Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Ericsson
Sony Ericsson
  • ARM Inside: A3618,R600,T100,T100c,T102,T105,T106,Z200,J200,J200i,J200c, J210,J220,230,Z300 etc.
  • AVR Inside: R520,T200,T202,T226,T226m,T226s,T230,T237,T238,T290,T290a,T290c,T290i, T300,T302,T306,T310,T312,T316,T39,T65,T68,T610,T616,T618,T628,T630,T637,P800,P802, P900,P908,P910,Z600,Z608.
  • New ARM Inside (SEMC):D750,F500,J300,K300,K310,K500,K506c,K508,K510,K600,K608,K610,K700,K750,K790,M600, P990,S700,S710,W300,W550,W600,W700,W800,W810,W900,V600,V630,V800,Z1010,Z300,Z500,Z520,Z530,Z550,Z800.
  • CR 16B Inside:T66,T600,T600c,T602.
  • ODM:J100.
  • C Series: C510, C702, C901, C902, C903, C905
  • G Series: G502, G705
  • K Series: K630, K660, K850
  • T Series: T700, T707, T715
  • V Series: V640
  • W Series: W508, W595, W705, W715, W760, W890, W902, W910, W980, W995
  • Z Series: Z750, Z770, Z780
  • Reply
    Old 01-26-2013, 07:58   #1 (permalink)
    Member: 1865785
    Sonork: 100.1638271
    Thanks Meter: 29
    sony ericsson w960i Flashing Problem
    RUNNING v 1.1295/01.15/UNI
    CARD SERIAL 00207800
    USBFLASH DRIVER VERSION 03.00.00.00
    SIGNED MODE (USING SERVER)
    CFG:101000000000
    writing "C:\Documents and Settings\Danish\My Documents\Downloads\Compressed\W960i_DPY1011584_54 _Trade_Taiwan.zip"
    Processing package
    DETECTED PORTS [MASTER COM4,SLAVE COM31]
    PDA EROM VERSION: CXC162123 P1B
    Processing ISP files
    ISP SOFTWARE VERSION: 2.38
    Flashing:
    2_38_CXC162176_isp_EN_MO_Camera_Firmware.ispsoftwa re
    Processing ACPU files
    PROCESSING: Core OS
    FILE FLASHED OK
    PROCESSING: ROFS1
    FILE FLASHED OK
    PROCESSING: ROFS1 Extension
    FILE FLASHED OK
    PROCESSING: ROFS2
    FILE FLASHED OK
    PROCESSING: USERDATA
    FILE FLASHED OK
    PLEASE IGNORE "PRESS POWER ON" MESSAGES !!!!
    ChipID: 7100 [RESPIN] , EMP protocol: 0301
    PHONE DOMAIN: "DEVELOPER"
    PHONE CID: 0049
    SPEED: 921600
    LDR: 070410 1354 NPACXC125871_DB2000_PRODUCTIONIDLOADER_P3B
    OTP: LOCKED:1 CID:52 PAF:1 IMEI:35950201310841 CERT:BROWN
    CURRENT CID: 49 COLOR: BROWN
    LDR: 060529 0823 LIECXC1325712_DB2000_PRODUCTION_R1A002
    Processing CCPU files
    PROCESSING: R5A02_CXC162175_CCPU_fs_EN_MO_Red_CID53_DB2001.sof tware
    CURRENT FLASH FILE CID: 53
    SSW uses full hash, hash len is: 160
    Will flash 8 blocks ...
    incorrect address [20700000/00010000]
    Break.
    Elapsed: 496 secs.
    Help me
    Old 01-27-2013, 15:15   #2 (permalink)
    Member: 1865785
    Sonork: 100.1638271
    Thanks Meter: 29
    POSSIBLE PROBLEMS
    DB200X+NEXPERIA
    damaged SCRC (imei mismatch), damaged seczone, damaged gdfs,damaged CCPU EROM
    1. go to emptyboard tab
    2. select model
    3. on settings, check "signed mode", fill login details
    4. press reset, connect phone
    5. if gdfs structure okay, skip that step, otherwise add to firmware are gdfs in ssw format: one of
    DB2001_G700_GDFS_IN_SSW_FORMAT.SSW
    DB2001_M600_GDFS_IN_SSW_FORMAT.ssw
    DB2001_P1_GDFS_IN_SSW_FORMAT.ssw
    DB2001_P990_GDFS_IN_SSW_FORMAT.ssw
    6. add to firmware area correct EROM
    for m600,w950,p990: pda_ccpu_convert_red49_BROWN_CID49_DB2001.software
    for w960,p1: pda_ccpu_convert_red53_BROWN_CID49_DB2001.software
    7. press flash
    8. reflash phone on usual PDA tab if needed.
    phone could not boot using dcu60, erom version timeout error,etc
    ACPU EROM damaged, to restore it
    1. select correct PDA model
    2. find corresponding EROM in dist\eroms\, add it to firmware area
    3. select correct com port. ufs,usb can't be used for that operation.
    4. press recovery
    5. connect turned off phone
    6. reflash phone via USB with normal firmware
    S1 OPEN
    phone could not boot and blinks red, you CAN flash phone
    unlock phone using full signature unlock
    Page generated in 0.30691 seconds with 7 queries
