Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Sony Ericsson > Sony Ericsson
Sony Ericsson
  • ARM Inside: A3618,R600,T100,T100c,T102,T105,T106,Z200,J200,J200i,J200c, J210,J220,230,Z300 etc.
  • AVR Inside: R520,T200,T202,T226,T226m,T226s,T230,T237,T238,T290,T290a,T290c,T290i, T300,T302,T306,T310,T312,T316,T39,T65,T68,T610,T616,T618,T628,T630,T637,P800,P802, P900,P908,P910,Z600,Z608.
  • New ARM Inside (SEMC):D750,F500,J300,K300,K310,K500,K506c,K508,K510,K600,K608,K610,K700,K750,K790,M600, P990,S700,S710,W300,W550,W600,W700,W800,W810,W900,V600,V630,V800,Z1010,Z300,Z500,Z520,Z530,Z550,Z800.
  • CR 16B Inside:T66,T600,T600c,T602.
  • ODM:J100.
  • C Series: C510, C702, C901, C902, C903, C905
  • G Series: G502, G705
  • K Series: K630, K660, K850
  • T Series: T700, T707, T715
  • V Series: V640
  • W Series: W508, W595, W705, W715, W760, W890, W902, W910, W980, W995
  • Z Series: Z750, Z770, Z780
  • Reply
    Old 04-05-2004, 00:12   #1 (permalink)
    Member: 771
    T610_Write GDFS file problem:ERROR 4B06 at 84 %
    SonyEricsson T610 was freezing...especially when use camera...
    By search engine in this forum I found that it is possible to solve that
    problem by flashing phone with AVR and ARM files (R1L013) and
    full GDFS file.
    I flashed phone successfully with AVR and ARM file, but when I flashed with
    GDFS file process stopped at 98 % and USB DIV 3.1 patched by Laser with terminator dongle gave ERROR 4B06.
    After that I still could switch on phone. I think the phone was working better than before flashing,it was not freezing but sometimes restarting when camera is in use.
    I tried flash phone with GDFS file again but now process stopped at 84 % and
    DIV 3.1 gave ERROR 4B06 again.
    I repeated process few times but every times it stop at 84 % and give same ERROR 4B06.
    I tried with "Original" and "FullGDFS" and different is only in stop position: 84 % or 79 %
    Now, when I switch on phone I can hear boot music, display light comes on but display nothing show and phone isn't switched on.
    Any advice?
    Thanks in advance
    Regards
    Old 04-05-2004, 02:15   #2 (permalink)
    AndreS's Avatar
    Member: 36951
    Sonork: 100.63212
    try to rehot the avr chip and reflash again with full gdfs in avr format.
    if that doesnt work, i think you must change the avr chip
    br andres
    Old 04-05-2004, 05:50   #3 (permalink)
    Member: 59687
    try to use gdfs writer from Mr. Laser
    Old 04-05-2004, 11:56   #4 (permalink)
    muppet's Avatar
    Member: 42570
    Sounds like a hardware fault to me.
    Old 01-10-2005, 06:03   #5 (permalink)
    s1emens's Avatar
    Member: 40602
    @gsm-andres
    how do we write full gdfs in avr format? Is there anyway to backup this file from a healthy t610 and write it to faulty t610 with se fighter?
    regards,
    s1emens
    Old 01-10-2005, 11:02   #6 (permalink)
    onu
    onu's Avatar
    Member: 101586
    Question
    br andres
    i have the same problem. this solution is not working..... do you have another ideea?????
    Old 01-12-2005, 09:06   #7 (permalink)
    onu
    onu's Avatar
    Member: 101586
    Originally Posted by s1emens
    @gsm-andres
    regards,
    s1emens
    nothing new available for me?
    Old 01-12-2005, 16:39   #8 (permalink)
    s1emens's Avatar
    Member: 40602
    I'm looking forward to use setool and write raw gdfs directly to phone via terminator dongle. Post the result when done. But i have to look around to find terminator dongle first and also div.
    regards,
    s1emens
    Old 01-15-2005, 22:36   #9 (permalink)
    Crazy Poster
    Member: 100220
    try gdfs from different source i think gdfs file is corrupt, almost always the cause when flashing halt
    Old 01-16-2005, 00:37   #10 (permalink)
    MOBICOM's Avatar
    Member: 67805
    I allways solved problem with damaged GDFS area only with SEtool from Laser.You need to have cleangdfs.bin format SEtool which work in dos mode and Terminator dongle.
    It`s easy to use.
    WBR
    Old 01-16-2005, 03:30   #11 (permalink)
    s1emens's Avatar
    Member: 40602
    @MOBICOM
    Can you attach here cleangdfs.bin and also how to use this file correctly. Please. Cause i have 1 dead T610 stop when flashing GDFS. Thanks
    BR,
    s1emens
    Old 01-16-2005, 04:47   #12 (permalink)
    MOBICOM's Avatar
    Member: 67805
    Here is program + info for restoring GDFS.
    It`s easy you will see, but you have to find that .bin GDFS because I can`t upload here it`s too big, or someone will link you tomorow .
    WBR.
    Old 03-08-2005, 12:53   #13 (permalink)
    TheBrain's Avatar
    Member: 97899
    Can anyone help me with link to download full flashes for SonyEricsson, so I can change IMEIs also.
    10x`n`Regards
    Old 03-08-2005, 13:00   #14 (permalink)
    Unlocker AL's Avatar
    Member: 3617
    Twister have good solution for these problems
    Old 03-08-2005, 17:30   #15 (permalink)
    fonecellar's Avatar
    Member: 545165
    10x`n`Regards
    @brain hey you had better refrase and ask for REBUILD/RESTORE EMEI, I can assure you this forum has hidden eyes,
    PM for more info
    rgds
    K310 stop at 2 % on FS flashing with R4DA044 hooi76 Cruiser Suite 8 06-05-2007 15:03
    Complete stop at 50 % profdrgrga SonyEricsson (USB-Smart) 1 07-27-2006 13:12
    k608i cid49 fs stop at 20 % profdrgrga SonyEricsson (USB-Smart) 2 05-21-2006 00:27
    D500: Tfs Flash stops at ~80 % dannyogolo TST Dongle 9 07-18-2005 18:39
    Halting at 27 % and exiting in C25_1202 Flasher.Anybody has Correct one ? nightxyz x1x to x45/x50 3 02-20-2001 12:46
    Page generated in 0.34109 seconds with 12 queries
