Sony Ericsson ARM Inside: A3618,R600,T100,T100c,T102,T105,T106,Z200,J200,J200i,J200c, J210,J220,230,Z300 etc. AVR Inside: R520,T200,T202,T226,T226m,T226s,T230,T237,T238,T290,T290a,T290c,T290i, T300,T302,T306,T310,T312,T316,T39,T65,T68,T610,T616,T618,T628,T630,T637,P800,P802, P900,P908,P910,Z600,Z608. New ARM Inside (SEMC):D750,F500,J300,K300,K310,K500,K506c,K508,K510,K600,K608,K610,K700,K750,K790,M600, P990,S700,S710,W300,W550,W600,W700,W800,W810,W900,V600,V630,V800,Z1010,Z300,Z500,Z520,Z530,Z550,Z800. CR 16B Inside:T66,T600,T600c,T602. ODM:J100. C Series: C510, C702, C901, C902, C903, C905
G Series: G502, G705
K Series: K630, K660, K850
T Series: T700, T707, T715
V Series: V640
W Series: W508, W595, W705, W715, W760, W890, W902, W910, W980, W995
Z Series: Z750, Z770, Z780 |
11-07-2006, 10:16 | #47 (permalink) |
No Life Poster Join Date: Mar 2006 Location: wales uk Age: 51
Member: 240939 Status: Offline Thanks Meter: 17 | i wouldnt even attempt to use this software on a cid 49 phone.usb smart has been dead for a couple of months now and the flash loader needs to restore the phone soft after its been unlocked and as usb smart only had the earliest software on support it isnt going to be able to restore newer software on the phones.so you have been warned. |
11-19-2006, 12:05 | #50 (permalink) |
No Life Poster Join Date: Apr 2006 Location: eproom memory Age: 41
Member: 264366 Status: Offline Thanks Meter: 29 | how can i revive W810 when power on with sim it says CONFIGURATION ERROR PLEASE CONTACT SERVICE CENTRE . . . how can i solve this problem PLEASE ANYBODY HELP im using cracked semctool 8 4 |
03-14-2007, 13:35 | #52 (permalink) |
Major Poster Join Date: Feb 2007
Member: 446083 Status: Offline Thanks Meter: 9 | MY experience with SonyEricsson USB-Smart SEMC tool v8.4 cracked With the hardware of a Box, UFS-3 with I modulate updated original HWK on j210i and k300i has been quite bad, does not work Single the cable use of T-28 data from port COM, has flashed, successfully both terminal, from spot PCMCIA adapter of port COM sub9 pins With j210i, the SEMC tool v8.4 with the Repair flash from UFS -3 Tornado for this model, did not work, remained to the 100% but with failure With he himself j210i, the SEMC tool v8.4 with the Repair flash from the cable of data COM all correct one! Fail the SEMC tool v8.4? in my opinion it would say that no, which fails is the adaptation of the SEMC tool v8.4 when driver UFS-3 Con el hardware de una Box, UFS-3 con modulo HWK original actualizada sobre un j210i y un k300i ha sido bastante mala, no funciona Solo el uso de cable de datos T-28 desde el puerto COM, ha falseado, con éxito los dos terminales, desde un spot PCMCIA adaptador de puerto COM sub9 pins Con el j210i, el SEMC tool v8.4 con la flash Repair desde UFS -3 Tornado para este modelo, no funcionaba, se quedaba al 100% pero con fallo Con el mismo el j210i, el SEMC tool v8.4 con la flash Repair desde el cable de datos COM ¡todo correcto! ¿Falla el SEMC tool v8.4? en mi opinión diría que no, lo que falla es la adaptación del SEMC tool v8.4 al driver UFS-3 |
03-14-2007, 19:02 | #53 (permalink) | |
Freak Poster Join Date: Jul 2006 Location: Sweden Age: 46
Member: 312676 Status: Offline Thanks Meter: 34 | Quote:
I cant understand one line of what you are trying to type/say... | |
03-11-2009, 02:20 | #54 (permalink) | |
Crazy Poster Join Date: Nov 2006 Location: Belize
Member: 391768 Status: Offline Thanks Meter: 3 | Quote:
Semc-Tool V8.7 Cracked | TaHiR | Various | 11 | 11-16-2006 09:42 |
SEMC-Tool v8.4 FREE by OGM | multififa | Sony Ericsson | 105 | 09-28-2006 02:42 |
SEMC-Tool v8.7 cracked | aashir | Sony Ericsson | 18 | 09-26-2006 18:16 |
Cracked USB-SMART SEMC TOOL working!! | GSMsurgeon | Sony Ericsson | 67 | 06-16-2006 10:28 |
Where I can buy Usb smart semc tool V6.4? | bjzjcn | SonyEricsson (USB-Smart) | 6 | 02-16-2006 17:44 |
