Sony Ericsson ARM Inside: A3618,R600,T100,T100c,T102,T105,T106,Z200,J200,J200i,J200c, J210,J220,230,Z300 etc. AVR Inside: R520,T200,T202,T226,T226m,T226s,T230,T237,T238,T290,T290a,T290c,T290i, T300,T302,T306,T310,T312,T316,T39,T65,T68,T610,T616,T618,T628,T630,T637,P800,P802, P900,P908,P910,Z600,Z608. New ARM Inside (SEMC):D750,F500,J300,K300,K310,K500,K506c,K508,K510,K600,K608,K610,K700,K750,K790,M600, P990,S700,S710,W300,W550,W600,W700,W800,W810,W900,V600,V630,V800,Z1010,Z300,Z500,Z520,Z530,Z550,Z800. CR 16B Inside:T66,T600,T600c,T602. ODM:J100. C Series: C510, C702, C901, C902, C903, C905
G Series: G502, G705
K Series: K630, K660, K850
T Series: T700, T707, T715
V Series: V640
W Series: W508, W595, W705, W715, W760, W890, W902, W910, W980, W995
Z Series: Z750, Z770, Z780 |
12-12-2003, 22:01 | #1 (permalink) |
No Life Poster Join Date: Nov 2003 Location: Americas Age: 44
Member: 43802 Status: Offline Thanks Meter: 36 | T316 Emergency Call Only The Connect \ GSM Network \ Search Mode is set to Automatic Please assist |
12-28-2003, 09:20 | #4 (permalink) |
No Life Poster Join Date: Dec 2003 Location: Seattle, WA USA Age: 43
Member: 47173 Status: Offline Thanks Meter: 3 | Unlocking it again or master resetting it won't help. Providing the phone actually worked before you got it, the reason for "Emergency calls only" means that the network couldn't be found. Check that your network has 1800mhz service where you are... it could be that 1800mhz service is only in certain areas. By the way, what country are you in? |
C350 emergency calls only | Sam-TheMaster | Motorola Hardware Repair | 0 | 09-23-2005 08:29 |
LG 7020 emergency call only | gbada | LG | 0 | 08-26-2005 15:01 |
emergency calls only after unlock on A920 | alru111 | Smart-Clip | 3 | 08-09-2005 08:12 |
A60 Firmware v25 - Emergency calls only? | undercover_danc | E-Gold Based Phones | 0 | 05-09-2004 14:35 |
Emergency calls only | Mikebyrne000 | Sharp | 2 | 05-02-2004 22:35 |
