FLASHLOADER NOT RESPONDING Elapsed: 102 secs. CFG:000000000000 file "gdfs.bin" can't be found or opened Elapsed: 0 secs. CFG:000000000000 file "gdfs.bin" can't be found or opened Elapsed: 0 secs. CFG:000000000000 Will write GDFS now. ChipID:9900,EMP protocol:0301 Speed:921600 err: bad answer [00] FAILED TO SETUP PHONE Elapsed: 5 secs. CFG:000000000000 Will write GDFS now. ChipID:9900,EMP protocol:0301 Speed:921600 err: bad answer [00] FAILED TO SETUP PHONE Elapsed: 1 secs. CFG:000000000000 Will write GDFS now. ChipID:9900,EMP protocol:0301 Speed:921600 LDR:071130 1150 NPACXC1250330_DB2020_PRODUCTIONIDLOADER_P3M OTP LOCKED:1 CID:51 PAF:1 IMEI:35796601602734 ACTIVE CID:51 COLOR:RED PHONE CID NOT SUPPORTED IN THAT MODE Elapsed: 17 secs. SIGNED MODE (USING SERVER) CFG:100000000000 RESET MODE STARTED ChipID:9900,EMP protocol:0301 Speed:921600 err: bad answer [00] Elapsed: 24 secs. SIGNED MODE (USING SERVER) CFG:100000000000 RESET MODE STARTED ChipID:9900,EMP protocol:0301 Speed:921600 RESET:070703 1106 NPACXC1250329_DB2020_CERTRESETLOADER_P3AA FLASH ID: 897E GOT SEED:6F04F09C23804E7615E02693 P96 AUTH PASSED OTP LOCKED:1 CID:51 PAF:1 IMEI:35796601602734 PHONE SUCCESSFULLY RESET TO DEVELOPER STATE Elapsed: 4 secs. ALTERNATIVE SECURITY BYPASS ENABLED CFG:011110000000 ChipID:9900,EMP protocol:0301 Speed:921600 err: bad answer [00] Elapsed: 5 secs. ALTERNATIVE SECURITY BYPASS ENABLED CFG:011110000000 ChipID:9900,EMP protocol:0301 Speed:921600 STARTING BOOTLOADER ... PROCEDURE WAS STOPPED BY USER FLASHLOADER NOT RESPONDING Elapsed: 31 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:111110000000 ChipID:9900,EMP protocol:0301 Speed:921600 LDR:071130 1150 NPACXC1250330_DB2020_PRODUCTIONIDLOADER_P3M OTP LOCKED:1 CID:51 PAF:1 IMEI:35796601602734 ACTIVE CID:49 COLOR:BROWN LDR:DB2020 SERVICE LOADER FOR SETOOL2 FLASH ID: 897E writing "D:\MOBILE\SE TOOL\SE TOOL\main\FLASH FILES\t650 i\New Folder\CID53\T650-CID-RED-53-R8BC004-M_EAST_N_AFR-SETOOL\R8BC004_1200-2562_GENERIC_SN.ssw" CURRENT FLASH FILE CID: 53 SSW uses full hash, hash len is: 9200 HDR block not accepted,error: 19 Elapsed: 20 secs. CFG:001110000000 ChipID:9900,EMP protocol:0301 Speed:921600 err: bad answer [00] FAILED TO SETUP PHONE Elapsed: 4 secs. CFG:001110000000 ChipID:9900,EMP protocol:0301 Speed:921600 LDR:071130 1150 NPACXC1250330_DB2020_PRODUCTIONIDLOADER_P3M OTP LOCKED:1 CID:51 PAF:1 IMEI:35796601602734 ACTIVE CID:49 COLOR:BROWN LDR:DB2020 SERVICE LOADER FOR SETOOL2 FLASH ID: 897E writing "D:\MOBILE\SE TOOL\SE TOOL\main\FLASH FILES\t650 i\New Folder\CID53\T650-CID-RED-53-R8BC004-M_EAST_N_AFR-SETOOL\R8BC004_1200-2562_GENERIC_SN.ssw" CURRENT FLASH FILE CID: 53 SSW uses full hash, hash len is: 9200 HDR block not accepted,error: 19 Elapsed: 17 secs. SIGNED MODE (USING SERVER) CFG:101000000000 ChipID:9900,EMP protocol:0301 Speed:921600 err: bad answer [00] FAILED TO SETUP PHONE Elapsed: 11 secs. SIGNED MODE (USING SERVER) CFG:101000000000 ChipID:9900,EMP protocol:0301 Speed:921600 LDR:071130 1150 NPACXC1250330_DB2020_PRODUCTIONIDLOADER_P3M OTP LOCKED:1 CID:51 PAF:1 IMEI:35796601602734 ACTIVE CID:49 COLOR:BROWN LDR:DB2020 SERVICE LOADER FOR SETOOL2 FLASH ID: 897E writing "D:\MOBILE\SE TOOL\SE TOOL\main\FLASH FILES\t650 i\New Folder\CID53\T650-CID-RED-53-R8BC004-M_EAST_N_AFR-SETOOL\R8BC004_1200-2562_GENERIC_SN.ssw" CURRENT FLASH FILE CID: 53 SSW uses full hash, hash len is: 9200 HDR block not accepted,error: 19 Elapsed: 11 secs. CFG:000000000000 ChipID:9900,EMP protocol:0301 Speed:921600 LDR:071130 1150 NPACXC1250330_DB2020_PRODUCTIONIDLOADER_P3M OTP LOCKED:1 CID:51 PAF:1 IMEI:35796601602734 ACTIVE CID:49 COLOR:BROWN LDR:DB2020 SERVICE LOADER FOR SETOOL2 FLASH ID: 897E Elapsed: 6 secs. CFG:000000000000 ChipID:9900,EMP protocol:0301 Speed:921600 LDR:071130 1150 NPACXC1250330_DB2020_PRODUCTIONIDLOADER_P3M OTP LOCKED:1 CID:51 PAF:1 IMEI:35796601602734 ACTIVE CID:49 COLOR:BROWN LDR:DB2020 SERVICE LOADER FOR SETOOL2 FLASH ID: 897E writing "D:\MOBILE\SE TOOL\SE TOOL\main\1.1204\eroms\db2020\DB2020EROM_CNV_RED51_BROWN_CID49_DB2020.ssw" CURRENT FLASH FILE CID: 49 SSW uses full hash, hash len is: 80 Will flash 4 blocks ... Setting up GDFS ... OTP WRITE NOT EXECUTED No ack during gdfsWrite command. SCRC WRITE FAILURE FINALIZATION FAILED. Elapsed: 21 secs. CFG:000000000000 ChipID:9900,EMP protocol:0301 Speed:921600 LDR:071130 1150 NPACXC1250330_DB2020_PRODUCTIONIDLOADER_P3M OTP LOCKED:1 CID:51 PAF:1 IMEI:35796601602734 ACTIVE CID:51 COLOR:RED PHONE CID NOT SUPPORTED IN THAT MODE Elapsed: 4 secs. SIGNED MODE (USING SERVER) CFG:101110000000 ChipID:9900,EMP protocol:0301 Speed:921600 LDR:071130 1150 NPACXC1250330_DB2020_PRODUCTIONIDLOADER_P3M OTP LOCKED:1 CID:51 PAF:1 IMEI:35796601602734 ACTIVE CID:51 COLOR:RED LDR:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 FLASH ID: 897E writing "D:\MOBILE\SE TOOL\SE TOOL\main\FLASH FILES\t650 i\R8BE001_1200-2562_GENERIC_SN.ssw" CURRENT FLASH FILE CID: 53 SSW uses full hash, hash len is: 9200 HDR block not accepted,error: 19 Elapsed: 30 secs. br abu ussama Last edited by helloabuussama; 04-23-2012 at 15:47. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Solution for GSM phones!?!?!?!? | todosije | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 6 | 12-16-2010 04:52 |
| NEW ERICSSON A1018 £60 SIEMANS C25 £60 + LOADS MORE | MILLENNIUM-INTERNATIONAL | Main Sales Section | 0 | 08-31-1999 18:54 |
| !!!!!!TO ALL NOKIA 51XX/61XX SP LOCKS 1,2,3,4 SOLUTION latest news!!!!! | spterminator | Main Sales Section | 2 | 08-13-1999 05:55 |
| Anybody know solution | Robi | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 0 | 07-08-1999 09:14 |
| need ericsson 88 cable | migdamas | Old Ericsson Phones & Sony Phones | 1 | 06-02-1999 16:23 |
