Sony Ericsson ARM Inside: A3618,R600,T100,T100c,T102,T105,T106,Z200,J200,J200i,J200c, J210,J220,230,Z300 etc. AVR Inside: R520,T200,T202,T226,T226m,T226s,T230,T237,T238,T290,T290a,T290c,T290i, T300,T302,T306,T310,T312,T316,T39,T65,T68,T610,T616,T618,T628,T630,T637,P800,P802, P900,P908,P910,Z600,Z608. New ARM Inside (SEMC):D750,F500,J300,K300,K310,K500,K506c,K508,K510,K600,K608,K610,K700,K750,K790,M600, P990,S700,S710,W300,W550,W600,W700,W800,W810,W900,V600,V630,V800,Z1010,Z300,Z500,Z520,Z530,Z550,Z800. CR 16B Inside:T66,T600,T600c,T602. ODM:J100. C Series: C510, C702, C901, C902, C903, C905
G Series: G502, G705
K Series: K630, K660, K850
T Series: T700, T707, T715
V Series: V640
W Series: W508, W595, W705, W715, W760, W890, W902, W910, W980, W995
Z Series: Z750, Z770, Z780 |
07-28-2005, 12:45 | #1 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Life's a Journey Age: 44
Member: 49495 Status: Offline Sonork: 100.9 & 100.12345 Thanks Meter: 1,026 | SONY ERICSSON Z.1010 Always Stop 63 block on 63 Block How to sloved this problam Any Help me I use This Soft 1.DaVinci Team online sarver 2.setool3 3.CRUISER PRO 4.FURIOUSBOX2 But Still Same pls pls help me i am waiting |
07-29-2005, 07:03 | #4 (permalink) | |
Member: 49495 Status: Offline Sonork: 100.9 & 100.12345 Thanks Meter: 1,026 | Quote:
How to man ??????????????????????? | |
07-31-2005, 01:22 | #6 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,785 | @sunnyc try other pc and flashing on Davinci server on 115200bps via USB cable (use FREE - Read CID option, and download adequate flashes first) if dont help, rehot flash IC and retry procedure .. if still the same ... u need to change flash IC b.r. Alexandar. |
07-31-2005, 10:02 | #7 (permalink) |
Member: 49495 Status: Offline Sonork: 100.9 & 100.12345 Thanks Meter: 1,026 | Client Version 13.23 Shortly press Power button! Detected SonyEricsson: Z1010/V800. Status Ok, OTP Close, CID29, PAF1 IMEI: 353456-00-284291 Loading Main File. Ok! Loading FS File. Ok! Flash file CID:29 Phone CID:29 Flashing 247 blocks... Last block flashing error Execution Time - 00:01:59 Error: 0x005556 |
07-31-2005, 23:28 | #10 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,785 | Hey SunnyC, why dont you do things I said ??? - Change PC, try some laptop - try Serial and USB cable - Use cracked SemcTool 2.2 and use davinci flashes (not .dvt format) and just rename extension and flash with cracked tool and after that all if still error, read again ... CHANGE FLASH IC and thats it, stop screaming here !!! b.r. Alexandar. |
10-07-2005, 04:58 | #11 (permalink) |
No Life Poster Join Date: Nov 2001 Location: Mauritius Age: 47
Member: 7482 Status: Offline Thanks Meter: 24 | please take some time to read about sunnyc so that you don't get cheated http://forum.gsmhosting.com/vbb/show...42#post1374942 |
11-11-2005, 22:35 | #12 (permalink) |
Freak Poster Join Date: Jul 2005 Age: 38
Member: 162785 Status: Offline Thanks Meter: 10 | check the battery,and use full charged battery, the same problem i have faced, and solved with another full charged battery and if not possible to charge battery you may use direct power from charger 3.6 v to phone terminals.... and enjoy |
sony ericsson T700"serious error .stop charging .stop using your phone and contact | ameerali19 | Sony Ericsson Hardware Repair | 4 | 08-05-2012 16:24 |
Cant unlock Sony-Ericsson-J132 | rajhcl0 | Infinity-Box | 3 | 03-29-2010 18:28 |
k330 sony ericsson unlock failed always......... | rajesh_ch | Infinity-Box | 2 | 11-02-2009 12:13 |
Sony Ericsson K800i *BARRED* *BLOCKED* | R33f | Sony Ericsson | 3 | 12-17-2006 03:02 |
sony ericsson z520i always vibrating | b2l80 | Sony Ericsson | 0 | 06-24-2006 09:48 |
