Sony Ericsson ARM Inside: A3618,R600,T100,T100c,T102,T105,T106,Z200,J200,J200i,J200c, J210,J220,230,Z300 etc. AVR Inside: R520,T200,T202,T226,T226m,T226s,T230,T237,T238,T290,T290a,T290c,T290i, T300,T302,T306,T310,T312,T316,T39,T65,T68,T610,T616,T618,T628,T630,T637,P800,P802, P900,P908,P910,Z600,Z608. New ARM Inside (SEMC):D750,F500,J300,K300,K310,K500,K506c,K508,K510,K600,K608,K610,K700,K750,K790,M600, P990,S700,S710,W300,W550,W600,W700,W800,W810,W900,V600,V630,V800,Z1010,Z300,Z500,Z520,Z530,Z550,Z800. CR 16B Inside:T66,T600,T600c,T602. ODM:J100. C Series: C510, C702, C901, C902, C903, C905
G Series: G502, G705
K Series: K630, K660, K850
T Series: T700, T707, T715
V Series: V640
W Series: W508, W595, W705, W715, W760, W890, W902, W910, W980, W995
Z Series: Z750, Z770, Z780 |
08-07-2003, 13:39 | #1 (permalink) |
No Life Poster Join Date: May 2003 Location: POLAND
Member: 27761 Status: Offline Thanks Meter: 55 | T68i FREZZing after flash by DIV6.2 cracked I have T68i orginaly flash ver was R2A006 after flash by DIV6.2 CRACKED to ver T68I_EMEA1_R7A013.SBN phone frezzing if i press "My Shortcuts" button or if i select menu: WAP or COMMUNICATION All function is OK, i can make call's, ring tones OK, 4 locks open, ... etc. only frezzing with abouve What happend? is this a phone microchip failure or wrong flash. flash was taken from CD of DIV7 i need help |
08-09-2003, 02:58 | #4 (permalink) | |
No Life Poster Join Date: Sep 2002 Location: Portugal
Member: 15312 Status: Offline Sonork: 100.1576041 Thanks Meter: 1,097 | Quote:
08-09-2003, 13:08 | #7 (permalink) |
Member: 27761 Status: Offline Thanks Meter: 55 | i use: T68i_Modem_R2A014.arm T68i_Modem_R2B025.arm T68i_Modem_R2F004.arm T68i_Modem_R5C001.arm T68i_Modem_R5D007.arm T68i_Modem_R6A012.arm T68i_Modem_R6A012.arm T68i_Modem_R7A005.arm T68i_Modem_R7A013.arm with AVR: T68i_EMEA1_R7A013.sbn and always error 3608 (see picture in link http://www.psg.neostrada.pl/gsm/div62_t68i.jpg) who know the answer? NEED HELP ! |
08-09-2003, 13:54 | #8 (permalink) |
No Life Poster Join Date: Jul 2001 Location: London, UK
Member: 5324 Status: Offline Thanks Meter: 7 | i would suggest getting SE_Fighter as this software is 10000 times better than DIV.... but if it is only one phone you have then, try to flash and older firmware version into the phone, try and use win 200 or win XP as 98(se) has a few issues with flashing ericsson phones, my experience with div is that sometimes you must flash the phone several times before it will be operational, make sure battery is fully charged. Also make sure the bottom of the phones connectors are cleaned well as this is alot of the time a reason for bad contact with cable contact me if you need an older AVR and ARM file regards nick |
08-09-2003, 18:03 | #10 (permalink) |
No Life Poster Join Date: Dec 2001 Location: [winscard.SCardTransmit]
Member: 8023 Status: Offline Thanks Meter: 13 | FORGET THIS. DIV (EMMA) uses incremental linear erase-before-write method for flashing AVR flash. However, for ARM flash, it uses erase first (that is done in the first 1%, this is why it is the longest percent) then write the whole area (because in ARM no reusable data like GDFS present). If you get an error after 1% when flashing ARM, it means an error occured during flash erase process (blank check). Two cases: The power current was weak for flash erasement procedure. This means even your power supply is damaged (rare), or the battery itself is CRAP or NOT FULLY CHARGED. Try to fully charge your battery first (overnight), then never ever suppose a battery seemingly halfway charged would be enough for such a process. The flash chip is dissolved from PCB. Use a hot air station to resolder it (do not try to remove it if you are not experienced enough, onry heat it a bit, maybe with some flux). Regards crusher |
08-09-2003, 18:07 | #11 (permalink) | |
Well few days ago I flashed AVR R4A008, and then writed a AVR R4B008 into a T39m, and works ok. When I see his sw info, he says that has AVR R4A008 and ARM also R4A008. So I guess the problem might be if u try an ARM with other termination. Oh and might work ok anyway, because these days I only flashed AVR R7A013 into a T68i with R2 and after flashed just AVR R7 he worked fine. So I guess that depens on something else... | |
08-09-2003, 19:16 | #12 (permalink) |
No Life Poster Join Date: Dec 2000 Location: gsmdoctor.pl Age: 48
Member: 2755 Status: Offline Thanks Meter: 42 | I agree with crusher - I had the same problem - error after 1% ARM Flashing. (I guessed that was a problem with flash erasing - many experience with old T10 .. So I desoldered Flash chip, resoldered again and problem disappered ... So maybe people from SE factory should better check Motherboards quality ... ? |
Where I Can Find Div6.2 CRACK | DJ_Andy | Sony Ericsson | 7 | 06-09-2003 20:16 |
