Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Sony Ericsson > Sony Ericsson
Sony Ericsson
  • ARM Inside: A3618,R600,T100,T100c,T102,T105,T106,Z200,J200,J200i,J200c, J210,J220,230,Z300 etc.
  • AVR Inside: R520,T200,T202,T226,T226m,T226s,T230,T237,T238,T290,T290a,T290c,T290i, T300,T302,T306,T310,T312,T316,T39,T65,T68,T610,T616,T618,T628,T630,T637,P800,P802, P900,P908,P910,Z600,Z608.
  • New ARM Inside (SEMC):D750,F500,J300,K300,K310,K500,K506c,K508,K510,K600,K608,K610,K700,K750,K790,M600, P990,S700,S710,W300,W550,W600,W700,W800,W810,W900,V600,V630,V800,Z1010,Z300,Z500,Z520,Z530,Z550,Z800.
  • CR 16B Inside:T66,T600,T600c,T602.
  • ODM:J100.
  • C Series: C510, C702, C901, C902, C903, C905
  • G Series: G502, G705
  • K Series: K630, K660, K850
  • T Series: T700, T707, T715
  • V Series: V640
  • W Series: W508, W595, W705, W715, W760, W890, W902, W910, W980, W995
  • Z Series: Z750, Z770, Z780
  • Reply
    Old 06-20-2012, 13:33   #1606 (permalink)
    Member: 342027
    I have xperia E15i , after update flash , not power on , only vibrate when i put the baterry , and now i cannot connect in flash mode to write again.
    Old 06-24-2012, 11:15   #1607 (permalink)
    Member: 475308
    Originally Posted by roney_nexus View Post
    tell me any kind of sonyericsson software problem,i will tery to solve it only in 3 hour........
    Hi sir
    i have updated my mt15i from the instructions from androidworld .now its only works when its connected with usb cable or charger,
    otherwise
    its gets off..
    i dont know how to solve this problem.please guide me as i am new to sony ericson.
    will wait for your kind reply
    with best regards
    Old 06-27-2012, 18:05   #1608 (permalink)
    Member: 774126
    Sonork: 100.1618406
    Question w380 emergency calls
    solution pliz, only sos calls 4 my w380 set. tried flashing but not solve.
    Old 06-28-2012, 09:13   #1609 (permalink)
    Member: 1777868
    Sonork: jhecy
    im new here. pls help me with my K850i mobile phone. i was just using it awhile ago when my phone black out. then when i open it again, the lcd was stil black but the keypad has its light. when im pressing the keypad it is not responding. the keypad light didnt off.
    Old 06-28-2012, 20:28   #1610 (permalink)
    Crazy Poster
    Member: 1720904
    k320 how to flash with hwk how to many file to select please help me urgent
    Old 06-29-2012, 21:41   #1611 (permalink)
    Member: 264344
    PLEASE I HAVE XPERIA X10 MY PROBLEM I IS WHEN I OPEN THE CAM ITS FREEZING please anyone can help me?
    Old 07-15-2012, 05:05   #1612 (permalink)
    Crazy Poster
    Member: 505947
    morning sir my problem is about my x10 i try to update but no signal to
    but my no problem its good
    Old 07-16-2012, 14:26   #1613 (permalink)
    Crazy Poster
    Member: 781240
    c903 problem after unlock
    phone is dead after tryin to unlock with setool
    plz help
    RUNNING v 1.1289/01.15/UNI
    CARD SERIAL 00035248
    USBFLASH DRIVER VERSION 02.02.00.05
    SIGNED MODE (USING SERVER)
    ALTERNATIVE SECURITY BYPASS ENABLED
    PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5")
    CFG:110000000000
    ChipID: E900, EMP protocol: 0401
    BOOTROM MODE DETECTED
    OTP DBG: [1,53,1,35427803412279]
    OTP LOCKED: 1 CID: 53 PAF: 1 IMEI: 35427803412279 CERT: BROWN
    LDR: 2009-10-26 13:51 1202-0421_DB3210_CS_LOADER_ACC_SDRAM_R2A087
    LDR: 2009-10-26 13:52 1202-0420_DB3210_CS_LOADER_APP_SDRAM_R2A087
    GOT SEED: 90075D273580E6673570A764
    P96 AUTH PASSED
    RESTARTING ...
    llbug: read error: "The device does not recognize the command"
    Unlock FAILED
    Elapsed: 145 secs.
    Old 07-16-2012, 22:51   #1614 (permalink)
    Crazy Poster
    Member: 1714791
    bro you flash the phone and then unlock
    Old 07-21-2012, 18:56   #1615 (permalink)
    Member: 1787794
    Bro I have W705 on and off not working. But it open when I try to connect the charger.
    Bottom 2, 3, down and call are also not working. I change the top board, main flex and keypad flex but its still has the same problem. What should I do?
    Old 07-23-2012, 13:38   #1616 (permalink)
    universalunlocking's Avatar
    Member: 807542
    Sonork: 100.1581878
    sony ericsson z610i flash problem
    CFG:111000000000
    ChipID: 9900, EMP protocol: 0301
    SPEED: 921600
    LDR: 071130 1150 NPACXC1250330_DB2020_PRODUCTIONIDLOADER_P3M
    OTP: LOCKED:1 CID:51 PAF:1 IMEI:35283701355425
    CURRENT CID: 49 COLOR: BROWN
    LDR: DB2020 LOADER FOR SETOOL2
    FLASH ID: 897E
    writing "C:\Users\umar\Downloads\R1JG001_1250546_GENERIC_M Y.ssw"
    CURRENT FLASH FILE CID: 53
    SSW uses full hash, hash len is: 9200
    Will flash 460 blocks ...
    writing "C:\Users\umar\Downloads\R1JG001_FS_S_E_EUROPE_MY_ RED_CID53.SOFTWARE"
    SSW uses full hash, hash len is: 2340
    Will flash 117 blocks ...
    llbug: blk write fail.fatal
    packet not acknowledged (3C)
    A1_loader_on_loaderrologue block 0 NAK
    Loader uploading failed,exiting
    Elapsed: 321 secs.
    Old 08-07-2012, 05:33   #1617 (permalink)
    Member: 1794408
    SE Xperia X2 language settings
    hi, would you know how can change the language settings of my phone? my phone is currently in arabic and i can't hardly understand because it is in arabic fonts.
    Old 08-09-2012, 19:08   #1618 (permalink)
    roney_nexus's Avatar
    Member: 288504
    Sonork: .:100.1587032:.
    CFG:111000000000
    SPEED: 921600
    FLASH ID: 897E
    Elapsed: 321 secs.
    charge battery fully and repeat flashing procedure.
    Old 08-10-2012, 07:09   #1619 (permalink)
    Member: 1767369
    Hi, Help much appreciated. A client gave me a bricked xperia arc s. Nothing works with the phone the only hope I'm hanging on is that when plugged in computer it comes up asking for qhsusb dload driver.
    Is there any hope or I should throw it in the deep blue sea.
    Thanks
    Sent from my HTC Desire using Tapatalk 2
    Old 08-10-2012, 09:06   #1620 (permalink)
    Member: 395769
    hi,
    I have problem with K800i. SE official software Sony Pc Companion 2.1 tells me that there is a available update for my phone but I am not able to do it. There is error dialog again and again.I wonder if there is any posibility to use any program to update, tools,..etc. and link where I can download last firmware for this phone manually. I read that k810 fw could be installed on k800i. What are the adv/disadventage of this process? thanks for your answer and sorry for my english..
    Tell me any nokia hardwere problem.i will Try to solve it only in one hour mahbubalfa Nokia Repair Guide and FAQ 5905 Yesterday 17:32
    ...::Tell Me Any Kind Of Problem Setool3 Unlock/Flash ::... vodafoneserver SETool2 150 05-31-2011 15:05
    every time i have face this problem now i have to solved it m s s spk MT-BOX 8 01-31-2010 01:18
    Can U tell me what kinds of LCD is? see atth.. mobilesmith Sony Ericsson Hardware Repair Area 0 03-29-2006 06:32
    Page generated in 0.47487 seconds with 12 queries
