Go Back   GSM-Forum > GSM Mobile Brands -Software Area- > SonyEricsson > SonyEricsson
SonyEricsson
  • ARM Inside: A3618,R600,T100,T100c,T102,T105,T106,Z200,J200,J200i,J200c, J210,J220,230,Z300 etc.
  • AVR Inside: R520,T200,T202,T226,T226m,T226s,T230,T237,T238,T290,T290a,T290c,T290i, T300,T302,T306,T310,T312,T316,T39,T65,T68,T610,T616,T618,T628,T630,T637,P800,P802, P900,P908,P910,Z600,Z608.
  • New ARM Inside (SEMC):D750,F500,J300,K300,K310,K500,K506c,K508,K510,K600,K608,K610,K700,K750,K790,M600, P990,S700,S710,W300,W550,W600,W700,W800,W810,W900,V600,V630,V800,Z1010,Z300,Z500,Z520,Z530,Z550,Z800.
  • CR 16B Inside:T66,T600,T600c,T602.
  • ODM:J100.
  • Reply
    Old 10-17-2003, 09:14   #1 (permalink)
    Member: 20027
    T68i problem after flashing!!!
    Help!
    T68i and DIV8.4
    After flashing t68i with t68i full GDFS in avr format -> result: bad colors, bad contrast, no pictures and 4 locks closed.
    How repair this???
    Thank's!
    Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!Share on FacebookTwitter
    Old 10-17-2003, 09:52   #2 (permalink)
    AndreS's Avatar
    Member: 36951
    Sonork: 100.63212
    what version was your phoine before and did you write only gdfs in avr format? tell me more
    Old 10-17-2003, 10:08   #3 (permalink)
    Member: 20027
    Version is t68i emea4 r7a013.
    Old 10-17-2003, 10:10   #4 (permalink)
    AndreS's Avatar
    Member: 36951
    Sonork: 100.63212
    and why did you write gdfs in avr format? it was something wrong with the phone? or you just write it for fun??
    tell me why did you write those gdfs
    Old 10-17-2003, 10:38   #5 (permalink)
    SFlood's Avatar
    Member: 83
    add to this symptoms bad RF and battery calibration data.
    its not always good to have such powerful toys as full GDFS in hands...
    contrast, no pictures and 4locks can be repaired using DIV recalc for security zone and t68i GDFS file, but RF and battery cal. now gone forever.
    Old 10-17-2003, 10:38   #6 (permalink)
    Member: 20027
    Not fun!
    T68i after make a call not listening voice in the speaker. Keypad tones - Yes. Not problem "volume 0/0". After flashing AVR and ARM and GDFS in gdf format problem remains.
    After flashing phone with t68i full GDFS file in avr format the problem is solved. 4 locks problem solved too (rewrite IMEI). Now the phone work but colors is bad and not pictures.
    Where is solution?
    Thank's!
    Old 10-17-2003, 10:46   #7 (permalink)
    SFlood's Avatar
    Member: 83
    i think there are must be another solution for no voice in speaker than avr GDFS. some gdf file of so.
    but i don't know it
    Old 10-17-2003, 10:52   #8 (permalink)
    AndreS's Avatar
    Member: 36951
    Sonork: 100.63212
    for volume 0/0 you must write T68_Volume00_fix.gdf. no need to flash avr or arm.
    Old 10-17-2003, 10:56   #9 (permalink)
    Member: 20027
    Some gdf solutoin T68_Volume00_fix.gdf not work in my phone - tested many times! I solved problem only with avr - gdfs. But...
    Old 10-17-2003, 11:02   #10 (permalink)
    AndreS's Avatar
    Member: 36951
    Sonork: 100.63212
    i don't think you can solve volume 0/0 by flashing avr and arm.
    i've tried on many phone but no succes. only way is to wrtye this gdfs in the phone.
    now to make your phone working try to change imei as the one from the back cover and after rebuild sp area using OTP imei
    br andres
    Old 10-17-2003, 11:24   #11 (permalink)
    Member: 20027
    My problem is not volume 0/0. My problem is: no voice in the speaker. After T68_Volume00_fix.gdf problem remains! After T68i Full GDFS file in .AVR format problem solved. RF - OK, battery setings - OK but bad colors and no pictures. Possible or not repair phone?????????
    Old 10-17-2003, 11:37   #12 (permalink)
    SFlood's Avatar
    Member: 83
    try to set contrast in service menu!
    no another ideas
    Old 10-17-2003, 15:00   #13 (permalink)
    Member: 20027
    no another ideas
    ...or change main board
    Old 10-17-2003, 15:26   #14 (permalink)
    AndreS's Avatar
    Member: 36951
    Sonork: 100.63212
    not the hole mainb board , only flash CPU
    Old 10-18-2003, 18:23   #15 (permalink)
    Member: 20027
    Heeeey!
    Problem solved!!!
    steps:
    1. flash with t68i_eu2_r8a015.sbn and t68i_modem_r8a015.arm
    2. write t68i_full_gdfs_in _avr_flash_format.sbn
    3. rewrite proper IMEI (in the back side label)
    4. write t68m_to_t68i_version2.gdf
    5. flash with t68i_emea4_r7a013.sbn and t68i_modem_r7a013.arm (becouse bg lang needed)
    All OK!!! No problem with voice in the speaker, no problem with colors and contrast, all pictures and sounds - good, RF and battery setings - OK! My phone work fine!
    Regards!!!!!!!
    GSMCity - GSM Hosting - 1999-2010
    Page generated in 0.10423 seconds with 8 queries
