Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Sony Ericsson > Sony Ericsson
Sony Ericsson
  • ARM Inside: A3618,R600,T100,T100c,T102,T105,T106,Z200,J200,J200i,J200c, J210,J220,230,Z300 etc.
  • AVR Inside: R520,T200,T202,T226,T226m,T226s,T230,T237,T238,T290,T290a,T290c,T290i, T300,T302,T306,T310,T312,T316,T39,T65,T68,T610,T616,T618,T628,T630,T637,P800,P802, P900,P908,P910,Z600,Z608.
  • New ARM Inside (SEMC):D750,F500,J300,K300,K310,K500,K506c,K508,K510,K600,K608,K610,K700,K750,K790,M600, P990,S700,S710,W300,W550,W600,W700,W800,W810,W900,V600,V630,V800,Z1010,Z300,Z500,Z520,Z530,Z550,Z800.
  • CR 16B Inside:T66,T600,T600c,T602.
  • ODM:J100.
  • C Series: C510, C702, C901, C902, C903, C905
  • G Series: G502, G705
  • K Series: K630, K660, K850
  • T Series: T700, T707, T715
  • V Series: V640
  • W Series: W508, W595, W705, W715, W760, W890, W902, W910, W980, W995
  • Z Series: Z750, Z770, Z780
  • Reply
    Old 10-16-2009, 18:34   #31 (permalink)
    roney_nexus's Avatar
    Member: 288504
    Sonork: .:100.1587032:.
    i think not have any way for setool box...
    pls info me......
    gd luck.............
    The Following 7 Users Say Thank You to roney_nexus For This Useful Post:
    Old 10-16-2009, 19:50   #32 (permalink)
    Member: 1142200
    My W595 phone has got bad battery time after unlocking it with Aerix. Changed the SEMCBOOT to R6A013. Is there any free way to fix it? In three hours?
    Old 10-16-2009, 20:16   #33 (permalink)
    BackSlash_cu's Avatar
    Member: 1020744
    I have an J132 and now seems dead, I can't detect the phone.
    what to do?
    Old 10-16-2009, 23:05   #34 (permalink)
    Member: 695725
    pls info me......
    no i mean do i need a box for running the software for cruiser.thanks
    Old 10-17-2009, 09:34   #35 (permalink)
    Registered User
    Member: 1042354
    Sonork: 1602841
    how run cruiser????????????????????
    Old 10-17-2009, 09:49   #36 (permalink)
    Member: 950629
    Hi..
    Bro Se tool TP method now Very easy. If you have technological knowledge you can fix every Software Errors on SE tool Which can Fix by Cruiser. Simply I Say Setool and Cruiser are Same performance.
    But These two boxes are Failed on Some Advance Repair(Touching Security) . It can be done on Dream Box SE.
    Old 10-18-2009, 08:28   #37 (permalink)
    Crazy Poster
    Member: 1141165
    w810i flesing problem its saw HDR block
    Old 10-19-2009, 05:30   #38 (permalink)
    Member: 288504
    Originally Posted by mswmkm View Post
    Hi..
    u try to dream box than same problrm then try to hardware pls....
    gd luck..........
    Old 10-19-2009, 07:42   #39 (permalink)
    Member: 288504
    W810 flashing , unlocking , patching , modding tutorial (very easy)
    Steps that you will do:
    1.Instal USB flash drivers
    2.Identifying your phone's CID
    3.Make a GDFS backup for safety
    4.FLASH your phone
    5.UNLOCK your phone
    6.MOD your phone
    STEP 1.
    -Download USB flash drivers from HERE
    -Conect the USB cable to PC
    -Turn off phone
    -Press & hold the "C" key on the phone's keyboard and insert the USB cable into the phone.
    -A popup will appear that a NEW HARDWARE was found .
    -Choose the USB FLASH DRIVERS path .. for instaling them for this new hardware
    - After is done plug off the phone from usb cable and remove/insert back battery.
    STEP 2.
    -Turn off the phone and remove SIM and MEMORY STICK .
    -Run Setool2 lite and choose your PHONE TYPE (W810)
    -press IDENTIFY
    -PRESS AND HOLD THE " C " KEY AND CONNECT THE PHONE .
    -Setool will display in the main window all the info of your phone ( FIRMWARE , CID ,IMEI ),
    STEP 3.
    Make a GDFS Backup for safety (you can do that with SETOOL or XS ++)
    -1.With Setool2 lite:
    -Download SEtool2 lite v1.11 from the SOFTWARES area
    -Run SETOOL and At "Phone Type" Choose your phone model (W810) before you start.
    -Click on "Read GDFS"
    -Now turn off your phone,hold c(from phone)and insert USB cable.
    -Setool lite will create a backup of your GDFS.It will be stored in the SE Tool main folder,("gdfs_[your IMEI].bin")
    -Disconnect phone
    -2.With XS++:
    -Run XS++
    -Click "Connect",turn off your phone,hold c(from phone)and insert USB cable!
    -Click on GDFS then click on Backup GDFS and wait for message "Disconnected...Unplug the phone".
    -Now disconnect your phone
    STEP 4.
    FLASH your phone
    -Download the MAIN / FS / CUSTOMIZATION for your PHONE MODEL(W810) AND YOU PHONE'S CID (from [http://*****-forum.com/index.php?topic=111.0]HERE[/URL]).
    -Turn off the phone and remove SIM card and Memory card.
    -Start Setool2 lite and choose PHONE TYPE-W810
    -Click on ADD and select the MAIN (.MBN file) .mbn] and ADD next the FS(.FBN file) [ex:W810_R4ED001_FS_MEDITERR_RED49.fbn] (they will appear both in the ADD-list)
    -At MISC FILES select the CUSTOMIZATION (.ZIP) [ex:W810_CDA102555_4_R2A_Generic_MEDITERR.zip ]
    -Press FLASH and setool will ask you to insert the cable into the phone .
    -Quickly you PRESS and HOLD the button C on your phone's keyboard and CONNECT the usb cable.
    -Setool will show then that it's starting to flash the phone.
    -You can remove the usb cable only when it displays: "elapsed xxx second,phone detached".After that disconnect the phone,get battery out few seconds,reinsert battery,SIM card and memory stick and start up phone,will appear a message "Please wait"and wait!
    -2.With XS++:
    -Download XS++ from Softwares area
    -Run XS++
    -Click "Connect"
    -Now quickly PRESS and HOLD the button C on your phone and CONNECT the usb cable
    -Now mark "Flash Main Firmware" and "Flash Filesystem"
    -At "Flash Main Firmware" add your MAIN (.MBN file) [ex:W810_R4EA031_MAIN_GENERIC_HN_RED49.mbn,at "Flash filesystem add FS(.FBN file) [ex:W810_R4ED001_FS_MEDITERR_RED49.fbn]
    -Now mark "Customize Filesystem" and select W810 and region(same as FS,ex:if FS is like FS_MEDITERR_RED49.fbn you will select MEDTERR custom pack
    -Now click "Flash" and wait for XS++ finish flashing your phone!
    -Wait for message "Disconnected...Unplug the phone" and disconnect your phone,reinsert battery,SIM card and memory stick and start up phone,will appear a message "Please wait"and wait!
    Step 5.
    UNLOCK your phone --- with Setool ---
    1.Make the unlock patch:
    -Download Unlock patch maker form Here
    -Run program.
    -Click on "..."
    -Go to phone MAIN folder[ex:W810_R4EA031_MAIN_GENERIC_HN_RED49] and select it!
    -Click "Make patch" and close program
    -Unlock patch it's on vkp folder[ex:Remove_SIM_lock_W810_R4EA031.vkp]!
    2.Writing the patch to the phone only with Setool :
    !!! NOTE THAT THIS STEP DESCRIBES THE WAY YOU CAN APPLY ANY PATCH TO A DB2010 PHONE NOT JUST THE UNLOCK PATCH !!!
    -Run Setool.
    -Select "Phone type" W810.
    (http://aycu33.webshots.com/image/355...7436561_rs.jpg)
    -At MISC FILES select the UNLOCK patch[ex:Remove_SIM_lock_W810_R4EA031.vkp]
    -Press "WRITE SCRIPT"
    -Press and hold "c" from phone and insert USB cable
    -When the program ask to select "YES to remove patch or NO to apply patch",you press NO.
    -Now you wait untill you see next message: Elapsed ___ sec and disconnect your phone!
    Your phone is now UNLOCKED
    STEP 6.
    MOD your phone
    With XS++:
    -Run XS++
    (http://www.postimage.org/aV1wW_i-ab8...ac40141ea6.bmp)
    -Click Connect
    -Now shut down your phone,press and hold "c" and insert USB cable
    (http://www.postimage.org/aV1z4H0-ab8...ac40141ea6.bmp)
    -Click on "FSX"
    (http://www.postimage.org/PqBPbJ-ab8b...ac40141ea6.bmp)
    -Click "Start FSX" and wait
    (http://www.postimage.org/PqCn6J-ab8b...ac40141ea6.bmp)
    -Now you can change:
    -1.Acoustics(sound drivers)
    --Download acoustics (.apf extesion) FROM HERE and drag and drop them to ifs/settings/acoustic
    -2.Camera driver
    --Download camera drivers FROM HERE and drog and drop them to ifs/settings/camera
    -3.Display driver
    --Download display driver FROM HERE and drag and drop them to ifs/settings/display
    -4.Layouts
    --Download layouts FROM HERE and drag and drop them to tpa/system/layout
    -5.Menu
    --Download menus FROM HERE and drag and drop them to tpa/preset/system/menu
    Credits ??: V!r7u@l-X
    Thanks to:KNET and *****-forum staff
    IF YOU LIKE THE TUTORIAL SAY THANKS, AT LEAST!
    Do NOT COPY THIS TUTORIAL OR PARTS OF IT WITHOUT OUR APPROVAL. IF YOU COPY THIS TUTORIAL WITHOUT US TO KNOW YOU MUST PUT A LINK TO THE ORIGINAL ONE HERE !!! OTHERWISE YOU WILL BREAK COPYRIGHT LAWS AND YOUR TUTORIAL WILL BE ERASED FROM ANY SITE .WE CAN TRACK BACK COPYES !!!
    The Following 14 Users Say Thank You to roney_nexus For This Useful Post:
    Old 10-19-2009, 08:49   #40 (permalink)
    Crazy Poster
    Member: 1141165
    Thank you very much
    all the best ......
    Old 10-19-2009, 08:53   #41 (permalink)
    Member: 288504
    what to do?
    u can try setool or cruiser,then info here pls.....
    Old 10-20-2009, 17:01   #42 (permalink)
    Member: 1145658
    Camera stops working
    hi i am using the se w705. i have put a picture on my phone background. sometimes while taking pictures, my phone decides to not save any of my picture files and when i upload them up on the computer it appears as blank images, and at that time my picture background disappears, an indication to me when my camera is not working and i have to restart my phone.
    Old 10-20-2009, 17:33   #43 (permalink)
    Member: 1020744
    yes, I'm using SE Tool and the phone doesn't respond.
    Maybe I need some GDFS. no?
    Old 10-21-2009, 13:30   #44 (permalink)
    Member: 288504
    just try to flash than not ok try to hardware.........
    gd luck............
    The Following 8 Users Say Thank You to roney_nexus For This Useful Post:
    Old 10-21-2009, 19:23   #45 (permalink)
    Member: 1145658
    gd luck............
    u mean turn off/ on flash?
    Tell me any nokia hardwere problem.i will Try to solve it only in one hour mahbubalfa Nokia Repair Guide and FAQ 5900 05-02-2013 17:07
    ...::Tell Me Any Kind Of Problem Setool3 Unlock/Flash ::... vodafoneserver SETool2 150 05-31-2011 15:05
    every time i have face this problem now i have to solved it m s s spk MT-BOX 8 01-31-2010 01:18
    Can U tell me what kinds of LCD is? see atth.. mobilesmith Sony Ericsson Hardware Repair Area 0 03-29-2006 06:32
    Page generated in 0.46900 seconds with 12 queries
