Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Ericsson
Sony Ericsson
  • ARM Inside: A3618,R600,T100,T100c,T102,T105,T106,Z200,J200,J200i,J200c, J210,J220,230,Z300 etc.
  • AVR Inside: R520,T200,T202,T226,T226m,T226s,T230,T237,T238,T290,T290a,T290c,T290i, T300,T302,T306,T310,T312,T316,T39,T65,T68,T610,T616,T618,T628,T630,T637,P800,P802, P900,P908,P910,Z600,Z608.
  • New ARM Inside (SEMC):D750,F500,J300,K300,K310,K500,K506c,K508,K510,K600,K608,K610,K700,K750,K790,M600, P990,S700,S710,W300,W550,W600,W700,W800,W810,W900,V600,V630,V800,Z1010,Z300,Z500,Z520,Z530,Z550,Z800.
  • CR 16B Inside:T66,T600,T600c,T602.
  • ODM:J100.
  • C Series: C510, C702, C901, C902, C903, C905
  • G Series: G502, G705
  • K Series: K630, K660, K850
  • T Series: T700, T707, T715
  • V Series: V640
  • W Series: W508, W595, W705, W715, W760, W890, W902, W910, W980, W995
  • Z Series: Z750, Z770, Z780
  • Reply
    Old 06-13-2003, 22:48   #1 (permalink)
    kingofhearts's Avatar
    Member: 8710
    Sonork: 1576303
    Thanks Meter: 197
    Sony P-800 no display and no lights? The phone is working perfect.
    Sony P-800 no display and no lights? The phone is working perfect. What's the problem?
    Old 06-17-2003, 05:18   #2 (permalink)
    Member: 8804
    Thanks Meter: 4
    check your setup menu, OR the flip switch has a problem,,,,
    Old 06-17-2003, 08:32   #3 (permalink)
    Syed's Avatar
    Member: 19979
    Thanks Meter: 116
    Re: Sony P-800 no display and no lights? The phone is working perfect.
    if you are sure that it is not hardware problem...then flash your phone again....
    Old 06-17-2003, 10:12   #4 (permalink)
    Member: 8710
    Sonork: 1576303
    Thanks Meter: 197
    How can I flash my P-800? I only have DIV. And it does'nt support the flashing for P800. Which flasher supports P800 flashing?
    Old 06-17-2003, 10:22   #5 (permalink)
    Syed's Avatar
    Member: 19979
    Thanks Meter: 116
    yes no soft support P-800 Flashing only one and that is available at www.se-fighter.com
    Old 06-18-2003, 22:16   #6 (permalink)
    Member: 8710
    Sonork: 1576303
    Thanks Meter: 197
    How to solve that problem? Shall I wait for the solution? Does any body have the GDFS files for P-800. So I can try to reset its GDFS. I think that is the same GDFS problem like before in T-68 volume.
    k850 no display and no light on lcd...!!! natlifs Sony Ericsson 12 11-22-2011 07:41
    No display and no light in Nokia 1209. SUDARSHAN PRASA Nokia Hardware & Hardware Repair 11 08-07-2011 04:15
    NOKIA 3230 when Insert the battery LCD display white light but phone is working fine tarikalikhan Nokia Hardware & Hardware Repair 14 11-07-2010 10:55
    L7 no display and no lights in display, tricks enside.. ticksjarub Motorola Hardware Repair 4 09-18-2010 17:30
    Help V6 No Display and No Light on LCD gravity06 Motorola Hardware Repair 2 01-11-2009 16:14
    Page generated in 0.16559 seconds with 10 queries
