Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Sony Ericsson > Sony Ericsson
Sony Ericsson
  • ARM Inside: A3618,R600,T100,T100c,T102,T105,T106,Z200,J200,J200i,J200c, J210,J220,230,Z300 etc.
  • AVR Inside: R520,T200,T202,T226,T226m,T226s,T230,T237,T238,T290,T290a,T290c,T290i, T300,T302,T306,T310,T312,T316,T39,T65,T68,T610,T616,T618,T628,T630,T637,P800,P802, P900,P908,P910,Z600,Z608.
  • New ARM Inside (SEMC):D750,F500,J300,K300,K310,K500,K506c,K508,K510,K600,K608,K610,K700,K750,K790,M600, P990,S700,S710,W300,W550,W600,W700,W800,W810,W900,V600,V630,V800,Z1010,Z300,Z500,Z520,Z530,Z550,Z800.
  • CR 16B Inside:T66,T600,T600c,T602.
  • ODM:J100.
  • C Series: C510, C702, C901, C902, C903, C905
  • G Series: G502, G705
  • K Series: K630, K660, K850
  • T Series: T700, T707, T715
  • V Series: V640
  • W Series: W508, W595, W705, W715, W760, W890, W902, W910, W980, W995
  • Z Series: Z750, Z770, Z780
  • Reply
    Old 07-14-2003, 11:07   #1 (permalink)
    Member: 6054
    T68i 'Charging Only' after Water Damage
    Recently cleaned a water damaged T68i. After cleaning was completed i tried to turn the phone on. No go. Assumption was the battery was flat. Plugged in charger and the phone said 'Charging Only'. Assumed phone was good to go again. After charging was completed i tried to turn on the phone but nothing happened. Plugged in charfer again and 'Charging Only' came up again. I dont know what this is, but is the phone telling me it has a error? Any suggestions on how to get it going again?
    Many Thanks
    BEEF
    Old 07-23-2003, 18:48   #2 (permalink)
    Acidmrp's Avatar
    Member: 15315
    nearly same problem here, T68i after washing first it was ok
    and the bad user didn't remove the batterie then two days later
    it was dead. So I've cleaned it really good. But the battery is still
    dead. If I supply it external everything works. I gonna buy an new
    battery. And ask the bad user if I can diassemble the old one. On
    x-ray analyse I can't see the damage.
    Old 07-23-2003, 19:01   #3 (permalink)
    Moderator
    Syed's Avatar
    Member: 19979
    flash the phone again and your phone will power on again but most probably you will end up with "Insert Correct Sim" with 4 locks closed....
    WBR
    Syed
    Old 07-24-2003, 03:24   #4 (permalink)
    Blartiartfast's Avatar
    Member: 4611
    Had a few of these, and they just needed the power button contacts cleaning with a fibreglass pen (the contacts looked fine)
    Old 07-24-2003, 04:35   #5 (permalink)
    Acidmrp's Avatar
    Member: 15315
    I've tested the battery, the maximum output current is 5mA the
    output voltage is ok, it's 3,65V
    Nokia 3110 no backlight and ring after water damage Chuk Nokia Hardware & Hardware-Repair Area 7 12-22-2008 09:10
    lost ringer after water damage 3330 m1dzb Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 4 10-05-2002 16:01
    c30 can't charge after water damaged. hooi76 Hardware Repair by brands 0 03-20-2002 12:16
    Nokia 3310 Can't On After Water Damage Williamcwy Nokia Hardware & Hardware-Repair Area 3 02-04-2002 05:26
    V.50 not charging after water damage bluelights Old Legacy Motorola (EMMI) 0 01-07-2002 17:25
    Page generated in 0.40034 seconds with 11 queries
