sony ericsson w960i Flashing Problem RUNNING v 1.1295/01.15/UNI CARD SERIAL 00207800 USBFLASH DRIVER VERSION 03.00.00.00 SIGNED MODE (USING SERVER) CFG:101000000000 writing "C:\Documents and Settings\Danish\My Documents\Downloads\Compressed\W960i_DPY1011584_54 _Trade_Taiwan.zip" Processing package C:\Documents and Settings\Danish\My Documents\Downloads\Compressed\W960i_DPY1011584_54 _Trade_Taiwan.zip DETECTED PORTS [MASTER COM4,SLAVE COM31] PDA EROM VERSION: CXC162123 P1B Processing ISP files ISP SOFTWARE VERSION: 2.38 Flashing: 2_38_CXC162176_isp_EN_MO_Camera_Firmware.ispsoftwa re Processing ACPU files PROCESSING: Core OS FILE FLASHED OK PROCESSING: ROFS1 FILE FLASHED OK PROCESSING: ROFS1 Extension FILE FLASHED OK PROCESSING: ROFS2 FILE FLASHED OK PROCESSING: USERDATA FILE FLASHED OK PLEASE IGNORE "PRESS POWER ON" MESSAGES !!!! DETECTED PORTS [MASTER COM4,SLAVE COM31] ChipID: 7100 [RESPIN] , EMP protocol: 0301 PHONE DOMAIN: "DEVELOPER" PHONE CID: 0049 SPEED: 921600 LDR: 070410 1354 NPACXC125871_DB2000_PRODUCTIONIDLOADER_P3B OTP: LOCKED:1 CID:52 PAF:1 IMEI:35950201310841 CERT:BROWN CURRENT CID: 49 COLOR: BROWN LDR: 060529 0823 LIECXC1325712_DB2000_PRODUCTION_R1A002 Processing CCPU files PROCESSING: R5A02_CXC162175_CCPU_fs_EN_MO_Red_CID53_DB2001.sof tware CURRENT FLASH FILE CID: 53 SSW uses full hash, hash len is: 160 Will flash 8 blocks ... incorrect address [20700000/00010000] Break. Elapsed: 496 secs. Help me |
POSSIBLE PROBLEMS DB200X+NEXPERIA damaged SCRC (imei mismatch), damaged seczone, damaged gdfs,damaged CCPU EROM 1. go to emptyboard tab 2. select model 3. on settings, check "signed mode", fill login details 4. press reset, connect phone 5. if gdfs structure okay, skip that step, otherwise add to firmware are gdfs in ssw format: one of DB2001_G700_GDFS_IN_SSW_FORMAT.SSW DB2001_M600_GDFS_IN_SSW_FORMAT.ssw DB2001_P1_GDFS_IN_SSW_FORMAT.ssw DB2001_P990_GDFS_IN_SSW_FORMAT.ssw 6. add to firmware area correct EROM for m600,w950,p990: pda_ccpu_convert_red49_BROWN_CID49_DB2001.software for w960,p1: pda_ccpu_convert_red53_BROWN_CID49_DB2001.software 7. press flash 8. reflash phone on usual PDA tab if needed. phone could not boot using dcu60, erom version timeout error,etc ACPU EROM damaged, to restore it 1. select correct PDA model 2. find corresponding EROM in dist\eroms\, add it to firmware area 3. select correct com port. ufs,usb can't be used for that operation. 4. press recovery 5. connect turned off phone 6. reflash phone via USB with normal firmware S1 OPEN phone could not boot and blinks red, you CAN flash phone unlock phone using full signature unlock |
