Sony Ericsson ARM Inside: A3618,R600,T100,T100c,T102,T105,T106,Z200,J200,J200i,J200c, J210,J220,230,Z300 etc. AVR Inside: R520,T200,T202,T226,T226m,T226s,T230,T237,T238,T290,T290a,T290c,T290i, T300,T302,T306,T310,T312,T316,T39,T65,T68,T610,T616,T618,T628,T630,T637,P800,P802, P900,P908,P910,Z600,Z608. New ARM Inside (SEMC):D750,F500,J300,K300,K310,K500,K506c,K508,K510,K600,K608,K610,K700,K750,K790,M600, P990,S700,S710,W300,W550,W600,W700,W800,W810,W900,V600,V630,V800,Z1010,Z300,Z500,Z520,Z530,Z550,Z800. CR 16B Inside:T66,T600,T600c,T602. ODM:J100. C Series: C510, C702, C901, C902, C903, C905
G Series: G502, G705
K Series: K630, K660, K850
T Series: T700, T707, T715
V Series: V640
W Series: W508, W595, W705, W715, W760, W890, W902, W910, W980, W995
Z Series: Z750, Z770, Z780 |
03-19-2004, 16:11 | #3 (permalink) |
Insane Poster Join Date: Feb 2002 Location: russia-moscow
Member: 9186 Status: Offline Thanks Meter: 1 | im trying /flash full gdfs in AVR/upload some gdfs.../ flash any version sbn+arm / - after soft reset two profiles "AWS DATA" "AWS WAP" stay in phone. Phones without profiles work perfectly. |
03-19-2004, 17:03 | #4 (permalink) |
No Life Poster Join Date: Feb 2002 Location: Russia Age: 44
Member: 9519 Status: Offline Thanks Meter: 2,150 | wap profiles in arm area. you have at least two way to solve problem 1. readout full arm from "good" phone and write to "bad" - preferable way. 2. write null file 2mb size to arm area (you will lost blutooth calibration) |
03-19-2004, 17:13 | #5 (permalink) |
No Life Poster Join Date: May 1999 Location: RU
Member: 83 Status: Offline Thanks Meter: 1 | as i think, ARM is only slave for any customisation. After "Master Reset->Reset All" with decustomised GDFS custom wap profiles can go away. Also, even ir there are customized profiles for GPRS at CID=1, add new profile at CID=2 and use *99***2# for GPRS dialing. |
03-19-2004, 18:04 | #6 (permalink) |
Member: 9519 Status: Offline Thanks Meter: 2,150 | @SFlood: i talked much with one man, who has exactly same problem as beer33rus have. no any avr (even avr_in_sbn) helps, until he flashed arm with arm ,readed from "good" phone. why that problem arises ? who knows |
03-20-2004, 01:40 | #9 (permalink) |
Member: 9186 Status: Offline Thanks Meter: 1 | Correct if what not so. I converted a part of arm cpu in format ARM DIV, first 8 bytes I set to 00 00 00 01 00 00 20 00 and then 2mb binary. Flash it to phone, make full reset but it has not solved a problem ! There was last hope, today shall write bin2sbn converter and upload 8meg sbn to phone. |
after unlock ku380 bluetooth not work | Haouas | FuriousGold | 5 | 07-08-2008 14:24 |
U6 after unlock keypad does not work properly | trentini | Smart-Clip | 2 | 11-21-2006 04:07 |
o2x7 after unlock camera is not working | topydrama77 | Infinity-Box | 4 | 05-09-2006 21:35 |
after unlocking k608i joystick not working | gsmindia | Cruiser Suite | 8 | 02-01-2006 18:25 |
A60 After Unlocking Ok Key Not Working | Slider_Gsm | E-Gold Based Phones | 2 | 01-24-2005 22:44 |
